[postgis-tickets] r16611 - Remove erroneous commutator definitions for over(left/right/above/below)
Paul Ramsey pramsey at cleverelephant.ca
Wed Jun 6 11:01:15 PDT 2018
Author: pramsey
Date: 2018-06-06 11:01:15 -0700 (Wed, 06 Jun 2018)
New Revision: 16611
   trunk/postgis/postgis.sql.in
operators. Closes #4088
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in	2018-06-06 09:29:33 UTC (rev 16610)
+++ trunk/postgis/postgis.sql.in	2018-06-06 18:01:15 UTC (rev 16611)
@@ -651,7 +651,6 @@
 -- Availability: 0.1.0
 CREATE OPERATOR &< (
 	LEFTARG = geometry, RIGHTARG = geometry, PROCEDURE = geometry_overleft,
-	COMMUTATOR = '&>',
 	RESTRICT = positionsel, JOIN = positionjoinsel
@@ -677,7 +676,6 @@
 CREATE OPERATOR &<| (
 	LEFTARG = geometry, RIGHTARG = geometry, PROCEDURE = geometry_overbelow,
-	COMMUTATOR = '|&>',
@@ -690,7 +688,6 @@
 CREATE OPERATOR &> (
 	LEFTARG = geometry, RIGHTARG = geometry, PROCEDURE = geometry_overright,
-	COMMUTATOR = '&<',
@@ -716,7 +713,6 @@
 CREATE OPERATOR |&> (
 	LEFTARG = geometry, RIGHTARG = geometry, PROCEDURE = geometry_overabove,
-	COMMUTATOR = '&<|',
