[postgis-tickets] r16279 - Add release notes to docs in prep for release. Minor reword in NEWs
Regina Obe lr at pcorp.us
Fri Jan 12 09:56:33 PST 2018
Author: robe
Date: 2018-01-12 21:56:33 -0800 (Fri, 12 Jan 2018)
New Revision: 16279
   branches/2.4/NEWS
   branches/2.4/doc/release_notes.xml
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS	2018-01-12 19:17:20 UTC (rev 16278)
+++ branches/2.4/NEWS	2018-01-13 05:56:33 UTC (rev 16279)
@@ -1,5 +1,5 @@
 PostGIS 2.4.3
-2018/xx/xx
+2018/01/xx
  * Bug fixes *
   - #3713, Support encodings that happen to output a '\' character
@@ -11,8 +11,8 @@
   - #3956, Brin opclass object does not upgrade properly (Sandro Santilli)
   - #3982, ST_AsEncodedPolyline supports LINESTRING EMPTY and MULTIPOINT EMPTY
            (Darafei Praliaskouski)
-  - #3975, ST_Transform runs query on spatial_ref_sys without schema
-           qualification. May cause restore issues. (Paul Ramsey)
+  - #3975, ST_Transform runs query on spatial_ref_sys without schema
+           qualification. Was causing restore issues. (Paul Ramsey)
  * Enhancements *
   - #3944, Update to EPSG register v9.2 (Even Rouault)
Modified: branches/2.4/doc/release_notes.xml
--- branches/2.4/doc/release_notes.xml	2018-01-12 19:17:20 UTC (rev 16278)
+++ branches/2.4/doc/release_notes.xml	2018-01-13 05:56:33 UTC (rev 16279)
@@ -4,6 +4,27 @@
     <subtitle>Release Notes</subtitle>
     <sect1>
+      <title>Release 2.4.8</title>
+      <para>Release date: 2018/01/xx</para>
+      <para>This is a bug fix and performance improvement release.</para>
+      <simplesect>
+        <title>Bug Fixes and Enhancements</title>
+        <para>#3713, Support encodings that happen to output a '\' character</para>
+        <para>#3827, Set configure default to not do interrupt testing,
+                  was causing false negatives for many people</para>
+        <para>#3930, Minimum bounding circle issues on 32-bit platforms</para>
+        <para>#3965, ST_ClusterKMeans used to lose some clusters on initialization
+                  (Darafei Praliaskouski)</para>
+        <para>#3956, Brin opclass object does not upgrade properly (Sandro Santilli)</para>
+        <para>#3982, ST_AsEncodedPolyline supports LINESTRING EMPTY and MULTIPOINT EMPTY
+        <para>#3975, ST_Transform runs query on spatial_ref_sys without schema
+                  qualification. Was causing restore issues. (Paul Ramsey)</para>
+      </simplesect>
+    </sect1>
+    <sect1>
       <title>Release 2.4.2</title>
       <para>Release date: 2017/11/15</para>
