[postgis-tickets] [PostGIS] #4101: garden test crash on ST_ClusterMeans on empty geometries
PostGIS trac at osgeo.org
Sat Jun 2 18:17:38 PDT 2018
  Reporter:  robe     |      Owner:  komzpa
      Type:  defect   |     Status:  assigned
  Priority:  blocker  |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> SELECT ST_ClusterKMeans(foo1.the_geom, 3)OVER()  As result
>                                                         FROM ((SELECT
> ST_GeomFromText('POINT EMPTY',4326) As the_geom
>                         UNION ALL SELECT ST_GeomFromText('MULTIPOINT
>                         UNION ALL SELECT ST_GeomFromText('MULTIPOLYGON
>                         UNION ALL SELECT ST_GeomFromText('LINESTRING
>                         UNION ALL SELECT ST_GeomFromText('MULTILINESTRING
> EMPTY',4326) As the_geom ) ) As foo1 LIMIT 10;
New description:
                                                         FROM ((SELECT
 output
 Connection to the server has been lost.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4101#comment:1>
