[postgis-tickets] [PostGIS] #4269: Inconsistent result for ST_Intersects depending on the plan
PostGIS trac at osgeo.org
Thu Dec 6 02:15:39 PST 2018
  Reporter:  Algunenano  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  critical    |  Milestone:  PostGIS 2.4.7
 Component:  postgis     |    Version:  2.5.x
Resolution:              |   Keywords:
Comment (by tilt):
 Using _ST_Intersects() instead of ST_Intersects does not change the issue
 with me.
 It is correct that one of the geometries is (on purpose) invalid since it
 is a vertical plane. It's the third one in the example.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4269#comment:5>
