[postgis-tickets] r16264 - Encoded Polyline of EMPTY
Darafei komzpa at gmail.com
Fri Jan 12 12:48:50 PST 2018
Author: komzpa
Date: 2018-01-12 00:48:50 -0800 (Fri, 12 Jan 2018)
New Revision: 16264
   branches/2.4/NEWS
   branches/2.4/liblwgeom/cunit/cu_out_encoded_polyline.c
   branches/2.4/liblwgeom/lwout_encoded_polyline.c
Pull in from trunk
Closes #3982
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS	2018-01-12 08:18:39 UTC (rev 16263)
+++ branches/2.4/NEWS	2018-01-12 08:48:50 UTC (rev 16264)
@@ -9,6 +9,9 @@
   - #3965, ST_ClusterKMeans used to lose some clusters on initialization
            (Darafei Praliaskouski)
   - #3956, Brin opclass object does not upgrade properly (Sandro Santilli)
+  - #3982, ST_AsEncodedPolyline supports LINESTRING EMPTY and MULTIPOINT EMPTY
+           (Darafei Praliaskouski)
  * Enhancements *
   - #3944, Update to EPSG register v9.2 (Even Rouault)
Modified: branches/2.4/liblwgeom/cunit/cu_out_encoded_polyline.c
--- branches/2.4/liblwgeom/cunit/cu_out_encoded_polyline.c	2018-01-12 08:18:39 UTC (rev 16263)
+++ branches/2.4/liblwgeom/cunit/cu_out_encoded_polyline.c	2018-01-12 08:48:50 UTC (rev 16264)
@@ -1,15 +1,15 @@
-* PostGIS - Spatial Types for PostgreSQL
-* http://postgis.net
-* Copyright 2014 Kashif Rasul <kashif.rasul at gmail.com> and
-*                Shoaib Burq <saburq at gmail.com>
-* This is free software; you can redistribute and/or modify it under
-* the terms of the GNU General Public Licence. See the COPYING file.
+ * PostGIS - Spatial Types for PostgreSQL
+ * http://postgis.net
+ * Copyright 2014 Kashif Rasul <kashif.rasul at gmail.com> and
+ *                Shoaib Burq <saburq at gmail.com>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU General Public Licence. See the COPYING file.
 #include <stdio.h>
 #include <stdlib.h>
@@ -19,10 +19,11 @@
 #include "liblwgeom_internal.h"
 #include "cu_tester.h"
-static void do_encoded_polyline_test(char * in, int precision, char * out)
+static void
+do_encoded_polyline_test(char* in, int precision, char* out)
-	LWGEOM *g;
-	char * h;
+	LWGEOM* g;
+	char* h;
 	g = lwgeom_from_wkt(in, LW_PARSER_CHECK_NONE);
 	h = lwgeom_to_encoded_polyline(g, precision);
@@ -36,66 +37,65 @@
 	lwfree(h);
-static void out_encoded_polyline_test_geoms(void)
+static void
+out_encoded_polyline_test_geoms(void)
 	/* Magic Linestring */
-	    "SRID=4326;LINESTRING(33.6729 38.7071,33.6692 38.701,33.6673 38.6972,33.6626 38.6871)",
-	    5,
-	    "k~fkFsvolEbe at bVvVzJb~@j\\");
-		return;
+		"SRID=4326;LINESTRING(33.6729 38.7071,33.6692 38.701,"
+		"33.6673 38.6972,33.6626 38.6871)",
+		5,
+		"k~fkFsvolEbe at bVvVzJb~@j\\");
 	/* Linestring */
-	    "LINESTRING(-120.2 38.5,-120.95 40.7,-126.453 43.252)",
-	    5,
-	    "_p~iF~ps|U_ulLnnqC_mqNvxq`@");
+		"LINESTRING(-120.2 38.5,-120.95 40.7,-126.453 43.252)",
+		5,
+		"_p~iF~ps|U_ulLnnqC_mqNvxq`@");
+	do_encoded_polyline_test("LINESTRING EMPTY", 5, "");
 	/* MultiPoint */
-	    "MULTIPOINT(-120.2 38.5,-120.95 40.7)",
-	    5,
-	    "_p~iF~ps|U_ulLnnqC");
+		"MULTIPOINT(-120.2 38.5,-120.95 40.7)", 5, "_p~iF~ps|U_ulLnnqC");
+	do_encoded_polyline_test("MULTIPOINT EMPTY", 5, "");
-static void out_encoded_polyline_test_srid(void)
+static void
+out_encoded_polyline_test_srid(void)
 	/* SRID - with PointArray */
-	    "SRID=4326;LINESTRING(0 1,2 3)",
-	    5,
-	    "_ibE?_seK_seK");
+		"SRID=4326;LINESTRING(0 1,2 3)", 5, "_ibE?_seK_seK");
 	/* wrong SRID */
-	    "SRID=4327;LINESTRING(0 1,2 3)",
-	    5,
-	    "_ibE?_seK_seK");
+		"SRID=4327;LINESTRING(0 1,2 3)", 5, "_ibE?_seK_seK");
-static void out_encoded_polyline_test_precision(void)
+static void
+out_encoded_polyline_test_precision(void)
 	/* Linestring */
-	    "LINESTRING(-0.250691 49.283048,-0.250633 49.283376,-0.250502 49.283972,-0.251245 49.284028,-0.251938 49.284232,-0.251938 49.2842)",
-	    6,
-	    "o}~~|AdshNoSsBgd at eGoBlm@wKhj@~@?");
+		"LINESTRING(-0.250691 49.283048, -0.250633 49.283376,"
+		"-0.250502 49.283972, -0.251245 49.284028, -0.251938 "
+		"49.284232, -0.251938 49.2842)",
+		6,
+		"o}~~|AdshNoSsBgd at eGoBlm@wKhj@~@?");
 	/* MultiPoint */
-	    3,
-	    "gejAnwiFohCzm@");
+		"MULTIPOINT(-120.2 38.5,-120.95 40.7)", 3, "gejAnwiFohCzm@");
 ** Used by test harness to register the tests in this file.
 void out_encoded_polyline_suite_setup(void);
-void out_encoded_polyline_suite_setup(void)
+void
+out_encoded_polyline_suite_setup(void)
 	CU_pSuite suite = CU_add_suite("encoded_polyline_output", NULL, NULL);
 	PG_ADD_TEST(suite, out_encoded_polyline_test_geoms);
Modified: branches/2.4/liblwgeom/lwout_encoded_polyline.c
--- branches/2.4/liblwgeom/lwout_encoded_polyline.c	2018-01-12 08:18:39 UTC (rev 16263)
+++ branches/2.4/liblwgeom/lwout_encoded_polyline.c	2018-01-12 08:48:50 UTC (rev 16264)
@@ -18,21 +18,21 @@
 #include "stringbuffer.h"
-static char * lwline_to_encoded_polyline(const LWLINE*, int precision);
-static char * lwmmpoint_to_encoded_polyline(const LWMPOINT*, int precision);
-static char * pointarray_to_encoded_polyline(const POINTARRAY*, int precision);
+static char* lwline_to_encoded_polyline(const LWLINE*, int precision);
+static char* lwmmpoint_to_encoded_polyline(const LWMPOINT*, int precision);
+static char* pointarray_to_encoded_polyline(const POINTARRAY*, int precision);
 /* takes a GEOMETRY and returns an Encoded Polyline representation */
-extern char *
-lwgeom_to_encoded_polyline(const LWGEOM *geom, int precision)
+extern char*
+lwgeom_to_encoded_polyline(const LWGEOM* geom, int precision)
 	int type = geom->type;
 	switch (type)
@@ -42,53 +42,66 @@
 	case MULTIPOINTTYPE:
 		return lwmmpoint_to_encoded_polyline((LWMPOINT*)geom, precision);
 	default:
-		lwerror("lwgeom_to_encoded_polyline: '%s' geometry type not supported", lwtype_name(type));
+		lwerror("lwgeom_to_encoded_polyline: '%s' geometry type not supported",
+				lwtype_name(type));
 		return NULL;
-static
-char * lwline_to_encoded_polyline(const LWLINE *line, int precision)
+static char*
+lwline_to_encoded_polyline(const LWLINE* line, int precision)
 	return pointarray_to_encoded_polyline(line->points, precision);
-static
-char * lwmmpoint_to_encoded_polyline(const LWMPOINT *mpoint, int precision)
+static char*
+lwmmpoint_to_encoded_polyline(const LWMPOINT* mpoint, int precision)
-	LWLINE *line = lwline_from_lwmpoint(mpoint->srid, mpoint);
-	char *encoded_polyline = lwline_to_encoded_polyline(line, precision);
+	LWLINE* line = lwline_from_lwmpoint(mpoint->srid, mpoint);
+	char* encoded_polyline = lwline_to_encoded_polyline(line, precision);
 	lwline_free(line);
 	return encoded_polyline;
-static
-char * pointarray_to_encoded_polyline(const POINTARRAY *pa, int precision)
+static char*
+pointarray_to_encoded_polyline(const POINTARRAY* pa, int precision)
 	int i;
-	const POINT2D *prevPoint;
-	int *delta = lwalloc(2*sizeof(int)*pa->npoints);
-	char *encoded_polyline = NULL;
-	stringbuffer_t *sb;
-	double scale = pow(10,precision);
+	const POINT2D* prevPoint;
+	int* delta;
+	char* encoded_polyline = NULL;
+	stringbuffer_t* sb;
+	double scale = pow(10, precision);
-	/* Take the double value and multiply it by 1x10^precision, rounding the result */
+	/* Empty input is empty string */
+	if (pa->npoints == 0) {
+		encoded_polyline = lwalloc(1 * sizeof(char));
+		encoded_polyline[0] = 0;
+		return encoded_polyline;
+	delta = lwalloc(2 * sizeof(int) * pa->npoints);
+	/* Take the double value and multiply it by 1x10^precision, rounding the
+	 * result */
 	prevPoint = getPoint2d_cp(pa, 0);
-	delta[0] = round(prevPoint->y*scale);
-	delta[1] = round(prevPoint->x*scale);
+	delta[0] = round(prevPoint->y * scale);
+	delta[1] = round(prevPoint->x * scale);
-	/*  points only include the offset from the previous point */
-	for (i=1; i<pa->npoints; i++)
+	/* Points only include the offset from the previous point */
+	for (i = 1; i < pa->npoints; i++)
-		const POINT2D *point = getPoint2d_cp(pa, i);
-		delta[2*i] = round(point->y*scale) - round(prevPoint->y*scale);
-		delta[(2*i)+1] = round(point->x*scale) - round(prevPoint->x*scale);
+		const POINT2D* point = getPoint2d_cp(pa, i);
+		delta[2 * i] = round(point->y * scale) - round(prevPoint->y * scale);
+		delta[(2 * i) + 1] =
+			round(point->x * scale) - round(prevPoint->x * scale);
 		prevPoint = point;
-	/* value to binary: a negative value must be calculated using its two's complement */
-	for (i=0; i<pa->npoints*2; i++)
+	/* value to binary: a negative value must be calculated using its two's
+	 * complement */
+	for (i = 0; i < pa->npoints * 2; i++)
 		/* Multiply by 2 for a signed left shift */
 		delta[i] *= 2;
@@ -99,11 +112,12 @@
 	sb = stringbuffer_create();
 		int numberToEncode = delta[i];
-		while (numberToEncode >= 0x20) {
+		while (numberToEncode >= 0x20)
 			/* Place the 5-bit chunks into reverse order or
 			 each value with 0x20 if another bit chunk follows and add 63*/
 			int nextValue = (0x20 | (numberToEncode & 0x1f)) + 63;
