[postgis-tickets] [PostGIS] #4047: Docs are broken on trunk
PostGIS trac at osgeo.org
Thu Mar 15 22:03:03 PDT 2018
  Reporter:  robe           |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  blocker        |  Milestone:  PostGIS 2.5.0
 Component:  documentation  |    Version:  trunk
Resolution:                 |   Keywords:
Description changed by robe:
Old description:
> Even though I got the job running again, the docs are still broken for
> trunk.
> https://debbie.postgis.net/job/PostGIS_Make_Dist/label=debbie/183/consoleFull
> I still have to investigate what's up.  Lot of imagemagick errors I don't
> recal seeing before, but don't think that's the main issue.
New description:
 trunk.
 05:37:19 generating ../images/st_subdivide01.png
 05:37:19 Could not find style named Style01
 05:37:21 generating ../images/st_subdivide02.png
 05:37:23 make[1]: *** [Makefile:178: ../images/st_subdivide02.png] Error 1
 05:37:23 make[1]: Leaving directory
 '/var/lib/jenkins/workspace/PostGIS_Make_Dist/label/debbie/20b95b81feb9f7e80dc829cd53f2640db4d2933e/doc/html/image_src'
 05:37:23 make: *** [Makefile:311: images] Error 2
 05:37:23 /usr/bin/xsltproc --novalid ./xsl/postgis_aggs_mm.xml.xsl
 postgis-out.xml > postgis_aggs_mm.xml
 05:37:23 if test x"dbtoepub" = x; then \
 05:37:23    echo "Error: dbtoepub not found, can't build epub"; \
 05:37:23    echo "       try installing dbtoepub"; \
 05:37:25    false; \
 05:37:25 else \
 05:37:25        dbtoepub -c
 "/var/lib/jenkins/workspace/PostGIS_Make_Dist/label/debbie/20b95b81feb9f7e80dc829cd53f2640db4d2933e/doc/html/style.css"
 05:37:25         -o postgis-2.5.0dev.epub \
 05:37:25          postgis-out.xml; \
 05:37:25 fi
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4047#comment:3>
