[postgis-tickets] [PostGIS] #4269: Inconsistent result for ST_Intersects depending on the plan
PostGIS trac at osgeo.org
Mon Dec 10 01:14:23 PST 2018
  Reporter:  Algunenano  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  critical    |  Milestone:  PostGIS 2.4.7
 Component:  postgis     |    Version:  2.5.x
Resolution:              |   Keywords:
Comment (by robe):
 I thought when ST_IsValid is false the intersection is really unknown?
 Anyway it does seem like the caching is at fault here.  ST_DWithin returns
 all true as expected, but the ST_Intersects flip answers depending on the
 order the data is traversed
 WITH data AS (
 SELECT 134 as cid,720::bigint as blockid, ST_GeomFromText('POLYGON Z
 ((122427.759 489209.498 14.5066901703871,122395.957 489222.943
 14.3997094723791,122399.649 489231.676 4.98556790825181,122431.452
 489218.231 5.09216481886026,122427.759 489209.498 14.5066901703871))')
 geom
 UNION ALL
 SELECT 316, 720, ST_GeomFromText('POLYGON Z ((122427.027 489216.053
 5.97863674861823,122419.873 489219.077 6.03923989893278,122421.6
 489223.163 1.83027232084998,122428.754 489220.138
 1.77054008712955,122427.027 489216.053 5.97863674861823))')
 UNION ALL
 SELECT 10890, 720, ST_GeomFromText('POLYGON Z ((122422.267 489220.741
 0,122424.396 489219.847 0,122424.396 489219.847 30,122422.267 489220.741
 30,122422.267 489220.741 0))')
 SELECT ST_DWithin(a.geom, b.geom,0), ST_Intersects(a.geom,b.geom),
 ST_Distance(a.geom, b.geom), ST_ISValid(a.geom) AS isvalid_a,
 ST_IsValid(b.geom) AS isvalid_b,
 a.cid AS acid, b.cid As bcid,
 a.blockid,b.blockid
 FROM data a, data b
 WHERE a.cid != b.cid
 AND a.blockid = b.blockid
 AND a.blockid::int = 720
 AND ST_DWithin(a.geom, b.geom,0);
 Gives me true for all 6 for ST_DWithin but for ST_Intersects the 3 that
 have invalid geoms
 would be filtered out
  st_dwithin | st_intersects | st_distance | isvalid_a | isvalid_b | acid
 | bcid  | blockid | blockid
  t          | f             |           0 | f         | t         | 10890
 |   134 |     720 |     720
  t          | t             |           0 | t         | t         |   316
 |   134 |     720 |     720
 |   316 |     720 |     720
  t          | t             |           0 | t         | t         |   134
 |   316 |     720 |     720
  t          | f             |           0 | t         | f         |   316
 | 10890 |     720 |     720
  t          | t             |           0 | t         | f         |   134
 | 10890 |     720 |     720
 (6 rows)
 WITH data AS (
 geom
 UNION ALL
 UNION ALL
 ST_Distance(a.geom, b.geom), ST_IsValid(a.geom) AS isvalid_a,
 a.cid AS acid, b.cid AS bcid,
 a.blockid,b.blockid
 FROM data a, data b
 AND a.blockid = 720
 Gives me true for all 6 for ST_DWithin and filters out 1 with invalid
 |   316 |     720 |     720
 | 10890 |     720 |     720
 |   134 |     720 |     720
  t          | t             |           0 | t         | f         |   316
 | 10890 |     720 |     720
 |   134 |     720 |     720
  t          | t             |           0 | f         | t         | 10890
 |   316 |     720 |     720
 (6 rows)
 I thought maybe the issue was because prepared geometry is assuming
 ST_Intersects is a commutative operation.  In the case of invalid
 geometries maybe it's not.
 though doing a standalone and flipping the order of the geometries, I get
 false in both cases
 So this:
 SELECT ST_Intersects('POLYGON Z ((122422.267 489220.741 0,122424.396
 489219.847 0,122424.396 489219.847 30,122422.267 489220.741 30,122422.267
 489220.741 0))'::geometry,
 1.77054008712955,122427.027 489216.053 5.97863674861823))'::geometry
 returns:
 false
 SELECT ST_Intersects('POLYGON Z ((122427.027 489216.053
 1.77054008712955,122427.027 489216.053 5.97863674861823))'::geometry   ,
 'POLYGON Z ((122422.267 489220.741 0,122424.396 489219.847 0,122424.396
 489219.847 30,122422.267 489220.741 30,122422.267 489220.741
 0))'::geometry
 returns: false
 So not sure how it's getting a true for:
   134 | 10890
 and when I explicitly ask for the ids, I get the expected false answer for
 both regardless if I cast or don't cast the integer
 WITH data AS (
 geom
 UNION ALL
 UNION ALL
 a.blockid,b.blockid
 FROM data a, data b
 AND ( (a.cid = 134 AND b.cid =10890)
      OR (a.cid = 10890 and b.cid = 134) );
  t          | f             |           0 | t         | f         |   134
 | 10890 |     720 |     720
 |   134 |     720 |     720
 (2 rows)
 WITH data AS (
 geom
 UNION ALL
 UNION ALL
 a.blockid,b.blockid
 FROM data a, data b
 AND a.blockid = 720
 | 10890 |     720 |     720
 |   134 |     720 |     720
 (2 rows)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4269#comment:7>
