[postgis-tickets] [PostGIS] #4100: garden test crash on ST_ClusterKMeans
PostGIS trac at osgeo.org
Fri Jun 1 22:34:31 PDT 2018
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 2.5.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 Testing PostGIS 2.5.0alpha on postgreSQL 10.1 windows and 11beta1
 SELECT ST_ClusterKMeans(foo1.the_geom, 3)OVER()  As result
   FROM ((SELECT ST_Collect(geom)  As the_geom
                 FROM (VALUES (
 ST_GeomFromEWKT('SRID=4326;MULTIPOLYGON(((-71.0821 42.3036 2,-71.0822
 42.3036 2,-71.082 42.3038 2,-71.0819 42.3037 2,-71.0821 42.3036 2)))') ),
         ( ST_GeomFromEWKT('SRID=4326;POLYGON((-71.1261 42.2703 1,-71.1257
 42.2703 1,-71.1257 42.2701 1,-71.126 42.2701 1,-71.1261 42.2702 1,-71.1261
 42.2703 1))') ) ) As g(geom) CROSS JOIN generate_series(1,3) As i GROUP BY
 i )) As foo1 LIMIT 10;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4100>
