[postgis-tickets] [PostGIS] #3956: Upgrade does not upgrade geog_brin_inclusion_add_value function to use the updated module
PostGIS trac at osgeo.org
Tue Jan 9 02:38:22 PST 2018
updated module
  Reporter:  keiko713    |      Owner:  robe
      Type:  defect      |     Status:  closed
  Priority:  medium      |  Milestone:  PostGIS 2.4.3
 Component:  postgis     |    Version:  2.4.x
Resolution:  worksforme  |   Keywords:
Comment (by strk):
 BTW, I don't think you need to handle the PostgreSQL version upgrade
 because the upgrade script used should be the one built against the *new*
 version of PostgreSQL. Is this not the case, with pg_upgrade ? We actually
 do know we ask the users to upgrade with postgis_extension_upgrade() after
 pg_upgrade, right?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3956#comment:10>
