[postgis-tickets] [PostGIS] #4284: Winnie hanging indefinitely on CUnit GEOS tests
PostGIS trac at osgeo.org
Sat Dec 29 14:26:25 PST 2018
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS GEOS
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Description changed by robe:
Old description:
>  -------------- Dependencies --------------
>   GEOS config:          /projects/geos/rel-3.8.0devw64gcc48/bin/geos-
> config
>   GEOS version:         3.8.0dev
>   GDAL config:          /projects/gdal/rel-2.2.4w64gcc48/bin/gdal-config
>   GDAL version:         2.2.4
>   SFCGAL config:        /projects/CGAL/rel-sfcgal-1.3.2w64gcc48/bin
> /sfcgal-config
>   SFCGAL version:       1.3.2
>   PostgreSQL config:
> /projects/postgresql/rel/pg11w64gcc48/bin/pg_config
>   PostgreSQL version:   PostgreSQL 11.0
>   PROJ4 version:        49
>   Libxml2 config:       /projects/libxml/rel-
> libxml2-2.7.8w64gcc48/bin/xml2-config
>   Libxml2 version:      2.7.8
>   JSON-C support:       yes
>   protobuf-c support:   yes
>   PCRE support:         yes
>   Perl:                 /bin/perl
> Suite: algorithm
>   Test: test_lw_segment_side ...passed
>   Test: test_lw_segment_intersects ...passed
>   Test: test_lwline_crossing_short_lines ...passed
>   Test: test_lwline_crossing_long_lines ...passed
>   Test: test_lwline_crossing_bugs ...passed
>   Test: test_lwpoint_set_ordinate ...passed
>   Test: test_lwpoint_get_ordinate ...passed
>   Test: test_point_interpolate ...passed
>   Test: test_lwline_interpolate_points ...passed
>   Test: test_lwline_interpolate_point_3d ...passed
>   Test: test_lwline_clip ...passed
>   Test: test_lwpoly_clip ...passed
>   Test: test_lwtriangle_clip ...passed
>   Test: test_lwline_clip_big ...passed
>   Test: test_lwmline_clip ...passed
>   Test: test_geohash_point ...passed
>   Test: test_geohash_precision ...passed
>   Test: test_geohash ...passed
>   Test: test_geohash_point_as_int ...passed
>   Test: test_isclosed ...passed
>   Test: test_lwgeom_simplify ...passed
>   Test: test_lw_arc_center ...passed
> I think this might be because I flipped her to GEOS 3.8 testing.
> pramsey I think is aware of this.  I'll flip back to 3.7 and test locally
> on mine to see if gcc 8.1 has the same issue.
New description:
 config
   GDAL version:         2.2.4
 /sfcgal-config
   PostgreSQL config:
   PROJ4 version:        49
   JSON-C support:       yes
   PCRE support:         yes
   Perl:                 /bin/perl
 Suite: algorithm
 :hangs here forever
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4284#comment:2>
