[postgis-tickets] r16242 - Upgrade SFCGAL too when requested
Sandro Santilli strk at kbt.io
Tue Jan 9 10:40:52 PST 2018
Author: strk
Date: 2018-01-09 10:40:52 -0800 (Tue, 09 Jan 2018)
New Revision: 16242
   branches/2.3/regress/run_test.pl
Modified: branches/2.3/regress/run_test.pl
--- branches/2.3/regress/run_test.pl	2018-01-09 18:36:31 UTC (rev 16241)
+++ branches/2.3/regress/run_test.pl	2018-01-09 18:40:52 UTC (rev 16242)
@@ -1398,6 +1398,22 @@
             die "$script not found\n";
+    if ( $OPT_WITH_SFCGAL )
+        my $script = `ls ${STAGED_SCRIPTS_DIR}/sfcgal_upgrade.sql`;
+        chomp($script);
+        if ( -e $script )
+            print "Upgrading sfcgal\n";
+            load_sql_file($script);
+        else
+            die "$script not found\n";
     return 1;
@@ -1434,6 +1450,17 @@
+      my $sql = "ALTER EXTENSION postgis_sfcgal UPDATE TO '${nextver}'";
+      $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
+      $rv = system($cmd);
+      if ( $rv ) {
+        fail "Error encountered creating EXTENSION POSTGIS_SFCGAL", $REGRESS_LOG;
+        die;
     return 1;
