[postgis-tickets] [PostGIS] #4284: Winnie hanging indefinitely on CUnit GEOS tests
PostGIS trac at osgeo.org
Sat Dec 29 14:23:08 PST 2018
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS GEOS
Component:  postgis  |    Version:  trunk
 Keywords:           |
  -------------- Dependencies --------------
   GEOS config:          /projects/geos/rel-3.8.0devw64gcc48/bin/geos-
 config
   GEOS version:         3.8.0dev
   GDAL config:          /projects/gdal/rel-2.2.4w64gcc48/bin/gdal-config
   GDAL version:         2.2.4
   SFCGAL config:        /projects/CGAL/rel-sfcgal-1.3.2w64gcc48/bin
 /sfcgal-config
   SFCGAL version:       1.3.2
   PostgreSQL config:
 /projects/postgresql/rel/pg11w64gcc48/bin/pg_config
   PostgreSQL version:   PostgreSQL 11.0
   PROJ4 version:        49
   Libxml2 config:       /projects/libxml/rel-
 libxml2-2.7.8w64gcc48/bin/xml2-config
   Libxml2 version:      2.7.8
   JSON-C support:       yes
   protobuf-c support:   yes
   PCRE support:         yes
   Perl:                 /bin/perl
 Suite: algorithm
   Test: test_lw_segment_side ...passed
   Test: test_lw_segment_intersects ...passed
   Test: test_lwline_crossing_short_lines ...passed
   Test: test_lwline_crossing_long_lines ...passed
   Test: test_lwline_crossing_bugs ...passed
   Test: test_lwpoint_set_ordinate ...passed
   Test: test_lwpoint_get_ordinate ...passed
   Test: test_point_interpolate ...passed
   Test: test_lwline_interpolate_points ...passed
   Test: test_lwline_interpolate_point_3d ...passed
   Test: test_lwline_clip ...passed
   Test: test_lwpoly_clip ...passed
   Test: test_lwtriangle_clip ...passed
   Test: test_lwline_clip_big ...passed
   Test: test_lwmline_clip ...passed
   Test: test_geohash_point ...passed
   Test: test_geohash_precision ...passed
   Test: test_geohash ...passed
   Test: test_geohash_point_as_int ...passed
   Test: test_isclosed ...passed
   Test: test_lwgeom_simplify ...passed
   Test: test_lw_arc_center ...passed
 I think this might be because I flipped her to GEOS 3.8 testing.
 pramsey I think is aware of this.  I'll flip back to 3.7 and test locally
 on mine to see if gcc 8.1 has the same issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4284>
