[postgis-tickets] [PostGIS] #4111: debbie failing on PostgreSQL 10 run on topology
PostGIS trac at osgeo.org
Tue Jun 26 13:25:58 PDT 2018
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS PostgreSQL
 Component:  buildbots  |    Version:  trunk
Resolution:             |   Keywords:
Changes (by robe):
 * milestone:  PostGIS 2.5.0 => PostGIS PostgreSQL
Comment:
 Seems to have started failing after this commit:
     Add PGTYPESchar_free() to avoid cross-module problems on Windows.
 (details)
 Commit 3566873f21909397561418fab22c98332fa8b72a by tmunro
 https://git.postgresql.org/gitweb/?p=postgresql.git;a=commitdiff;h=3566873f21909397561418fab22c98332fa8b72a
 On Windows, it is sometimes important for corresponding malloc() and
 free() calls to be made from the same DLL, since some build options can
 result in multiple allocators being active at the same time.  For that
 reason we already provided PQfreemem().  This commit adds a similar
 function for freeing string results allocated by the pgtypes library.
 Author: Takayuki Tsunakawa Reviewed-by: Kyotaro Horiguchi Discussion:
 https://postgr.es/m/0A3221C70F24FB45833433255569204D1F8AD5D6%40G01JPEXMBYT05
 The file was modified   src/interfaces/ecpg/test/pgtypeslib/dt_test.pgc
 The file was modified   src/interfaces/ecpg/test/expected/pgtypeslib-
 dt_test.c
 num_test2.c
 The file was modified   src/interfaces/ecpg/pgtypeslib/common.c
 The file was modified   src/interfaces/ecpg/test/pgtypeslib/dt_test2.pgc
 The file was modified   doc/src/sgml/ecpg.sgml
 The file was modified   src/interfaces/ecpg/test/sql/sqlda.pgc
 The file was modified   src/interfaces/ecpg/test/pgtypeslib/num_test2.pgc
 The file was modified   src/interfaces/ecpg/include/pgtypes_interval.h
 num_test.c
 The file was modified   src/interfaces/ecpg/include/pgtypes_timestamp.h
 The file was modified   src/interfaces/ecpg/include/pgtypes_numeric.h
 The file was modified   src/interfaces/ecpg/test/expected/preproc-
 outofscope.c
 The file was modified   src/interfaces/ecpg/include/Makefile
 The file was modified   src/interfaces/ecpg/include/pgtypes_date.h
 The file was modified   src/interfaces/ecpg/pgtypeslib/exports.txt
 The file was added      src/interfaces/ecpg/include/pgtypes.h
 dt_test2.c
 The file was modified   src/interfaces/ecpg/test/pgtypeslib/num_test.pgc
 The file was modified   src/interfaces/ecpg/test/expected/sql-sqlda.c
 I'll report upstream
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4111#comment:2>
