[postgis-tickets] r16616 - MVT tests: Remove ST_Normalize calls
Raul raul at rmr.ninja
Wed Jun 13 07:19:49 PDT 2018
Author: algunenano
Date: 2018-06-13 07:19:49 -0700 (Wed, 13 Jun 2018)
New Revision: 16616
   trunk/regress/mvt.sql
   trunk/regress/mvt_expected
References #4106
Modified: trunk/regress/mvt.sql
--- trunk/regress/mvt.sql	2018-06-13 14:16:16 UTC (rev 16615)
+++ trunk/regress/mvt.sql	2018-06-13 14:19:49 UTC (rev 16616)
@@ -1,164 +1,259 @@
 -- geometry preprocessing tests
-select 'PG1', ST_AsText(ST_Normalize(ST_AsMVTGeom(
+select 'PG1', ST_AsText(ST_AsMVTGeom(
 	ST_Point(1, 2),
 	ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)),
-	4096, 0, false)));
-select 'PG2', ST_AsText(ST_Normalize(ST_AsMVTGeom(
+	4096, 0, false));
+select 'PG2', ST_AsText(ST_AsMVTGeom(
 	ST_Point(1, 2),
 	ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096*2, 4096*2)),
-select 'PG3', ST_AsText(ST_Normalize(ST_AsMVTGeom(
+	4096, 0, false));
+select 'PG3', ST_AsText(ST_AsMVTGeom(
 	ST_Point(1, 2),
 	ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096/2, 4096/2)),
-select 'PG4', ST_AsText(ST_Normalize(ST_AsMVTGeom(
+	4096, 0, false));
+select 'PG4', ST_AsText(ST_AsMVTGeom(
 	ST_GeomFromText('POLYGON ((0 0, 10 0, 10 5, 0 -5, 0 0))'),
-select 'PG5', ST_AsText(ST_Normalize(ST_AsMVTGeom(
+	4096, 0, false));
+select 'PG5', ST_AsText(ST_AsMVTGeom(
 	ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096*4096, 4096*4096)),
-select 'PG6', ST_AsText(ST_Normalize(ST_AsMVTGeom(
+	4096, 0, false));
+select 'PG6', ST_AsText(ST_AsMVTGeom(
 	ST_GeomFromText('POLYGON ((762780 6474467, 717821 6797045, 1052826 6797045, 762780 6474467))'),
 	ST_MakeBox2D(ST_Point(626172.135625, 6261721.35625), ST_Point(1252344.27125, 6887893.49188)),
-select 'PG7', ST_AsText(ST_Normalize(ST_AsMVTGeom(
-    ST_GeomFromText('POLYGON((-7792023.4539488 1411512.60791779,-7785283.40665468 1406282.69482469,-7783978.88137195 1404858.20373788,-7782986.89858399 1402324.91434802,-7779028.02672366 1397370.31802772,
-        -7778652.06985644 1394387.75452545,-7779906.76953697 1393279.22658385,-7782212.33678782 1393293.14086794,-7784631.14401331 1394225.4151684,-7786257.27108231 1395867.40241344,-7783978.88137195 1395867.40241344,
-        -7783978.88137195 1396646.68250521,-7787752.03959369 1398469.72134299,-7795443.30325373 1405280.43988858,-7797717.16326269 1406217.73286975,-7798831.44531677 1406904.48130551,-7799311.5830898 1408004.24038921,
-        -7799085.10302919 1409159.72782477,-7798052.35381919 1411108.84582812,-7797789.63692662 1412213.40365339,-7798224.47868753 1414069.89725829,-7799003.5701851 1415694.42577482,-7799166.63587328 1416966.26267896,
-        -7797789.63692662 1417736.81850415,-7793160.38395328 1412417.61222784,-7792023.4539488 1411512.60791779))'),
-        ST_MakeBox2D(ST_Point(-20037508.34, -20037508.34), ST_Point(20037508.34, 20037508.34)),
-        4096, 10, true)));
-select 'PG8', ST_AsText(ST_Normalize(ST_AsMVTGeom(
-    ST_GeomFromText('GEOMETRYCOLLECTION(MULTIPOLYGON (((0 0, 10 0, 10 5, 0 -5, 0 0))))'),
-    ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)),
-select 'PG9', ST_AsText(ST_Normalize(ST_AsMVTGeom(
+	4096, 0, false));
+select 'PG7', ST_AsText(ST_AsMVTGeom(
+	ST_GeomFromText('POLYGON((-7792023.4539488 1411512.60791779,-7785283.40665468 1406282.69482469,-7783978.88137195 1404858.20373788,-7782986.89858399 1402324.91434802,-7779028.02672366 1397370.31802772,
+	-7778652.06985644 1394387.75452545,-7779906.76953697 1393279.22658385,-7782212.33678782 1393293.14086794,-7784631.14401331 1394225.4151684,-7786257.27108231 1395867.40241344,-7783978.88137195 1395867.40241344,
+	-7783978.88137195 1396646.68250521,-7787752.03959369 1398469.72134299,-7795443.30325373 1405280.43988858,-7797717.16326269 1406217.73286975,-7798831.44531677 1406904.48130551,-7799311.5830898 1408004.24038921,
+	-7799085.10302919 1409159.72782477,-7798052.35381919 1411108.84582812,-7797789.63692662 1412213.40365339,-7798224.47868753 1414069.89725829,-7799003.5701851 1415694.42577482,-7799166.63587328 1416966.26267896,
+	-7797789.63692662 1417736.81850415,-7793160.38395328 1412417.61222784,-7792023.4539488 1411512.60791779))'),
+	ST_MakeBox2D(ST_Point(-20037508.34, -20037508.34), ST_Point(20037508.34, 20037508.34)),
+	4096, 10, true));
+select 'PG8', ST_AsText(ST_AsMVTGeom(
+	ST_GeomFromText('GEOMETRYCOLLECTION(MULTIPOLYGON (((0 0, 10 0, 10 5, 0 -5, 0 0))))'),
+	ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)),
+	4096, 0, false));
+select 'PG9', ST_AsText(ST_AsMVTGeom(
 	ST_GeomFromText('POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0))'),
 	ST_MakeBox2D(ST_Point(0, 0), ST_Point(5, 5)),
-	4096, 0, true)));
+	4096, 0, true));
 SELECT 'PG10', ST_AsText(ST_AsMVTGeom(
 	'POINT EMPTY'::geometry,
 	'BOX(0 0,2 2)'::box2d));
+-- Clockwise Polygon
+SELECT 'PG11', ST_AsText(ST_AsMVTGeom(
+	ST_GeomFromText('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))'),
+	ST_MakeBox2D(ST_Point(0, 0), ST_Point(10, 10)),
+	10, 0, false));
+-- Same as PG11 but CCW
+SELECT 'PG12', ST_AsText(ST_AsMVTGeom(
+	ST_GeomFromText('POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))'),
+	10, 0, false));
+--- POLYGONS WITH INTERIOR RINGS
+-- Input: Exterior CW, interior CW
+-- Output: CW, CCW
+SELECT 'PG13', ST_AsText(ST_AsMVTGeom(
+	ST_GeomFromText('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0), (1 1, 1 9, 9 9, 9 1, 1 1))'),
+	10, 0, false));
+-- Input: Exterior CW, interior CCW
+-- Output: CW, CCW
+SELECT 'PG14', ST_AsText(ST_AsMVTGeom(
+	ST_GeomFromText('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0), (1 1, 9 1, 9 9, 1 9, 1 1))'),
+	10, 0, false));
+-- Input: Exterior CCW, interior CW
+-- Output: CW, CCW
+SELECT 'PG15', ST_AsText(ST_AsMVTGeom(
+	ST_GeomFromText('POLYGON((0 0, 10 0, 10 10, 0 10, 0 0), (1 1, 1 9, 9 9, 9 1, 1 1))'),
+	10, 0, false));
+-- Output: CW, CCW
+SELECT 'PG16', ST_AsText(ST_AsMVTGeom(
+	10, 0, false));
+-- Input: CW, CW, CW, CW
+-- Output: CW, CCW, CW, CCW
+SELECT 'PG17', ST_AsText(ST_AsMVTGeom(
+		(0 0, 0 10, 10 10, 10 0, 0 0),
+		(1 1, 1  9,  9  9,  9 1, 1 1),
+		(2 2, 2  8,  8  8,  8 2, 2 2),
+		(3 3, 3  7,  7  7,  7 3, 3 3))'),
+	10, 0, false));
+-- Multipoint
+SELECT 'PG18', ST_AsText(ST_AsMVTGeom(
+	ST_GeomFromText('MULTIPOINT(1 1, 3 2)'),
+	10, 0, false));
+SELECT 'PG19', ST_AsText(ST_AsMVTGeom(
+	ST_GeomFromText('MULTIPOINT(25 17, 26 18)'),
+	4096, 0, false));
+SELECT 'PG20', ST_AsText(ST_AsMVTGeom(
+	ST_GeomFromText('MULTIPOINT(10 10, 10 10)'),
+	4096, 0, false));
+-- Linestring
+SELECT 'PG21', ST_AsText(ST_AsMVTGeom(
+	ST_GeomFromText('LINESTRING(1 1, 5 5)'),
+	10, 0, false));
+SELECT 'PG22', ST_AsText(ST_AsMVTGeom(
+	ST_GeomFromText('LINESTRING(1 9, 1.01 9.01)'),
+	10, 0, false));
+-- Multiline
+SELECT 'PG23', ST_AsText(ST_AsMVTGeom(
+	ST_GeomFromText('MULTILINESTRING((1 1, 5 5),(2 8, 5 5))'),
+	10, 0, false));
+SELECT 'PG24', ST_AsText(ST_AsMVTGeom(
+	ST_GeomFromText('MULTILINESTRING((1 1, 5 5),(1 1, 5 5))'),
+	10, 0, false));
+SELECT 'PG25', ST_AsText(ST_AsMVTGeom(
+	ST_GeomFromText('MULTILINESTRING((1 1, 501 501, 1001 1001),(2 2, 502 502, 1002 1002))'),
+	4096, 0, false));
 -- geometry encoding tests
 SELECT 'TG1', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1,
-    ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
-    ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)), 4096, 0, false)) AS geom) AS q;
+	ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
+		ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)), 4096, 0, false) AS geom) AS q;
 SELECT 'TG2', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1,
-    ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('MULTIPOINT(25 17, 26 18)'),
+	ST_AsMVTGeom(ST_GeomFromText('MULTIPOINT(25 17, 26 18)'),
 SELECT 'TG3', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1,
-    ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('LINESTRING(0 0, 1000 1000)'),
+	ST_AsMVTGeom(ST_GeomFromText('LINESTRING(0 0, 1000 1000)'),
 SELECT 'TG4', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1,
-    ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('LINESTRING(0 0, 500 500, 1000 1000)'),
+	ST_AsMVTGeom(ST_GeomFromText('LINESTRING(0 0, 500 500, 1000 1000)'),
 SELECT 'TG5', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1,
-    ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('MULTILINESTRING((1 1, 501 501, 1001 1001),(2 2, 502 502, 1002 1002))'),
+	ST_AsMVTGeom(ST_GeomFromText('MULTILINESTRING((1 1, 501 501, 1001 1001),(2 2, 502 502, 1002 1002))'),
 SELECT 'TG6', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1,
-    ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POLYGON ((35 10, 45 45, 15 40, 10 20, 35 10), (20 30, 35 35, 30 20, 20 30))'),
+	ST_AsMVTGeom(ST_GeomFromText('POLYGON ((35 10, 45 45, 15 40, 10 20, 35 10), (20 30, 35 35, 30 20, 20 30))'),
 SELECT 'TG7', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1,
-    ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('MULTIPOLYGON (((40 40, 20 45, 45 30, 40 40)), ((20 35, 10 30, 10 10, 30 5, 45 20, 20 35), (30 20, 20 15, 20 25, 30 20)))'),
+	ST_AsMVTGeom(ST_GeomFromText('MULTIPOLYGON (((40 40, 20 45, 45 30, 40 40)), ((20 35, 10 30, 10 10, 30 5, 45 20, 20 35), (30 20, 20 15, 20 25, 30 20)))'),
 SELECT 'TG8', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1,
 SELECT 'TG9', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1,
-    ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('MULTIPOINT(25 17, -26 -18)'),
+	ST_AsMVTGeom(ST_GeomFromText('MULTIPOINT(25 17, -26 -18)'),
 -- attribute encoding tests
 SELECT 'TA1', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1, 'abcd'::text AS c2,
 SELECT 'TA2', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1.1::double precision AS c1,
 SELECT 'TA3', encode(ST_AsMVT(q, 'test',  4096, 'geom'), 'base64') FROM (SELECT NULL::integer AS c1,
 SELECT 'TA4', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (
-    SELECT 1 AS c1, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
-    UNION
-    SELECT 2 AS c1, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
-    ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)), 4096, 0, false)) AS geom ORDER BY c1) AS q;
+	SELECT 1 AS c1, ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
+	UNION
+	SELECT 2 AS c1, ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
+		ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)), 4096, 0, false) AS geom ORDER BY c1) AS q;
 SELECT 'TA5', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT
-    ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)), 4096, 0, false)) AS geom, 1 AS c1, 'abcd'::text AS c2) AS q;
+		ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)), 4096, 0, false) AS geom, 1 AS c1, 'abcd'::text AS c2) AS q;
 SELECT 'TA6', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1, -1 AS c2,
 SELECT 'TA7', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (
-    SELECT 'test' AS c1, 1 AS c2, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
-    UNION
-    SELECT 'test' AS c1, 2 AS c2, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(26 18)'),
-    UNION
-    SELECT 'othertest' AS c1, 3 AS c2, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(26 18)'),
-    ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)), 4096, 0, false)) AS geom ORDER BY c2) AS q;
+	SELECT 'test' AS c1, 1 AS c2, ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
+	UNION
+	SELECT 'test' AS c1, 2 AS c2, ST_AsMVTGeom(ST_GeomFromText('POINT(26 18)'),
+	UNION
+	SELECT 'othertest' AS c1, 3 AS c2, ST_AsMVTGeom(ST_GeomFromText('POINT(26 18)'),
+		ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)), 4096, 0, false) AS geom ORDER BY c2) AS q;
 SELECT 'TA8', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (
-    SELECT 1::int AS c1, 1 AS c2, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
-    UNION
-    SELECT 1::int AS c1, 2 AS c2, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(26 18)'),
-    UNION
-    SELECT 2::int AS c1, 3 AS c2, ST_Normalize(ST_AsMVTGeom(ST_GeomFromText('POINT(26 18)'),
+	SELECT 1::int AS c1, 1 AS c2, ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
+	UNION
+	SELECT 1::int AS c1, 2 AS c2, ST_AsMVTGeom(ST_GeomFromText('POINT(26 18)'),
+	UNION
+	SELECT 2::int AS c1, 3 AS c2, ST_AsMVTGeom(ST_GeomFromText('POINT(26 18)'),
 SELECT 'TA9', length(ST_AsMVT(q))
 FROM (
+	ST_AsMVTGeom(
 		'POINT(25 17)'::geometry,
 		ST_MakeBox2D(ST_Point(0, 0), ST_Point(4, 4))
-	)) AS geom
+	) AS geom
 ) AS q;
 SELECT 'TA10', length(ST_AsMVT(q))
 FROM (
+	ST_AsMVTGeom(
 		ST_MakeBox2D(ST_Point(0, 0), ST_Point(48, 48))
-	)) AS geom
+	) AS geom
 ) AS q;
 -- default values tests
 SELECT 'D1', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1, 'abcd'::text AS c2,
 SELECT 'D2', encode(ST_AsMVT(q, 'test', 4096), 'base64') FROM (SELECT 1 AS c1, 'abcd'::text AS c2,
 SELECT 'D3', encode(ST_AsMVT(q, 'test'), 'base64') FROM (SELECT 1 AS c1, 'abcd'::text AS c2,
 SELECT 'D4', encode(ST_AsMVT(q), 'base64') FROM (SELECT 1 AS c1, 'abcd'::text AS c2,
-select 'D5', ST_AsText(ST_Normalize(ST_AsMVTGeom(
+select 'D5', ST_AsText(ST_AsMVTGeom(
 	ST_Point(1, 2),
-	4096, 0)));
-select 'D6', ST_AsText(ST_Normalize(ST_AsMVTGeom(
+	4096, 0));
+select 'D6', ST_AsText(ST_AsMVTGeom(
 	ST_Point(1, 2),
-	4096)));
-select 'D7', ST_AsText(ST_Normalize(ST_AsMVTGeom(
+	4096));
+select 'D7', ST_AsText(ST_AsMVTGeom(
 	ST_Point(1, 2),
-	ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)))));
+	ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096))));
 -- unsupported input
 SELECT 'TU2';
 SELECT encode(ST_AsMVT(1, 'test', 4096, 'geom'), 'base64');
 SELECT 'TU3', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64')
-    FROM (SELECT NULL::integer AS c1, NULL AS geom) AS q;
+	FROM (SELECT NULL::integer AS c1, NULL AS geom) AS q;
 -- Ticket #3922
 SELECT '#3922', length(bytea(ST_AsMVTGeom(
Modified: trunk/regress/mvt_expected
--- trunk/regress/mvt_expected	2018-06-13 14:16:16 UTC (rev 16615)
+++ trunk/regress/mvt_expected	2018-06-13 14:19:49 UTC (rev 16616)
@@ -1,20 +1,35 @@
 PG1|POINT(1 4094)
 PG2|POINT(0 4095)
 PG3|POINT(2 4092)
-PG4|MULTIPOLYGON(((5 4096,10 4096,10 4091,5 4096)),((0 4096,0 4101,5 4096,0 4096)))
+PG4|MULTIPOLYGON(((5 4096,10 4091,10 4096,5 4096)),((5 4096,0 4101,0 4096,5 4096)))
 PG5|
-PG6|POLYGON((600 594,894 2704,2791 594,600 594))
-PG7|POLYGON((1251 1904,1253 1906,1253 1905,1252 1904,1251 1904))
-PG8|MULTIPOLYGON(((5 4096,10 4096,10 4091,5 4096)),((0 4096,0 4101,5 4096,0 4096)))
-PG9|POLYGON((0 0,0 4096,4096 4096,4096 0,0 0))
+PG6|POLYGON((894 2704,600 594,2791 594,894 2704))
+PG7|POLYGON((1252 1904,1253 1905,1253 1906,1251 1904,1252 1904))
+PG8|MULTIPOLYGON(((5 4096,10 4091,10 4096,5 4096)),((5 4096,0 4101,0 4096,5 4096)))
+PG9|POLYGON((4096 4096,0 4096,0 0,4096 0,4096 4096))
 PG10|
+PG11|POLYGON((0 10,0 0,10 0,10 10,0 10))
+PG12|POLYGON((0 10,0 0,10 0,10 10,0 10))
+PG13|POLYGON((0 10,0 0,10 0,10 10,0 10),(1 9,9 9,9 1,1 1,1 9))
+PG14|POLYGON((0 10,0 0,10 0,10 10,0 10),(1 9,9 9,9 1,1 1,1 9))
+PG15|POLYGON((0 10,0 0,10 0,10 10,0 10),(1 9,9 9,9 1,1 1,1 9))
+PG16|POLYGON((0 10,0 0,10 0,10 10,0 10),(1 9,9 9,9 1,1 1,1 9))
+PG17|MULTIPOLYGON(((0 10,0 0,10 0,10 10,0 10),(1 9,9 9,9 1,1 1,1 9)),((2 8,2 2,8 2,8 8,2 8),(3 7,7 7,7 3,3 3,3 7)))
+PG18|MULTIPOINT(1 9,3 8)
+PG19|MULTIPOINT(25 4079,26 4078)
+PG20|MULTIPOINT(10 4086)
+PG21|LINESTRING(1 9,5 5)
+PG22|
+PG23|MULTILINESTRING((1 9,5 5),(2 2,5 5))
+PG24|MULTILINESTRING((1 9,5 5),(1 9,5 5))
+PG25|MULTILINESTRING((1 4095,1001 3095),(2 4094,1002 3094))
 TG1|GiEKBHRlc3QSDBICAAAYASIECTLePxoCYzEiAigBKIAgeAI=
-TG2|GiMKBHRlc3QSDhICAAAYASIGETTcPwECGgJjMSICKAEogCB4Ag==
+TG2|GiMKBHRlc3QSDhICAAAYASIGETLePwIBGgJjMSICKAEogCB4Ag==
 TG3|GiYKBHRlc3QSERICAAAYAiIJCQCAQArQD88PGgJjMSICKAEogCB4Ag==
 TG4|GiYKBHRlc3QSERICAAAYAiIJCQCAQArQD88PGgJjMSICKAEogCB4Ag==
-TG5|GjAKBHRlc3QSGxICAAAYAiITCQT8PwrQD88PCdEP0g8K0A/PDxoCYzEiAigBKIAgeAI=
-TG6|GjIKBHRlc3QSHRICAAAYAyIVCRTYPxoyFBRFOwoPCQoUEh4JCR4PGgJjMSICKAEogCB4Ag==
-TG7|Gj0KBHRlc3QSKBICAAAYAyIgCRTEPyIAKCgKHh0xHQ8JABQSFAoTCg8JADsSMh4JEw8aAmMxIgIo
+TG5|GjAKBHRlc3QSGxICAAAYAiITCQL+PwrQD88PCc0Pzg8K0A/PDxoCYzEiAigBKIAgeAI=
+TG6|GjIKBHRlc3QSHRICAAAYAyIVCUbsPxoxEwonPAkPCTEeEhQUCh0PGgJjMSICKAEogCB4Ag==
+TG7|Gj0KBHRlc3QSKBICAAAYAyIgCVCwPxIKFDEdDwkAFCIyHh0eJwkAJw8JKBQSEwkAFA8aAmMxIgIo
 ASiAIHgC
 TG8|GiEKBHRlc3QSDBICAAAYASIECTLePxoCYzEiAigBKIAgeAI=
 TG9|GiMKBHRlc3QSDhICAAAYASIGETLeP2VGGgJjMSICKAEogCB4Ag==
