[postgis-tickets] r16453 - PG11: Force order in failing test
Raul raul at rmr.ninja
Fri Mar 9 07:37:02 PST 2018
Author: algunenano
Date: 2018-03-09 07:37:02 -0800 (Fri, 09 Mar 2018)
New Revision: 16453
   trunk/regress/tickets.sql
Closes #4033
Closes #https://github.com/postgis/postgis/pull/229
Modified: trunk/regress/tickets.sql
--- trunk/regress/tickets.sql	2018-03-09 08:07:06 UTC (rev 16452)
+++ trunk/regress/tickets.sql	2018-03-09 15:37:02 UTC (rev 16453)
@@ -1033,11 +1033,11 @@
     WHERE ST_Y(path.g) = ST_X(rec.g)
 SELECT '#1014c', id, st_astext(g) FROM path;
-SELECT '#1014d', ST_AsEWKT(g) FROM (
+SELECT '#1014d', ST_AsEWKT(g) as t FROM (
 	SELECT 'SRID=1;POINT(0 1)'::geometry AS g
 	UNION
 	SELECT 'SRID=2;POINT(0 1)'::geometry AS g
-) a;
+) a ORDER BY t;
 DROP TABLE IF EXISTS rec;
 -- #3930
