[postgis-tickets] r16346 - Have Debbie test all available upgrades
Sandro Santilli strk at kbt.io
Sat Jan 20 04:58:39 PST 2018
Author: strk
Date: 2018-01-20 04:58:39 -0800 (Sat, 20 Jan 2018)
New Revision: 16346
   branches/2.4/ci/debbie/postgis_regress.sh
References #2676 for 2.4 branch
Modified: branches/2.4/ci/debbie/postgis_regress.sh
--- branches/2.4/ci/debbie/postgis_regress.sh	2018-01-20 09:20:44 UTC (rev 16345)
+++ branches/2.4/ci/debbie/postgis_regress.sh	2018-01-20 12:58:39 UTC (rev 16346)
@@ -67,10 +67,10 @@
 fi
 make check RUNTESTFLAGS=-v
+make install
 if [ "$MAKE_EXTENSION" = "1" ]; then
  echo "Running extension testing"
- make install
  make check RUNTESTFLAGS=--extension
  if [ "$?" != "0" ]; then
   exit $?
@@ -79,7 +79,6 @@
 if [ "$DUMP_RESTORE" = "1" ]; then
  echo "Dum restore test"
- make install
  make check RUNTESTFLAGS="-v --dumprestore"
   exit $?
@@ -89,4 +88,15 @@
 if [ "$MAKE_GARDEN" = "1" ]; then
  echo "Running garden test"
  make garden
+ if [ "$?" != "0" ]; then
+  exit $?
+ fi
 fi
+# Test all available upgrades
+# TODO: protect via some variable ?
+utils/check_all_upgrades.sh \
+  `grep '^POSTGIS_' Version.config | cut -d= -f2 | paste -sd '.'`
+if [ "$?" != "0" ]; then
+  exit $?
+fi
