[postgis-tickets] r16479 - Add ChaikinSmoothing #4050
nicklas.aven at jordogskog.no nicklas.aven at jordogskog.no
Tue Mar 20 06:11:17 PDT 2018
Author: nicklas
Date: 2018-03-20 06:11:17 -0700 (Tue, 20 Mar 2018)
New Revision: 16479
Added:
   trunk/liblwgeom/cunit/cu_chaikin.c
   trunk/liblwgeom/lwchaikins.c
   trunk/regress/chaikin.sql
   trunk/regress/chaikin_expected
   trunk/NEWS
   trunk/doc/reference_processing.xml
   trunk/liblwgeom/Makefile.in
   trunk/liblwgeom/cunit/Makefile.in
   trunk/liblwgeom/cunit/cu_tester.c
   trunk/liblwgeom/liblwgeom.h.in
   trunk/postgis/lwgeom_functions_analytic.c
   trunk/postgis/postgis.sql.in
   trunk/regress/Makefile.in
Modified: trunk/NEWS
--- trunk/NEWS	2018-03-20 09:37:03 UTC (rev 16478)
+++ trunk/NEWS	2018-03-20 13:11:17 UTC (rev 16479)
@@ -2,6 +2,7 @@
 2018/xx/xx
 * New Features *
+  - #4050, ST_ChaikinSmoothing (Nicklas Avén)
   - #3989, ST_Buffer single sided option (Stephen Knox)
   - #3876, ST_Angle function (Rémi Cura)
   - #3564, ST_LineInterpolatePoints (Dan Baston)
Modified: trunk/doc/reference_processing.xml
--- trunk/doc/reference_processing.xml	2018-03-20 09:37:03 UTC (rev 16478)
+++ trunk/doc/reference_processing.xml	2018-03-20 13:11:17 UTC (rev 16479)
@@ -3081,7 +3081,7 @@
 		  </refsection>
 	</refentry>
-<refentry id="ST_SimplifyVW">
+    <refentry id="ST_SimplifyVW">
 	  <refnamediv>
 		<refname>ST_SimplifyVW</refname>
 		<refpurpose>Returns a "simplified" version of the given geometry using the Visvalingam-Whyatt algorithm</refpurpose>
@@ -3129,8 +3129,64 @@
 			<para><xref linkend="ST_SetEffectiveArea" />, <xref linkend="ST_Simplify" />, <xref linkend="ST_SimplifyPreserveTopology" />, Topology <xref linkend="TP_ST_Simplify"/></para>
 		  </refsection>
 	</refentry>
-		<refentry id="ST_SetEffectiveArea">
+    <refentry id="ST_ChaikinSmoothing">
 	  <refnamediv>
+		<refname>ST_ChaikinSmoothing</refname>
+		<refpurpose>Returns a "smoothed" version of the given geometry using the Chaikin algorithm</refpurpose>
+	  </refnamediv>
+	  <refsynopsisdiv>
+		<funcsynopsis>
+		  <funcprototype>
+			<funcdef>geometry <function>ST_ChaikinSmoothing</function></funcdef>
+			<paramdef><type>geometry</type> <parameter>geomA</parameter></paramdef>
+			<paramdef><type>integer</type> <parameter>nIterations</parameter></paramdef>
+			<paramdef><type>boolean</type> <parameter>preserveEndPoints</parameter></paramdef>
+		  </funcprototype>
+		</funcsynopsis>
+	  </refsynopsisdiv>
+	  <refsection>
+		<title>Description</title>
+		<para> Returns a "smoothed" version of the given geometry using the Chaikin algorithm.
+        See <ulink url="http://www.idav.ucdavis.edu/education/CAGDNotes/Chaikins-Algorithm/Chaikins-Algorithm.html">Chaikins-Algorithm</ulink> for an explanation of the process.
+		For each iteration the number of vertex points will double.
+        The function puts new vertex points at 1/4 of the line before and after each point and removes the original point.
+        To reduce the number of points use one of the simplification functions on the result.
+        The new points gets interpolated values for all included dimensions, also z and m.</para>
+		<note><para>Note that returned geometry will get more points than the original.
+                To reduce the number of points again use one of the simplification functions on the result.
+                (see <xref linkend="ST_Simplify" /> and <xref linkend="ST_SimplifyVW" />)</para></note>
+		<note><para>Second argument, number of iterations is limited to max 5 iterations</para></note>
+		<note><para>Note third argument is only valid for polygons, and will be ignored for linestrings</para></note>
+		<note><para>This function handles 3D and the third dimension will affect the result.</para></note>
+		<para>Availability: 2.5.0</para>
+	  </refsection>
+		  <refsection>
+			<title>Examples</title>
+			<para>A triangle is smoothed</para>
+				<programlisting>
+select ST_AsText(ST_ChaikinSmoothing(geom)) smoothed
+FROM (SELECT  'LINESTRING(0 0, 8 8, 0 16)'::geometry geom) As foo;
+-result
+ smoothed
+LINESTRING(0 0,6 6,6 10,0 16)
+				</programlisting>
+		  </refsection>
+		  <refsection>
+			<title>See Also</title>
+			<para><xref linkend="ST_Simplify" />, <xref linkend="ST_SimplifyVW" /></para>
+		  </refsection>
+	</refentry>
+    <refentry id="ST_SetEffectiveArea">
+	  <refnamediv>
 		<refname>ST_SetEffectiveArea</refname>
 		<refpurpose>
 			Sets the effective area for each vertex, storing the value in the M ordinate.  A simplified geometry can then be generated by filtering on the M ordinate.
Modified: trunk/liblwgeom/Makefile.in
--- trunk/liblwgeom/Makefile.in	2018-03-20 09:37:03 UTC (rev 16478)
+++ trunk/liblwgeom/Makefile.in	2018-03-20 13:11:17 UTC (rev 16479)
@@ -114,6 +114,7 @@
 	lwgeom_wrapx.o \
 	lwunionfind.o \
 	effectivearea.o \
+	lwchaikins.o \
 	lwkmeans.o \
 	varint.o
Modified: trunk/liblwgeom/cunit/Makefile.in
--- trunk/liblwgeom/cunit/Makefile.in	2018-03-20 09:37:03 UTC (rev 16478)
+++ trunk/liblwgeom/cunit/Makefile.in	2018-03-20 13:11:17 UTC (rev 16479)
@@ -36,6 +36,7 @@
 	cu_tree.o \
 	cu_measures.o \
 	cu_effectivearea.o \
+	cu_chaikin.o \
 	cu_node.o \
 	cu_clip_by_rect.o \
 	cu_libgeom.o \
Added: trunk/liblwgeom/cunit/cu_chaikin.c
--- trunk/liblwgeom/cunit/cu_chaikin.c	                        (rev 0)
+++ trunk/liblwgeom/cunit/cu_chaikin.c	2018-03-20 13:11:17 UTC (rev 16479)
@@ -0,0 +1,66 @@
+ * PostGIS - Spatial Types for PostgreSQL
+ * http://postgis.net
+ * Copyright 2012 Sandro Santilli <strk at kbt.io>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU General Public Licence. See the COPYING file.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include "CUnit/Basic.h"
+#include "liblwgeom_internal.h"
+#include "cu_tester.h"
+static void do_test_chaikin(char *geom_txt,char *expected, int n_iterations, int preserve_end_points)
+	LWGEOM *geom_in, *geom_out;
+	char *out_txt;
+	geom_in = lwgeom_from_wkt(geom_txt, LW_PARSER_CHECK_NONE);
+	geom_out = lwgeom_chaikin(geom_in, n_iterations, preserve_end_points);
+	out_txt = lwgeom_to_wkt(geom_out, WKT_EXTENDED, 3, NULL);
+	if(strcmp(expected, out_txt))
+		printf("%s is not equal to %s\n", expected, out_txt);
+	CU_ASSERT_STRING_EQUAL(expected, out_txt)
+	lwfree(out_txt);
+	lwgeom_free(geom_in);
+	lwgeom_free(geom_out);
+	return;
+static void do_test_chaikin_lines(void)
+	/*Simpliest test*/
+	do_test_chaikin("LINESTRING(0 0,8 8,16 0)","LINESTRING(0 0,6 6,10 6,16 0)", 1, 1);
+	/*2 iterations*/
+	do_test_chaikin("LINESTRING(0 0,8 8,16 0)","LINESTRING(0 0,4.5 4.5,7 6,9 6,11.5 4.5,16 0)", 2, 1);
+	/*check so it really ignores preserve_end_points set to off for linestrings*/
+	do_test_chaikin("LINESTRING(0 0,8 8,16 0)","LINESTRING(0 0,4.5 4.5,7 6,9 6,11.5 4.5,16 0)", 2, 0);
+	return;
+static void do_test_chaikin_polygons(void)
+	do_test_chaikin("POLYGON((0 0,8 8,16 0,0 0))","POLYGON((0 0,6 6,10 6,14 2,12 0,0 0))", 1, 1);
+	/*2 iterations*/
+	do_test_chaikin("POLYGON((0 0,8 8,16 0,0 0))","POLYGON((0 0,4.5 4.5,7 6,9 6,11 5,13 3,13.5 1.5,12.5 0.5,9 0,0 0))", 2, 1);
+	/*2 iterations without preserving end points*/
+	do_test_chaikin("POLYGON((0 0,8 8,16 0,0 0))","POLYGON((3 3,5 5,7 6,9 6,11 5,13 3,13.5 1.5,12.5 0.5,10 0,6 0,3.5 0.5,2.5 1.5,3 3))", 2, 0);
+	return;
+void chaikin_suite_setup(void);
+	CU_pSuite suite = CU_add_suite("chaikin",NULL,NULL);
+	PG_ADD_TEST(suite, do_test_chaikin_lines);
+	PG_ADD_TEST(suite, do_test_chaikin_polygons);
Modified: trunk/liblwgeom/cunit/cu_tester.c
--- trunk/liblwgeom/cunit/cu_tester.c	2018-03-20 09:37:03 UTC (rev 16478)
+++ trunk/liblwgeom/cunit/cu_tester.c	2018-03-20 13:11:17 UTC (rev 16479)
@@ -47,6 +47,7 @@
 extern void lwstroke_suite_setup(void);
 extern void measures_suite_setup(void);
 extern void effectivearea_suite_setup(void);
+extern void chaikin_suite_setup(void);
 extern void minimum_bounding_circle_suite_setup(void);
 extern void misc_suite_setup(void);
 extern void node_suite_setup(void);
@@ -97,6 +98,7 @@
 	lwstroke_suite_setup,
 	measures_suite_setup,
 	effectivearea_suite_setup,
+	chaikin_suite_setup,
 	minimum_bounding_circle_suite_setup,
 	misc_suite_setup,
 	node_suite_setup,
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in	2018-03-20 09:37:03 UTC (rev 16478)
+++ trunk/liblwgeom/liblwgeom.h.in	2018-03-20 13:11:17 UTC (rev 16479)
@@ -990,6 +990,7 @@
 extern LWGEOM* lwgeom_force_4d(const LWGEOM *geom);
 extern LWGEOM* lwgeom_set_effective_area(const LWGEOM *igeom, int set_area, double area);
+extern LWGEOM* lwgeom_chaikin(const LWGEOM *igeom, int n_iterations, int preserve_endpoint);
  * Force to use SFS 1.1 geometry type
Added: trunk/liblwgeom/lwchaikins.c
--- trunk/liblwgeom/lwchaikins.c	                        (rev 0)
+++ trunk/liblwgeom/lwchaikins.c	2018-03-20 13:11:17 UTC (rev 16479)
@@ -0,0 +1,202 @@
+ * PostGIS is free software: you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation, either version 2 of the License, or
+ * (at your option) any later version.
+ * PostGIS is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with PostGIS.  If not, see <http://www.gnu.org/licenses/>.
+ * Copyright 2018 Nicklas Avén
+ #include "liblwgeom_internal.h"
+static POINTARRAY * ptarray_chaikin(POINTARRAY *inpts, int preserve_endpoint, int isclosed)
+	uint32_t p, i, n_out_points=0, p1_set=0, p2_set=0;
+	POINT4D p1, p2;
+	POINTARRAY *opts;
+	double *dlist;
+	double deltaval, quarter_delta, val1, val2;
+	int ndims = 2 + ptarray_has_z(inpts) + ptarray_has_m(inpts);
+	int new_npoints = inpts->npoints * 2;
+	opts = ptarray_construct_empty(FLAGS_GET_Z(inpts->flags), FLAGS_GET_M(inpts->flags), new_npoints);
+	dlist = (double*)(opts->serialized_pointlist);
+	p1 = getPoint4d(inpts, 0);
+	/*if first point*/
+	if(preserve_endpoint)
+		ptarray_append_point(opts, &p1, LW_TRUE);
+		n_out_points++;
+	for (p=1;p<inpts->npoints;p++)
+		memcpy(&p2, &p1, sizeof(POINT4D));
+		p1 = getPoint4d(inpts, p);
+		if(p>0)
+			p1_set = p2_set = 0;
+			for (i=0;i<ndims;i++)
+				val1 = ((double*) &(p1))[i];
+				val2 = ((double*) &(p2))[i];
+				deltaval =  val1 - val2;
+				quarter_delta = deltaval * 0.25;
+				if(!preserve_endpoint || p > 1)
+					dlist[n_out_points * ndims + i] = val2 + quarter_delta;
+					p1_set = 1;
+				if(!preserve_endpoint || p < inpts->npoints - 1)
+					dlist[(n_out_points + p1_set) * ndims + i] = val1 - quarter_delta;
+					p2_set = 1;
+			n_out_points+=(p1_set + p2_set);
+	/*if last point*/
+		opts->npoints = n_out_points;
+		n_out_points++;
+	if(isclosed && !preserve_endpoint)
+		POINT4D first_point = getPoint4d(opts, 0);
+		ptarray_append_point(opts, &first_point, LW_TRUE);
+		n_out_points++;
+	return opts;
+static LWLINE* lwline_chaikin(const LWLINE *iline, int n_iterations)
+	POINTARRAY *pa, *pa_new;
+	int j;
+	if( lwline_is_empty(iline))
+		return lwline_clone(iline);
+	LWLINE *oline = lwline_construct_empty(iline->srid, FLAGS_GET_Z(iline->flags), FLAGS_GET_M(iline->flags));
+	pa = iline->points;
+	for (j=0;j<n_iterations;j++)
+		pa_new = ptarray_chaikin(pa,1,LW_FALSE);
+		if(j>0)
+			ptarray_free(pa);
+		pa=pa_new;
+	oline = lwline_construct(iline->srid, NULL, pa);
+	oline->type = iline->type;
+	return oline;
+static LWPOLY* lwpoly_chaikin(const LWPOLY *ipoly, int n_iterations, int preserve_endpoint)
+	uint32_t i, j;
+	LWPOLY *opoly = lwpoly_construct_empty(ipoly->srid, FLAGS_GET_Z(ipoly->flags), FLAGS_GET_M(ipoly->flags));
+	if( lwpoly_is_empty(ipoly) )
+		return opoly;
+	for (i = 0; i < ipoly->nrings; i++)
+		pa = ipoly->rings[i];
+		for(j=0;j<n_iterations;j++)
+			pa_new = ptarray_chaikin(pa,preserve_endpoint,LW_TRUE);
+			if(j>0)
+				ptarray_free(pa);
+			pa=pa_new;
+		if(pa->npoints>=4)
+			if( lwpoly_add_ring(opoly,pa ) == LW_FAILURE )
+				return NULL;
+	opoly->type = ipoly->type;
+	if( lwpoly_is_empty(opoly) )
+		return NULL;
+	return opoly;
+static LWCOLLECTION* lwcollection_chaikin(const LWCOLLECTION *igeom, int n_iterations, int preserve_endpoint)
+	LWDEBUG(2, "Entered  lwcollection_set_effective_area");
+	uint32_t i;
+	LWCOLLECTION *out = lwcollection_construct_empty(igeom->type, igeom->srid, FLAGS_GET_Z(igeom->flags), FLAGS_GET_M(igeom->flags));
+	if( lwcollection_is_empty(igeom) )
+		return out; /* should we return NULL instead ? */
+	for( i = 0; i < igeom->ngeoms; i++ )
+		LWGEOM *ngeom = lwgeom_chaikin(igeom->geoms[i],n_iterations,preserve_endpoint);
+		if ( ngeom ) out = lwcollection_add_lwgeom(out, ngeom);
+	return out;
+LWGEOM* lwgeom_chaikin(const LWGEOM *igeom, int n_iterations, int preserve_endpoint)
+	LWDEBUG(2, "Entered  lwgeom_set_effective_area");
+	switch (igeom->type)
+	case POINTTYPE:
+	case MULTIPOINTTYPE:
+		return lwgeom_clone(igeom);
+	case LINETYPE:
+		return (LWGEOM*)lwline_chaikin((LWLINE*)igeom, n_iterations);
+	case POLYGONTYPE:
+		return (LWGEOM*)lwpoly_chaikin((LWPOLY*)igeom,n_iterations,preserve_endpoint);
+	case MULTILINETYPE:
+	case MULTIPOLYGONTYPE:
+	case COLLECTIONTYPE:
+		return (LWGEOM*)lwcollection_chaikin((LWCOLLECTION *)igeom,n_iterations,preserve_endpoint);
+	default:
+		lwerror("lwgeom_chaikin: unsupported geometry type: %s",lwtype_name(igeom->type));
+	return NULL;
Modified: trunk/postgis/lwgeom_functions_analytic.c
--- trunk/postgis/lwgeom_functions_analytic.c	2018-03-20 09:37:03 UTC (rev 16478)
+++ trunk/postgis/lwgeom_functions_analytic.c	2018-03-20 13:11:17 UTC (rev 16479)
@@ -127,7 +127,51 @@
 	PG_RETURN_POINTER(result);
+PG_FUNCTION_INFO_V1(LWGEOM_ChaikinSmoothing);
+Datum LWGEOM_ChaikinSmoothing(PG_FUNCTION_ARGS)
+	GSERIALIZED *geom = PG_GETARG_GSERIALIZED_P(0);
+	GSERIALIZED *result;
+	int type = gserialized_get_type(geom);
+	LWGEOM *in;
+	LWGEOM *out;
+	int preserve_endpoints=1;
+	int n_iterations=1;
+	if ( type == POINTTYPE || type == MULTIPOINTTYPE )
+		PG_RETURN_POINTER(geom);
+	if ( (PG_NARGS()>1) && (!PG_ARGISNULL(1)) )
+		n_iterations = PG_GETARG_INT32(1);
+	if (n_iterations>5)
+		elog(ERROR,"Not more than 5 iterations please");
+	if (n_iterations< 1)
+		elog(ERROR,"Number of iterations must be between 1 and 5");
+	if ( (PG_NARGS()>2) && (!PG_ARGISNULL(2)) )
+		if(PG_GETARG_BOOL(2))
+			preserve_endpoints = 1;
+		else
+			preserve_endpoints = 0;
+	in = lwgeom_from_gserialized(geom);
+	out = lwgeom_chaikin(in, n_iterations, preserve_endpoints);
+	if ( ! out ) PG_RETURN_NULL();
+	/* COMPUTE_BBOX TAINTING */
+	if ( in->bbox ) lwgeom_add_bbox(out);
+	result = geometry_serialize(out);
+	lwgeom_free(out);
+	PG_FREE_IF_COPY(geom, 0);
+	PG_RETURN_POINTER(result);
  * --strk at kbt.io;
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in	2018-03-20 09:37:03 UTC (rev 16478)
+++ trunk/postgis/postgis.sql.in	2018-03-20 13:11:17 UTC (rev 16479)
@@ -3144,7 +3144,14 @@
 	AS 'MODULE_PATHNAME', 'LWGEOM_SetEffectiveArea'
 	LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL
 	COST 1; -- reset cost, see #3675
+-- Availability: 2.5.0
+CREATE OR REPLACE FUNCTION ST_ChaikinSmoothing(geometry, integer default 1, boolean default true)
+	RETURNS geometry
+	AS 'MODULE_PATHNAME', 'LWGEOM_ChaikinSmoothing'
+	LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL
+	COST 1; -- reset cost, see #3675
 -- ST_SnapToGrid(input, xoff, yoff, xsize, ysize)
 -- Availability: 1.2.2
 CREATE OR REPLACE FUNCTION ST_SnapToGrid(geometry, float8, float8, float8, float8)
Modified: trunk/regress/Makefile.in
--- trunk/regress/Makefile.in	2018-03-20 09:37:03 UTC (rev 16478)
+++ trunk/regress/Makefile.in	2018-03-20 13:11:17 UTC (rev 16479)
@@ -80,6 +80,7 @@
 	bestsrid \
 	binary \
 	boundary \
+	chaikin \
 	cluster \
 	concave_hull\
 	ctors \
Added: trunk/regress/chaikin.sql
--- trunk/regress/chaikin.sql	                        (rev 0)
+++ trunk/regress/chaikin.sql	2018-03-20 13:11:17 UTC (rev 16479)
@@ -0,0 +1,6 @@
+SELECT '1', ST_astext(ST_ChaikinSmoothing('LINESTRING(0 0, 8 8, 0 16)'));
+SELECT '2', ST_astext(ST_ChaikinSmoothing('LINESTRING(0 0, 8 8, 0 16)',10));
+SELECT '3', ST_astext(ST_ChaikinSmoothing('LINESTRING(0 0, 8 8, 0 16)',0));
+SELECT '4', ST_astext(ST_ChaikinSmoothing('LINESTRING(0 0, 8 8, 0 16)',2));
+SELECT '5', ST_astext(ST_ChaikinSmoothing('POINT(0 0)'));
+SELECT '6', ST_astext(ST_ChaikinSmoothing('GEOMETRYCOLLECTION(POINT(1 1), LINESTRING(1 1, 1 3, 1 5), POLYGON((5 5, 5 10, 10 10, 10 5, 5 5), (6 6, 6 7, 7 7, 7 6, 6 6 )))', 2, 't'));
Added: trunk/regress/chaikin_expected
--- trunk/regress/chaikin_expected	                        (rev 0)
+++ trunk/regress/chaikin_expected	2018-03-20 13:11:17 UTC (rev 16479)
@@ -0,0 +1,6 @@
+1|LINESTRING(0 0,6 6,6 10,0 16)
+ERROR:  Not more than 5 iterations please
+ERROR:  Number of iterations must be between 1 and 5
+4|LINESTRING(0 0,4.5 4.5,6 7,6 9,4.5 11.5,0 16)
+5|POINT(0 0)
+6|GEOMETRYCOLLECTION(POINT(1 1),LINESTRING(1 1,1 2.125,1 2.75,1 3.25,1 3.875,1 5),POLYGON((5 5,5 7.8125,5.3125 9.0625,5.9375 9.6875,6.875 10,8.125 10,9.0625 9.6875,9.6875 9.0625,10 8.125,10 6.875,9.6875 5.9375,9.0625 5.3125,7.8125 5,5 5),(6 6,6 6.5625,6.0625 6.8125,6.1875 6.9375,6.375 7,6.625 7,6.8125 6.9375,6.9375 6.8125,7 6.625,7 6.375,6.9375 6.1875,6.8125 6.0625,6.5625 6,6 6)))
