[postgis-tickets] [PostGIS] #3706: Use of deprecated function
PostGIS trac at osgeo.org
Mon Jan 8 01:52:33 PST 2018
  Reporter:  postgispaul  |      Owner:  robe
      Type:  defect       |     Status:  closed
  Priority:  high         |  Milestone:  PostGIS 2.3.3
 Component:  postgis      |    Version:  2.3.x
Resolution:  worksforme   |   Keywords:
Comment (by postgispaul):
 Ok, after changingthe postgis_scripts_installed to return 2.2.0 and do the
 alter extension commands the st_extent uses the correct st_combinebbox
 So thanks!, it's finally solved
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3706#comment:10>
