[postgis-tickets] [PostGIS] #2960: Note in soft upgrade docs that legacy.sql needs to be rerun for each minor upgrade
PostGIS trac at osgeo.org
Fri Mar 23 19:17:08 PDT 2018
upgrade
  Reporter:  robe           |      Owner:  robe
      Type:  defect         |     Status:  closed
  Priority:  low            |  Milestone:  PostGIS 2.4.4
 Component:  documentation  |    Version:  2.1.x
Resolution:  fixed          |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16495" 16495]:
 #!CommitTicketReference repository="" revision="16495"
 note in docs about soft upgrade that legacy.sql must be rerun for each
 minor.
 Closes #2960 for PostGIS 2.4.4
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2960#comment:14>
