[postgis-tickets] [PostGIS] #4111: debbie failing on PostgreSQL 10 run on topology
PostGIS trac at osgeo.org
Sat Jun 30 14:59:43 PDT 2018
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  closed
  Priority:  blocker    |  Milestone:  PostGIS PostgreSQL
 Component:  buildbots  |    Version:  trunk
Resolution:  fixed      |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16625" 16625]:
 #!CommitTicketReference repository="" revision="16625"
 Make test sort order deterministic by using lateral.
 Closes #4111
 (Note they are going to fix the issue upstream that made this fail on
 stable 10, but I wanted to change this test anyway)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4111#comment:5>
