[postgis-tickets] [PostGIS] #4044: PostgreSQL 11 regression failures on topology since March 3
PostGIS trac at osgeo.org
Tue Mar 13 16:06:12 PDT 2018
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS 2.5.0
 Component:  topology  |    Version:  trunk
Resolution:            |   Keywords:
Comment (by robe):
 found the culprit, and the dev run missed it because it only fails on
 upgrade.
 https://git.postgresql.org/gitweb/?p=postgresql.git;a=commit;h=fd1a421fe66173fb9b85d3fe150afde8e812cbe4
 author  Peter Eisentraut <peter_e at gmx.net>
         Fri, 2 Mar 2018 09:57:38 -0400 (08:57 -0500)
 committer       Peter Eisentraut <peter_e at gmx.net>
         Fri, 2 Mar 2018 14:48:33 -0400 (13:48 -0500)
 commit  fd1a421fe66173fb9b85d3fe150afde8e812cbe4
 tree    24c80c87337ec2d1bb46ee8463207d0cfff5ffc3        tree | snapshot
 parent  1733460f0205fc6d6bbe4c14911049a918c6e073        commit | diff
 Add prokind column, replacing proisagg and proiswindow
 The new column distinguishes normal functions, procedures, aggregates,
 and window functions.  This replaces the existing columns proisagg and
 proiswindow, and replaces the convention that procedures are indicated
 by prorettype == 0.  Also change prorettype to be VOIDOID for procedures.
 Reviewed-by: Tom Lane <tgl at sss.pgh.pa.us>
 Reviewed-by: Michael Paquier <michael at paquier.xyz>
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4044#comment:3>
