[postgis-tickets] [PostGIS] #4267: Bump minimum GEOS version to 3.6
PostGIS trac at osgeo.org
Sun Dec 16 07:42:05 PST 2018
  Reporter:  komzpa   |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:  fixed    |   Keywords:
Comment (by komzpa):
 In [changeset:"17106" 17106]:
 #!CommitTicketReference repository="" revision="17106"
 Remove stray uncommented line while removing GEOS 3.5 check
 References #4267
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4267#comment:2>
