[postgis-tickets] r16295 - minor edits to HOWTO_RELEASE
Regina Obe lr at pcorp.us
Sun Jan 14 08:05:46 PST 2018
Author: robe
Date: 2018-01-14 08:05:45 -0800 (Sun, 14 Jan 2018)
New Revision: 16295
   branches/2.3/HOWTO_RELEASE
   branches/2.3/Version.config
   branches/2.3/doc/release_notes.xml
   branches/2.3/extensions/upgradeable_versions.mk
Add 2.3.5, 2.3.6dev to upgradeable_versions.mk
Update release_notes.xml to reflect impending release
Flip version to 2.3.6rc1 (in prep for rc1 tagging)
Modified: branches/2.3/HOWTO_RELEASE
--- branches/2.3/HOWTO_RELEASE	2018-01-14 15:42:00 UTC (rev 16294)
+++ branches/2.3/HOWTO_RELEASE	2018-01-14 16:05:45 UTC (rev 16295)
@@ -1,6 +1,6 @@
 How to release
-Date: 2015-10-08
+Date: 2018-01-14
 Versioning Scheme
@@ -24,7 +24,7 @@
 to work or rather *HIGHLY RECOMMENDED* to get new functionalities.
 All POSTGIS_MICRO_VERSION that are in branch or trunk should end in dev.
-So for example if you just release 2.1.1, then the 2.1 branch should have
+So for example if you just released 2.1.1, then the 2.1 branch should have
 POSTGIS_MICRO_VERSION set to 2dev so that the full version is 2.1.2dev.
 *Liblwgeom*
@@ -48,6 +48,7 @@
   - Proj4
   - GDAL (for raster)
   - json-c (for GeoJSON load support)
+  - protobuf, protobuf-c (for MVT support)
 * For the docs:
   - xsltproc
   - DocBook XSL scripts
@@ -103,7 +104,7 @@
        b) Update links on https://git.osgeo.org/gitea/postgis/postgis.net/src/master/_content/pages/source.html
        c) commit and wait 5 minutes to see changes on website
     - PostGIS doc release versioned doc - http://postgis.net/documentation/
-     Verify the documentation is up to date (might need to change the apach config)
+     Verify the documentation is up to date (might need to change the apache config)
     - Wikipedia
     - Twitter
        This should automatically happen as a result of posting to PostGIS website since Planet PostGIS autotweets.
Modified: branches/2.3/Version.config
--- branches/2.3/Version.config	2018-01-14 15:42:00 UTC (rev 16294)
+++ branches/2.3/Version.config	2018-01-14 16:05:45 UTC (rev 16295)
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=2
 POSTGIS_MINOR_VERSION=3
-POSTGIS_MICRO_VERSION=6dev
+POSTGIS_MICRO_VERSION=6rc1
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
Modified: branches/2.3/doc/release_notes.xml
--- branches/2.3/doc/release_notes.xml	2018-01-14 15:42:00 UTC (rev 16294)
+++ branches/2.3/doc/release_notes.xml	2018-01-14 16:05:45 UTC (rev 16295)
@@ -2,7 +2,26 @@
 <appendix id="release_notes">
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
+    <sect1>
+      <title>Release 2.3.6</title>
+      <para>Release date: 2018/01/17</para>
+      <para>This is a bug fix and performance improvement release.</para>
+      <simplesect>
+        <title>Bug Fixes and Enhancements</title>
+          <para>#3713, Support encodings that happen to output a '\' character</para>
+          <para>#3822, Have postgis_full_version() also show and check version of
+                  PostgreSQL the scripts were built against (Sandro Santilli)</para>
+          <para>#3965, ST_ClusterKMeans used to lose some clusters on initialization
+                  (Darafei Praliaskouski)</para>
+          <para>#3956, Brin opclass object does not upgrade properly (Sandro Santilli)</para>
+          <para>#3982, ST_AsEncodedPolyline supports LINESTRING EMPTY and MULTIPOINT EMPTY
+          <para>#3975, ST_Transform runs query on spatial_ref_sys without schema
+                  qualification. May cause restore issues. (Paul Ramsey)</para>
+      </simplesect>
+    </sect1>
     <sect1>
       <title>Release 2.3.5</title>
       <para>Release date: 2017/11/15</para>
Modified: branches/2.3/extensions/upgradeable_versions.mk
--- branches/2.3/extensions/upgradeable_versions.mk	2018-01-14 15:42:00 UTC (rev 16294)
+++ branches/2.3/extensions/upgradeable_versions.mk	2018-01-14 16:05:45 UTC (rev 16295)
@@ -28,7 +28,9 @@
 	2.3.1 \
 	2.3.2 \
 	2.3.3 \
-	2.3.4
+	2.3.4 \
+	2.3.5 \
+	2.3.6dev
 # This is to avoid forcing "check-installed-upgrades" as a default
 # rule, see https://trac.osgeo.org/postgis/ticket/3420
