[postgis-tickets] [PostGIS] #4111: debbie failing on PostgreSQL 10 run on topology
PostGIS trac at osgeo.org
Tue Jun 26 13:19:31 PDT 2018
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 2.5.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 Debbie started failing a day or so ago on her PostgreSQL 10 run.
 I suspect it may be a change upstream because her 11 is fine and Bessie
 64-bit 10 is also fine.
 She follows 10 branch, so they may have accidentally introduced a breaking
 change:
  regress/topoelementarray_agg .. ok
  regress/topogeo_addlinestring .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_5_pg10w64/test_29_diff)
 --- regress/topogeo_addlinestring_expected      2017-12-27
 17:51:25.767418144 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/2_5_pg10w64/test_29_out
 2018-06-26 18:41:30.907981957 +0000
 @@ -185,8 +185,7 @@
  t3280.start|t
  t3280|L11
  t3280|L22
 -t3280|L1b4
 -t3280|L1b2
 +ERROR:  ORDER/GROUP BY expression not found in targetlist
  t3280.end|Topology 'bug3280' dropped
  t3380.start|t
  t3380.L1|1
  regress/topogeo_addpoint .. ok
  regress/topogeo_addpolygon .. ok
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4111>
