[postgis-tickets] [PostGIS] #3975: ST_Transform references spatial_ref_sys without schema
PostGIS trac at osgeo.org
Thu Jan 11 12:23:58 PST 2018
  Reporter:  javitonino  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 2.4.3
 Component:  postgis     |    Version:  2.4.x
Resolution:              |   Keywords:
Comment (by pramsey):
 Confirmed that using search_path parameter on the function has a
 deleterious effect on performance.
 create table pts as
   select st_setsrid(st_makepoint(random()*360 - 180,random() * 180 -
 90),4326) as geom,
   generate_series(1,100000) as id;
 select sum(st_x(st_transform(geom, 3857))) from pts;
 -- Time: 157.676 ms
 alter function st_transform(geometry, integer) set
 search_path=public,pg_catalog;
 -- Time: 587.814 ms
 Very unfortunate.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3975#comment:8>
