[postgis-tickets] [PostGIS] #3957: ST_StartPoint - not works correctly
PostGIS trac at osgeo.org
Mon Jan 8 06:54:11 PST 2018
  Reporter:  sanyasi  |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 2.4.3
 Component:  postgis  |    Version:  2.4.x
Resolution:  invalid  |   Keywords:
Comment (by sanyasi):
 If I manually change the binaries to the old version, then the function
 returns the same results. The problem is not in the database data.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3957#comment:5>
