[postgis-tickets] [PostGIS] #4104: PostGIS 2.4.4 rt_gdalwrap test fails with GDAL 2.3.0 & PROJ 5.1.0 on Debian unstable
PostGIS trac at osgeo.org
Sat Jun 9 08:29:54 PDT 2018
unstable
 Reporter:  Bas Couwenberg  |      Owner:  pramsey
     Type:  defect          |     Status:  new
 Priority:  medium          |  Milestone:  PostGIS 2.4.5
Component:  postgis         |    Version:  2.4.x
 Keywords:                  |
 As reported by Niko Tyni in [https://bugs.debian.org/901158 Debian Bug
 #901158]:
 > This package fails to build from source on current sid/amd64.
 >  ### /tmp/pgis_reg/test_50_diff ###
 > --- rt_gdalwarp_expected      2018-04-06 05:05:52.000000000 +0000
 > +++ /tmp/pgis_reg/test_50_out 2018-06-09 14:27:15.049036062 +0000
 > @@ -19,8 +19,8 @@
 0.17|993309|243|243|1|50.000|50.000|0.000|0.000|950760.000|1396957.000|t|t|t
 0.18|992163|10|10|1|1000.000|-1000.000|3.000|3.000|-500030.000|600000.000|t|t|t
 0.19|993310|12|12|1|1009.894|-1009.894|3.000|3.000|950691.792|1409281.783|t|t|t
 -0.2|993309|12|12|1|1009.916|-1009.916|0.000|0.000|950762.305|1409088.896|t|t|t
 -0.20|993309|12|12|1|1009.916|-1009.916|1.000|3.000|950742.107|1409088.896|t|t|t
 +0.2|993309|12|12|1|1009.876|-1009.876|0.000|0.000|950808.447|1409091.640|t|t|t
 +0.20|993309|12|12|1|1009.876|-1009.876|1.000|3.000|950788.250|1409091.640|t|t|t
 0.21|993310|24|24|1|500.000|500.000|3.000|3.000|950657.188|1397356.783|t|t|t
 0.22|993310|26|26|1|500.000|500.000|0.000|6.000|950452.000|1396632.000|t|t|t
 >  0.23|984269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
 > @@ -63,12 +63,12 @@
 1.9|992163|11|10|1|1000.000|-1000.000|0.000|0.000|-500001.000|600000.000|t|t|t
 2.1|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 2.10|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 -2.11|993309|121|121|1|100.000|100.000|0.000|0.000|950762.305|1396988.896|t|t|t
 +2.11|993309|121|121|1|100.000|100.000|0.000|0.000|950808.447|1396991.640|t|t|t
 2.12|993310|6|6|1|2000.000|2000.000|0.000|0.000|950732.188|1397281.783|t|t|t
 2.13|993310|8|8|1|1500.000|1500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 2.14|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 2.15|993310|16|16|1|750.000|750.000|0.000|0.000|950732.188|1397281.783|t|t|t
 -2.2|993309|12|12|1|1009.916|-1009.916|0.000|0.000|950762.305|1409088.896|t|t|t
 +2.2|993309|12|12|1|1009.876|-1009.876|0.000|0.000|950808.447|1409091.640|t|t|t
 >  2.3|994269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
 >  2.4|||||||||||||
 2.5|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 >  ### end of log dumps ###
 > make[1]: *** [debian/rules:200: override_dh_auto_test] Error 2
 > make[1]: Leaving directory '/<<BUILDDIR>>/postgis-2.4.4+dfsg'
 > make: *** [debian/rules:111: build] Error 2
 > Full build log attached.
 [https://bugs.debian.org/cgi-
 bin/bugreport.cgi?att=1;bug=901158;filename=postgis_amd64-2018-06-09T14%3A19%3A48Z.build.gz;msg=5
 postgis_amd64-2018-06-09T14:19:48Z.build.gz]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4104>
