[postgis-tickets] [PostGIS] #4046: Revise Debbie Web Hook jobs (fix doc build)
PostGIS trac at osgeo.org
Tue Mar 13 22:26:36 PDT 2018
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  assigned
  Priority:  blocker    |  Milestone:  Management 2.0
 Component:  buildbots  |    Version:  trunk
Resolution:             |   Keywords:
Description changed by robe:
Old description:
> They changed the Generic Web Hook plugin to standardize on lowercase key
> names
> https://github.com/jenkinsci/generic-webhook-trigger-
> plugin/blob/master/CHANGELOG.md
> 1.30 (2018-03-08 17:59:01)
> No issue
> improve header variable name description
>     Version 1.28 introduced RFC 2616 compatibility making all headers
> lowercase.
>     This patch adds a note to make this fact more obvious.
>     Example situation where this matters: a CI systems that checks for X
> -GitHub-Event header to make further decisions. Since 1.28 the resulting
> variable changes from X_GitHub_Event to x_github_event effectively
> breaking this process.
> 0fd81969349a1d0 jekader 2018-03-08 17:28:09
> 1.29 (2018-03-06 20:26:35)
> GitHub #45 "This project is parameterized" parameters are being ignored
> if triggered bug
> Keeping default values in parameterized jobs #45
> 602ea1fd613abd2 Tomas Bjerre 2018-03-06 20:25:41
> I think the 1.28 change is what broke the doc building (as Dan Baston
> noticed) and the 1.30 will break the others, so have to change all of
> those that use regex to match by lower case.
New description:
 names
 plugi/blob/master/CHANGELOG.md
 No issue
 lowercase.
 GitHub #45 "This project is parameterized" parameters are being ignored if
 triggered bug
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4046#comment:1>
