[postgis-tickets] [PostGIS] #4053: Memory leak in lwline_chaikin
PostGIS trac at osgeo.org
Fri Mar 23 02:10:46 PDT 2018
 Reporter:  Algunenano  |      Owner:  Algunenano
     Type:  defect      |     Status:  assigned
 Priority:  high        |  Milestone:  PostGIS 2.5.0
Component:  liblwgeom   |    Version:  trunk
 Keywords:              |
 Direct leak of 32 byte(s) in 1 object(s) allocated from:
     #0 0x55ee1a682f11 in __interceptor_malloc
 (/home/raul/dev/public/postgis/liblwgeom/cunit/.libs/lt-
 cu_tester+0x13ef11)
     #1 0x7f708d9bade1 in lwline_construct_empty
 /home/raul/dev/public/postgis/liblwgeom/lwline.c:66:19
     #2 0x7f708da9a546 in lwline_chaikin
 /home/raul/dev/public/postgis/liblwgeom/lwchaikins.c:110:18
     #3 0x7f708da9a546 in lwgeom_chaikin
 /home/raul/dev/public/postgis/liblwgeom/lwchaikins.c:191
     #4 0x55ee1a6e81db in do_test_chaikin
 /home/raul/dev/public/postgis/liblwgeom/cunit/cu_chaikin.c:26:13
     #5 0x55ee1a6e8132 in do_test_chaikin_lines
 /home/raul/dev/public/postgis/liblwgeom/cunit/cu_chaikin.c:42:2
     #6 0x7f708d511087 in run_single_test.constprop.5 /tmp/yaourt-tmp-raul
 /aur-cunit/src/CUnit-2.1-3/CUnit/Sources/Framework/TestRun.c:991
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4053>
