[postgis-tickets] [PostGIS] #4279: Can't find proj
PostGIS trac at osgeo.org
Tue Dec 25 13:53:36 PST 2018
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 2.3.9
 Component:  buildbots  |    Version:  2.3.x
Resolution:             |   Keywords:
Comment (by robe):
 I should note the thing that both winnie and the bessies have in common is
 in the configure scripts for both I set the --with-projdir configure
 switch.  I think the other bots use their default proj install location.
 So I suspect this switch might be broken.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4279#comment:1>
