[postgis-tickets] r16234 - Fix OPERATOR CLASS syntax
Sandro Santilli strk at kbt.io
Tue Jan 9 09:03:16 PST 2018
Author: strk
Date: 2018-01-09 09:03:16 -0800 (Tue, 09 Jan 2018)
New Revision: 16234
   trunk/postgis/geography_brin.sql.in
   trunk/postgis/postgis_brin.sql.in
Modified: trunk/postgis/geography_brin.sql.in
--- trunk/postgis/geography_brin.sql.in	2018-01-09 15:56:33 UTC (rev 16233)
+++ trunk/postgis/geography_brin.sql.in	2018-01-09 17:03:16 UTC (rev 16234)
@@ -64,7 +64,7 @@
 -- Availability: 2.3.0
 CREATE OPERATOR CLASS brin_geography_inclusion_ops
   DEFAULT FOR TYPE geography
-  USING brin
+  USING brin AS
     FUNCTION      1        brin_inclusion_opcinfo(internal),
     FUNCTION      2        geog_brin_inclusion_add_value(internal, internal, internal, internal),
     FUNCTION      3        brin_inclusion_consistent(internal, internal, internal),
Modified: trunk/postgis/postgis_brin.sql.in
--- trunk/postgis/postgis_brin.sql.in	2018-01-09 15:56:33 UTC (rev 16233)
+++ trunk/postgis/postgis_brin.sql.in	2018-01-09 17:03:16 UTC (rev 16234)
@@ -208,7 +208,7 @@
 CREATE OPERATOR CLASS brin_geometry_inclusion_ops_2d
   DEFAULT FOR TYPE geometry
-  USING brin
+  USING brin AS
     FUNCTION      2        geom2d_brin_inclusion_add_value(internal, internal, internal, internal),
@@ -234,7 +234,7 @@
 CREATE OPERATOR CLASS brin_geometry_inclusion_ops_3d
   FOR TYPE geometry
-  USING brin
+  USING brin AS
     FUNCTION      1        brin_inclusion_opcinfo(internal) ,
     FUNCTION      2        geom3d_brin_inclusion_add_value(internal, internal, internal, internal),
@@ -252,7 +252,7 @@
 CREATE OPERATOR CLASS brin_geometry_inclusion_ops_4d
   FOR TYPE geometry
-  USING brin
+  USING brin AS
     FUNCTION      2        geom4d_brin_inclusion_add_value(internal, internal, internal, internal),
