[postgis-tickets] r16609 - ST_PointOnSurface handling of invalid.
Darafei komzpa at gmail.com
Tue Jun 5 10:11:34 PDT 2018
Author: komzpa
Date: 2018-06-05 10:11:34 -0700 (Tue, 05 Jun 2018)
New Revision: 16609
   trunk/NEWS
   trunk/liblwgeom/liblwgeom.h.in
   trunk/liblwgeom/lwgeom_geos.c
   trunk/postgis/lwgeom_geos.c
   trunk/regress/tickets.sql
   trunk/regress/tickets_expected
Prints a loud notice and passes input through MakeValid.
Closes #4103
Closes https://github.com/postgis/postgis/pull/257
Modified: trunk/NEWS
--- trunk/NEWS	2018-06-05 14:40:45 UTC (rev 16608)
+++ trunk/NEWS	2018-06-05 17:11:34 UTC (rev 16609)
@@ -77,6 +77,7 @@
   - #4084: Fixed wrong code-comment regarding front/back of BOX3D (Matthias Bay)
   - #4060, #4094, PostgreSQL JIT support (Raúl Marín, Laurenz Albe)
   - #3960, ST_Centroid now uses lwgeom_centroid (Darafei Praliaskouski)
+  - #4103, ST_PointOnSurface can handle invalid (Darafei Praliaskouski)
 PostGIS 2.4.4
 2018/04/08
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in	2018-06-05 14:40:45 UTC (rev 16608)
+++ trunk/liblwgeom/liblwgeom.h.in	2018-06-05 17:11:34 UTC (rev 16609)
@@ -2275,6 +2275,7 @@
 LWGEOM *lwgeom_intersection(const LWGEOM *geom1, const LWGEOM *geom2);
 LWGEOM *lwgeom_difference(const LWGEOM *geom1, const LWGEOM *geom2);
 LWGEOM *lwgeom_symdifference(const LWGEOM* geom1, const LWGEOM* geom2);
+LWGEOM *lwgeom_pointonsurface(const LWGEOM* geom);
 LWGEOM *lwgeom_centroid(const LWGEOM* geom);
 LWGEOM *lwgeom_union(const LWGEOM *geom1, const LWGEOM *geom2);
 LWGEOM *lwgeom_linemerge(const LWGEOM *geom1);
Modified: trunk/liblwgeom/lwgeom_geos.c
--- trunk/liblwgeom/lwgeom_geos.c	2018-06-05 14:40:45 UTC (rev 16608)
+++ trunk/liblwgeom/lwgeom_geos.c	2018-06-05 17:11:34 UTC (rev 16609)
@@ -543,7 +543,7 @@
 	return LW_TRUE;
-/* Output encoder and sanity checker for GEOS wrappers */
+/* Clean up and return NULL */
 inline static LWGEOM*
 geos_clean_and_fail(GEOSGeometry* g1, GEOSGeometry* g2, GEOSGeometry* g3, const char* funcname)
@@ -554,7 +554,7 @@
 	return NULL;
+/* Clean up */
 inline static void
 geos_clean(GEOSGeometry* g1, GEOSGeometry* g2, GEOSGeometry* g3)
@@ -829,6 +829,55 @@
 	return result;
+LWGEOM *
+lwgeom_pointonsurface(const LWGEOM *geom)
+	LWGEOM *result;
+	int32_t srid = get_result_srid(geom, NULL, __func__);
+	uint8_t is3d = FLAGS_GET_Z(geom->flags);
+	GEOSGeometry *g1, *g3;
+	if (srid == SRID_INVALID) return NULL;
+	if (lwgeom_is_empty(geom))
+		LWPOINT *lwp = lwpoint_construct_empty(srid, is3d, lwgeom_has_m(geom));
+		return lwpoint_as_lwgeom(lwp);
+	initGEOS(lwnotice, lwgeom_geos_error);
+	if (!input_lwgeom_to_geos(&g1, geom, __func__)) return NULL;
+	g3 = GEOSPointOnSurface(g1);
+	if (!g3)
+		GEOSGeometry *g1v;
+		lwnotice("%s: GEOS Error: %s", __func__, lwgeom_geos_errmsg);
+		if (!GEOSisValid(g1))
+			lwnotice(
+			    "Your geometry dataset is not valid per OGC Specification. "
+			    "Please fix it with manual review of entries that are not ST_IsValid(geom). "
+			    "Retrying GEOS operation with ST_MakeValid of your input.");
+			g1v = LWGEOM_GEOS_makeValid(g1);
+			g3 = GEOSPointOnSurface(g1v);
+			geos_clean(g1v, NULL, NULL);
+	if (!g3) return geos_clean_and_fail(g1, NULL, NULL, __func__);
+	if (!output_geos_as_lwgeom(&g3, &result, srid, is3d, __func__))
+		return geos_clean_and_fail(g1, NULL, g3, __func__);
+	geos_clean(g1, NULL, g3);
+	return result;
 LWGEOM*
 lwgeom_union(const LWGEOM* geom1, const LWGEOM* geom2)
Modified: trunk/postgis/lwgeom_geos.c
--- trunk/postgis/lwgeom_geos.c	2018-06-05 14:40:45 UTC (rev 16608)
+++ trunk/postgis/lwgeom_geos.c	2018-06-05 17:11:34 UTC (rev 16609)
@@ -1250,55 +1250,20 @@
 PG_FUNCTION_INFO_V1(pointonsurface);
 Datum pointonsurface(PG_FUNCTION_ARGS)
-	GSERIALIZED *geom;
-	GEOSGeometry *g1, *g3;
-	GSERIALIZED *result;
+	GSERIALIZED *geom, *result;
+	LWGEOM *lwgeom, *lwresult;
 	geom = PG_GETARG_GSERIALIZED_P(0);
-	/* Empty.PointOnSurface == Point Empty */
-	if ( gserialized_is_empty(geom) )
-		LWPOINT *lwp = lwpoint_construct_empty(
-		                   gserialized_get_srid(geom),
-		                   gserialized_has_z(geom),
-		                   gserialized_has_m(geom));
-		result = geometry_serialize(lwpoint_as_lwgeom(lwp));
-		lwpoint_free(lwp);
-		PG_RETURN_POINTER(result);
+	lwgeom = lwgeom_from_gserialized(geom);
+	lwresult = lwgeom_pointonsurface(lwgeom);
+	lwgeom_free(lwgeom);
+	PG_FREE_IF_COPY(geom, 0);
-	initGEOS(lwpgnotice, lwgeom_geos_error);
+	if (!lwresult) PG_RETURN_NULL();
-	g1 = POSTGIS2GEOS(geom);
-	if (!g1) HANDLE_GEOS_ERROR(__func__);
-	g3 = GEOSPointOnSurface(g1);
-	if (!g3)
-		GEOSGeom_destroy(g1);
-		HANDLE_GEOS_ERROR("GEOSPointOnSurface");
-	GEOSSetSRID(g3, gserialized_get_srid(geom));
-	result = GEOS2POSTGIS(g3, gserialized_has_z(geom));
-	if (!result)
-		GEOSGeom_destroy(g3);
-		elog(ERROR,"GEOS pointonsurface() threw an error (result postgis geometry formation)!");
-		PG_RETURN_NULL(); /* never get here */
-	PG_FREE_IF_COPY(geom, 0);
+	result = geometry_serialize(lwresult);
+	lwgeom_free(lwresult);
Modified: trunk/regress/tickets.sql
--- trunk/regress/tickets.sql	2018-06-05 14:40:45 UTC (rev 16608)
+++ trunk/regress/tickets.sql	2018-06-05 17:11:34 UTC (rev 16609)
@@ -1088,5 +1088,8 @@
 --#4089
 select '#4089', st_astext(st_geomfromtwkb(st_AsTWKB(st_GeometryFromText('LINESTRING Z(1 1 1, 3 3 1)'), 1, 0, 0, false, true)));
+select '#4103', ST_Intersects(ST_PointOnSurface(geom), geom)
+from (select '0103000020110F0000010000000A000000000000C41E644741000000EEA2A75A41000000F420644741000000629EA75A410000007A2D644741000000E49FA75A41000000C02E644741000000409DA75A41000000286A64474100000064A4A75A410000007867644741000000FAA9A75A41000000E82B644741000000D2A2A75A41000000222D64474100000046A0A75A41000000242B6447410000006CA4A75A41000000C41E644741000000EEA2A75A41'::geometry geom) z;
 -- Clean up
 DELETE FROM spatial_ref_sys;
Modified: trunk/regress/tickets_expected
--- trunk/regress/tickets_expected	2018-06-05 14:40:45 UTC (rev 16608)
+++ trunk/regress/tickets_expected	2018-06-05 17:11:34 UTC (rev 16609)
@@ -349,3 +349,8 @@
 #4055a|4326
 #4055b|4326
 #4089|LINESTRING Z (1 1 1,3 3 1)
+NOTICE:  lwgeom_pointonsurface: GEOS Error: TopologyException: Input geom 1 is invalid: Self-intersection
+NOTICE:  Self-intersection
+NOTICE:  Your geometry dataset is not valid per OGC Specification. Please fix it with manual review of entries that are not ST_IsValid(geom). Retrying GEOS operation with ST_MakeValid of your input.
+#4103|t
