[postgis-tickets] r16459 - Put in missing availability notes for ST_Union and ST_Clip and also put in missed schema qualifications on ST_Clip, _ST_Clip functions
Regina Obe lr at pcorp.us
Tue Mar 13 03:48:09 PDT 2018
Author: robe
Date: 2018-03-13 15:48:09 -0700 (Tue, 13 Mar 2018)
New Revision: 16459
   trunk/raster/rt_pg/rtpostgis.sql.in
Modified: trunk/raster/rt_pg/rtpostgis.sql.in
--- trunk/raster/rt_pg/rtpostgis.sql.in	2018-03-13 17:39:15 UTC (rev 16458)
+++ trunk/raster/rt_pg/rtpostgis.sql.in	2018-03-13 22:48:09 UTC (rev 16459)
@@ -5864,7 +5864,7 @@
 -- Availability: 2.5.0
 -- expects output to be WKB
 -- ST_AsWKB() is functionally identitical to bytea()
--- kept separate as bytea(raster) is for casting
+-- kept separate as bytea(raster) is for casting
 CREATE OR REPLACE FUNCTION st_aswkb(raster, outasin boolean DEFAULT FALSE)
     RETURNS bytea
     AS 'MODULE_PATHNAME', 'RASTER_asWKB'
@@ -6833,11 +6833,13 @@
 	uniontype text
+-- Availability: 2.1.0
 CREATE OR REPLACE FUNCTION _st_union_finalfn(internal)
 	RETURNS raster
 	AS 'MODULE_PATHNAME', 'RASTER_union_finalfn'
 	LANGUAGE 'c' IMMUTABLE _PARALLEL;
 CREATE OR REPLACE FUNCTION _st_union_transfn(internal, raster, unionarg[])
 	RETURNS internal
 	AS 'MODULE_PATHNAME', 'RASTER_union_transfn'
@@ -6854,6 +6856,7 @@
 	FINALFUNC = _st_union_finalfn
 CREATE OR REPLACE FUNCTION _st_union_transfn(internal, raster, integer, text)
 	RETURNS internal
@@ -6871,6 +6874,7 @@
 CREATE OR REPLACE FUNCTION _st_union_transfn(internal, raster, integer)
 	RETURNS internal
@@ -6888,6 +6892,7 @@
 CREATE OR REPLACE FUNCTION _st_union_transfn(internal, raster)
 	RETURNS internal
@@ -6905,6 +6910,7 @@
 CREATE OR REPLACE FUNCTION _st_union_transfn(internal, raster, text)
 	RETURNS internal
@@ -6926,6 +6932,7 @@
 -- ST_Clip
 CREATE OR REPLACE FUNCTION _st_clip(
 	rast raster, nband integer[],
 	geom geometry,
@@ -6935,6 +6942,8 @@
 	AS 'MODULE_PATHNAME', 'RASTER_clip'
+-- Availability: 2.0.0
+-- Changed: 2.1.0
 CREATE OR REPLACE FUNCTION st_clip(
 	geom geometry,
@@ -6944,7 +6953,7 @@
  	AS $$
 	BEGIN
 		-- short-cut if geometry's extent fully contains raster's extent
-		IF (nodataval IS NULL OR array_length(nodataval, 1) < 1) AND geom ~ ST_Envelope(rast) THEN
+		IF (nodataval IS NULL OR array_length(nodataval, 1) < 1) AND geom ~ @extschema at .ST_Envelope(rast) THEN
 			RETURN rast;
 		END IF;
@@ -6952,6 +6961,7 @@
 	END;
 	$$ LANGUAGE 'plpgsql' IMMUTABLE _PARALLEL;
 	rast raster, nband integer,
 	geom geometry,
@@ -6958,9 +6968,10 @@
 	nodataval double precision, crop boolean DEFAULT TRUE
 	RETURNS raster AS
-	$$ SELECT ST_Clip($1, ARRAY[$2]::integer[], $3, ARRAY[$4]::double precision[], $5) $$
+	$$ SELECT @extschema at .ST_Clip($1, ARRAY[$2]::integer[], $3, ARRAY[$4]::double precision[], $5) $$
 	LANGUAGE 'sql' IMMUTABLE _PARALLEL;
 	geom geometry,
@@ -6967,9 +6978,10 @@
 	crop boolean
 	RETURNS raster AS
-	$$ SELECT ST_Clip($1, ARRAY[$2]::integer[], $3, null::double precision[], $4) $$
+	$$ SELECT @extschema at .ST_Clip($1, ARRAY[$2]::integer[], $3, null::double precision[], $4) $$
 	rast raster,
 	geom geometry,
@@ -6976,9 +6988,10 @@
 	nodataval double precision[] DEFAULT NULL, crop boolean DEFAULT TRUE
 	RETURNS raster AS
-	$$ SELECT ST_Clip($1, NULL, $2, $3, $4) $$
+	$$ SELECT @extschema at .ST_Clip($1, NULL, $2, $3, $4) $$
 	rast raster,
 	geom geometry,
@@ -6985,9 +6998,10 @@
 	RETURNS raster AS
-	$$ SELECT ST_Clip($1, NULL, $2, ARRAY[$3]::double precision[], $4) $$
+	$$ SELECT @extschema at .ST_Clip($1, NULL, $2, ARRAY[$3]::double precision[], $4) $$
 	rast raster,
 	geom geometry,
@@ -6994,7 +7008,7 @@
 	crop boolean
 	RETURNS raster AS
-	$$ SELECT ST_Clip($1, NULL, $2, null::double precision[], $3) $$
+	$$ SELECT @extschema at .ST_Clip($1, NULL, $2, null::double precision[], $3) $$
