[postgis-tickets] r16305 - Get rid of SVN number and revise to not build local html except for trunk
Regina Obe lr at pcorp.us
Mon Jan 15 01:38:08 PST 2018
Author: robe
Date: 2018-01-15 13:38:08 -0800 (Mon, 15 Jan 2018)
New Revision: 16305
   branches/2.4/ci/debbie/postgis_release_docs.sh
Modified: branches/2.4/ci/debbie/postgis_release_docs.sh
--- branches/2.4/ci/debbie/postgis_release_docs.sh	2018-01-15 21:24:32 UTC (rev 16304)
+++ branches/2.4/ci/debbie/postgis_release_docs.sh	2018-01-15 21:38:08 UTC (rev 16305)
@@ -2,9 +2,8 @@
 export PG_VER=9.6
 # export PGPORT=8442
 export OS_BUILD=64
-# export POSTGIS_MAJOR_VERSION=2
-# export POSTGIS_MINOR_VERSION=2
-# export POSTGIS_MICRO_VERSION=0dev
+#this is passed in via postgis_make_dist.sh via jenkins
+#export reference=
 export PROJECTS=/var/lib/jenkins/workspace
 export GEOS_VER=3.6
 export GDAL_VER=2.2
@@ -41,8 +40,8 @@
 cd doc
-mv postgis.xml postgis.xml.orig
-sed -e "s:</title>:</title><subtitle><subscript>SVN Revision (<emphasis>${POSTGIS_SVN_REVISION}</emphasis>)</subscript></subtitle>:" postgis.xml.orig > postgis.xml
+#mv postgis.xml postgis.xml.orig
+#sed -e "s:</title>:</title><subtitle><subscript>SVN Revision (<emphasis>${POSTGIS_SVN_REVISION}</emphasis>)</subscript></subtitle>:" postgis.xml.orig > postgis.xml
 make pdf
 rm -rf images
@@ -50,20 +49,25 @@
 cp html/images/* images
 make epub
 make -e chunked-html 2>&1 | tee -a doc-errors.log
-#make update-po  #we do this only for trunk because transifex only follows trunk
-make -C po/ja/ local-html
-make -C po/de/ local-html
-make -C po/pt_BR/ local-html
-make -C po/ko_KR/ local-html
+if [[ "$reference"  == *trunk* ]] ; then  #only do this for trunk because only trunk follows transifex
+	make update-po
+  make -C po/it_IT/ local-html
+  make -C po/pt_BR/ local-html
+  make -C po/ja/ local-html
+  make -C po/de/ local-html
+  make -C po/ko_KR/ local-html
+  #make pdf-localized
+fi;
 package="doc-html-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}.tar.gz"
 export outdir=html
 tar -czf "$package" --exclude='.svn' --exclude='.git' --exclude='image_src' "$outdir"
-#make update-po
-#make -C po/it_IT/ local-html
-#make -C po/pt_BR/ local-html
-#make pdf-localized
-mv postgis.xml.orig postgis.xml
+#mv postgis.xml.orig postgis.xml
 mkdir -p /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
 mkdir -p /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}/images
 cp -R html/*.*  /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
