[postgis-tickets] r16481 - schema qualify geography functions (including ST_Buffer)
Regina Obe lr at pcorp.us
Thu Mar 22 08:45:32 PDT 2018
Author: robe
Date: 2018-03-22 08:45:31 -0700 (Thu, 22 Mar 2018)
New Revision: 16481
   branches/2.3/NEWS
   branches/2.3/postgis/geography.sql.in
References #4052 for PostGIS 2.3.7
Modified: branches/2.3/NEWS
--- branches/2.3/NEWS	2018-03-20 14:11:54 UTC (rev 16480)
+++ branches/2.3/NEWS	2018-03-22 15:45:31 UTC (rev 16481)
@@ -9,6 +9,7 @@
            PolyhedralSurface (Matthias Bay)
   - #4025, Incorrect answers for temporally "amost overlapping" ranges
   - #4017, lwgeom lexer memory corruption (Peter E)
+  - #4052, schema qualify several functions in geography
 PostGIS 2.3.6
Modified: branches/2.3/postgis/geography.sql.in
--- branches/2.3/postgis/geography.sql.in	2018-03-20 14:11:54 UTC (rev 16480)
+++ branches/2.3/postgis/geography.sql.in	2018-03-22 15:45:31 UTC (rev 16481)
@@ -23,7 +23,7 @@
 	RETURNS cstring
 	AS 'MODULE_PATHNAME','postgis_typmod_out'
 	LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
 -- Availability: 1.5.0
 CREATE OR REPLACE FUNCTION geography_in(cstring, oid, integer)
 	RETURNS geography
@@ -75,7 +75,7 @@
 CREATE OR REPLACE FUNCTION geography(geography, integer, boolean)
 	RETURNS geography
 	AS 'MODULE_PATHNAME','geography_enforce_typmod'
-	LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
+	LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
 CREATE CAST (geography AS geography) WITH FUNCTION geography(geography, integer, boolean) AS IMPLICIT;
@@ -103,11 +103,11 @@
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asText'
 -- Availability: 1.5.0 - this is just a hack to prevent unknown from causing ambiguous name because of geography
 CREATE OR REPLACE FUNCTION ST_AsText(text)
 	RETURNS text AS
-	$$ SELECT ST_AsText($1::@extschema at .geometry);  $$
+	$$ SELECT @extschema at .ST_AsText($1::@extschema at .geometry);  $$
 	LANGUAGE 'sql' IMMUTABLE STRICT _PARALLEL;
@@ -149,17 +149,17 @@
 CREATE OR REPLACE VIEW geography_columns AS
 	SELECT
-		current_database() AS f_table_catalog,
-		n.nspname AS f_table_schema,
-		c.relname AS f_table_name,
+		current_database() AS f_table_catalog,
+		n.nspname AS f_table_schema,
+		c.relname AS f_table_name,
 		a.attname AS f_geography_column,
 		postgis_typmod_dims(a.atttypmod) AS coord_dimension,
 		postgis_typmod_srid(a.atttypmod) AS srid,
 		postgis_typmod_type(a.atttypmod) AS type
-	FROM
-		pg_class c,
-		pg_attribute a,
-		pg_type t,
+	FROM
+		pg_class c,
+		pg_attribute a,
+		pg_type t,
 		pg_namespace n
 	WHERE t.typname = 'geography'
         AND a.attisdropped = false
@@ -192,50 +192,50 @@
-CREATE OR REPLACE FUNCTION geography_gist_consistent(internal,geography,int4)
-	RETURNS bool
+CREATE OR REPLACE FUNCTION geography_gist_consistent(internal,geography,int4)
+	RETURNS bool
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_consistent'
 	LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geography_gist_compress(internal)
-	RETURNS internal
+CREATE OR REPLACE FUNCTION geography_gist_compress(internal)
+	RETURNS internal
 	AS 'MODULE_PATHNAME','gserialized_gist_compress'
 	LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geography_gist_penalty(internal,internal,internal)
-	RETURNS internal
+CREATE OR REPLACE FUNCTION geography_gist_penalty(internal,internal,internal)
+	RETURNS internal
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_penalty'
 	LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geography_gist_picksplit(internal, internal)
-	RETURNS internal
+CREATE OR REPLACE FUNCTION geography_gist_picksplit(internal, internal)
+	RETURNS internal
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_picksplit'
 	LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geography_gist_union(bytea, internal)
-	RETURNS internal
+CREATE OR REPLACE FUNCTION geography_gist_union(bytea, internal)
+	RETURNS internal
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_union'
 	LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geography_gist_same(box2d, box2d, internal)
-	RETURNS internal
+CREATE OR REPLACE FUNCTION geography_gist_same(box2d, box2d, internal)
+	RETURNS internal
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_same'
 	LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geography_gist_decompress(internal)
-	RETURNS internal
+CREATE OR REPLACE FUNCTION geography_gist_decompress(internal)
+	RETURNS internal
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_decompress'
 	LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geography_overlaps(geography, geography)
-	RETURNS boolean
+CREATE OR REPLACE FUNCTION geography_overlaps(geography, geography)
+	RETURNS boolean
 	AS 'MODULE_PATHNAME' ,'gserialized_overlaps'
@@ -244,7 +244,7 @@
 	LEFTARG = geography, RIGHTARG = geography, PROCEDURE = geography_overlaps,
 	COMMUTATOR = '&&',
 	RESTRICT = gserialized_gist_sel_nd,
-	JOIN = gserialized_gist_joinsel_nd
+	JOIN = gserialized_gist_joinsel_nd
 -- Availability: 2.2.0
@@ -261,8 +261,8 @@
-CREATE OR REPLACE FUNCTION geography_gist_distance(internal, geography, int4)
-	RETURNS float8
+CREATE OR REPLACE FUNCTION geography_gist_distance(internal, geography, int4)
+	RETURNS float8
 	AS 'MODULE_PATHNAME' ,'gserialized_gist_geog_distance'
 	LANGUAGE 'c';
@@ -313,19 +313,19 @@
 	AS 'MODULE_PATHNAME', 'geography_gt'
--- Availability: 1.5.0
+-- Availability: 1.5.0
 CREATE OR REPLACE FUNCTION geography_ge(geography, geography)
 	RETURNS bool
 	AS 'MODULE_PATHNAME', 'geography_ge'
 CREATE OR REPLACE FUNCTION geography_eq(geography, geography)
 	RETURNS bool
 	AS 'MODULE_PATHNAME', 'geography_eq'
 CREATE OR REPLACE FUNCTION geography_cmp(geography, geography)
 	RETURNS integer
 	AS 'MODULE_PATHNAME', 'geography_cmp'
@@ -396,11 +396,11 @@
 	RETURNS text
 	AS 'MODULE_PATHNAME','geography_as_svg'
 CREATE OR REPLACE FUNCTION ST_AsSVG(text)
 	RETURNS text AS
-	$$ SELECT ST_AsSVG($1::@extschema at .geometry,0,15);  $$
+	$$ SELECT @extschema at .ST_AsSVG($1::@extschema at .geometry,0,15);  $$
@@ -532,11 +532,11 @@
 	RETURNS float8
 	AS 'SELECT @extschema at ._ST_Distance($1, $2, 0.0, true)'
 CREATE OR REPLACE FUNCTION ST_Distance(text, text)
 	RETURNS float8 AS
-	$$ SELECT ST_Distance($1::@extschema at .geometry, $2::@extschema at .geometry);  $$
+	$$ SELECT @extschema at .ST_Distance($1::@extschema at .geometry, $2::@extschema at .geometry);  $$
 -- Only expands the bounding box, the actual geometry will remain unchanged, use with care.
@@ -563,7 +563,7 @@
 CREATE OR REPLACE FUNCTION ST_DWithin(text, text, float8)
 	RETURNS boolean AS
-	$$ SELECT ST_DWithin($1::@extschema at .geometry, $2::@extschema at .geometry, $3);  $$
+	$$ SELECT @extschema at .ST_DWithin($1::@extschema at .geometry, $2::@extschema at .geometry, $3);  $$
 	LANGUAGE 'sql' IMMUTABLE _PARALLEL;
@@ -578,7 +578,7 @@
 	AS 'MODULE_PATHNAME','geography_distance_uncached'
 	COST 100;
 -- Calculate the distance in geographics *without* using the caching code line or tree code
 CREATE OR REPLACE FUNCTION _ST_DistanceUnCached(geography, geography, boolean)
 	RETURNS float8
@@ -591,7 +591,7 @@
 	AS 'SELECT @extschema at ._ST_DistanceUnCached($1, $2, 0.0, true)'
 	LANGUAGE 'sql' IMMUTABLE STRICT;
--- Calculate the distance in geographics using the circular tree code, but
+-- Calculate the distance in geographics using the circular tree code, but
 -- *without* using the caching code line
 CREATE OR REPLACE FUNCTION _ST_DistanceTree(geography, geography, float8, boolean)
 	RETURNS float8
@@ -599,7 +599,7 @@
 	COST 100;
 CREATE OR REPLACE FUNCTION _ST_DistanceTree(geography, geography)
 	RETURNS float8
@@ -618,7 +618,7 @@
 	RETURNS boolean
 	AS 'SELECT $1 OPERATOR(@extschema at .&&) @extschema at ._ST_Expand($2,$3) AND $2 OPERATOR(@extschema at .&&) @extschema at ._ST_Expand($1,$3) AND @extschema at ._ST_DWithinUnCached($1, $2, $3, true)'
 	LANGUAGE 'sql' IMMUTABLE;
@@ -631,7 +631,7 @@
 CREATE OR REPLACE FUNCTION ST_Area(text)
 	RETURNS float8 AS
-	$$ SELECT ST_Area($1::@extschema at .geometry);  $$
+	$$ SELECT @extschema at .ST_Area($1::@extschema at .geometry);  $$
@@ -644,7 +644,7 @@
 CREATE OR REPLACE FUNCTION ST_Length(text)
 	RETURNS float8 AS
-	$$ SELECT ST_Length($1::@extschema at .geometry);  $$
+	$$ SELECT @extschema at .ST_Length($1::@extschema at .geometry);  $$
 -- Availability: 2.0.0
@@ -692,7 +692,7 @@
 CREATE OR REPLACE FUNCTION ST_Covers(text, text)
 	RETURNS boolean AS
-	$$ SELECT ST_Covers($1::@extschema at .geometry, $2::@extschema at .geometry);  $$
+	$$ SELECT @extschema at .ST_Covers($1::@extschema at .geometry, $2::@extschema at .geometry);  $$
 -- Only implemented for polygon-over-point
@@ -705,7 +705,7 @@
 CREATE OR REPLACE FUNCTION ST_CoveredBy(text, text)
 	RETURNS boolean AS
-	$$ SELECT ST_CoveredBy($1::@extschema at .geometry, $2::@extschema at .geometry);  $$
+	$$ SELECT @extschema at .ST_CoveredBy($1::@extschema at .geometry, $2::@extschema at .geometry);  $$
 -- Availability: 2.1.0
@@ -724,7 +724,7 @@
 CREATE OR REPLACE FUNCTION ST_Intersects(text, text)
 	RETURNS boolean AS
-	$$ SELECT ST_Intersects($1::@extschema at .geometry, $2::@extschema at .geometry);  $$
+	$$ SELECT @extschema at .ST_Intersects($1::@extschema at .geometry, $2::@extschema at .geometry);  $$
@@ -742,43 +742,43 @@
 CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8)
 	RETURNS geography
-	AS 'SELECT geography(ST_Transform(ST_Buffer(ST_Transform(geometry($1), @extschema at ._ST_BestSRID($1)), $2), 4326))'
+	AS 'SELECT @extschema at .geography(@extschema at .ST_Transform(@extschema at .ST_Buffer(@extschema at .ST_Transform(geometry($1), @extschema at ._ST_BestSRID($1)), $2), 4326))'
 -- Availability: 2.3.x
 CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8, integer)
 	RETURNS geography
-	AS 'SELECT geography(ST_Transform(ST_Buffer(ST_Transform(geometry($1), @extschema at ._ST_BestSRID($1)), $2, $3), 4326))'
+	AS 'SELECT @extschema at .geography(@extschema at .ST_Transform(@extschema at .ST_Buffer(@extschema at .ST_Transform(@extschema at .geometry($1), @extschema at ._ST_BestSRID($1)), $2, $3), 4326))'
 CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8, text)
 	RETURNS geography
 CREATE OR REPLACE FUNCTION ST_Buffer(text, float8)
 	RETURNS geometry AS
-	$$ SELECT ST_Buffer($1::@extschema at .geometry, $2);  $$
+	$$ SELECT @extschema at .ST_Buffer($1::@extschema at .geometry, $2);  $$
 CREATE OR REPLACE FUNCTION ST_Buffer(text, float8, integer)
 	RETURNS geometry AS
-	$$ SELECT ST_Buffer($1::@extschema at .geometry, $2, $3);  $$
+	$$ SELECT @extschema at .ST_Buffer($1::@extschema at .geometry, $2, $3);  $$
 CREATE OR REPLACE FUNCTION ST_Buffer(text, float8, text)
 	RETURNS geometry AS
 CREATE OR REPLACE FUNCTION ST_Intersection(geography, geography)
 	RETURNS geography
-	AS 'SELECT geography(ST_Transform(ST_Intersection(ST_Transform(geometry($1), @extschema at ._ST_BestSRID($1, $2)), ST_Transform(geometry($2), @extschema at ._ST_BestSRID($1, $2))), 4326))'
+	AS 'SELECT @extschema at .geography(@extschema at .ST_Transform(@extschema at .ST_Intersection(@extschema at .ST_Transform(@extschema at .geometry($1), @extschema at ._ST_BestSRID($1, $2)), @extschema at .ST_Transform(@extschema at .geometry($2), @extschema at ._ST_BestSRID($1, $2))), 4326))'
@@ -834,13 +834,13 @@
 	RETURNS int4
 	AS 'MODULE_PATHNAME', 'LWGEOM_get_srid'
 CREATE OR REPLACE FUNCTION ST_SetSRID(geog geography, srid int4)
 	RETURNS geography
 	AS 'MODULE_PATHNAME', 'LWGEOM_set_srid'
