[postgis-tickets] r16508 - Avoid incompatible automatic variable length array
Sandro Santilli strk at kbt.io
Wed Mar 28 08:01:18 PDT 2018
Author: strk
Date: 2018-03-28 08:01:18 -0700 (Wed, 28 Mar 2018)
New Revision: 16508
   trunk/postgis/geography_centroid.c
Patch by vmo
Closes #4059
Modified: trunk/postgis/geography_centroid.c
--- trunk/postgis/geography_centroid.c	2018-03-28 15:01:12 UTC (rev 16507)
+++ trunk/postgis/geography_centroid.c	2018-03-28 15:01:18 UTC (rev 16508)
@@ -105,7 +105,7 @@
         /* average between all points */
         uint32_t size = mpoints->ngeoms;
-        POINT3DM points[size];
+        POINT3DM* points = palloc(size*sizeof(POINT3DM));
 		uint32_t i;
 		for (i = 0; i < size; i++) {
@@ -115,6 +115,7 @@
 		lwpoint_out = geography_centroid_from_wpoints(srid, points, size);
+        pfree(points);
         break;
@@ -258,7 +259,7 @@
         size += (mline->geoms[i]->points->npoints - 1) * 2;
     uint32_t j = 0;
     for (i = 0; i < mline->ngeoms; i++) {
@@ -295,7 +296,9 @@
-    return geography_centroid_from_wpoints(mline->srid, points, size);
+    LWPOINT* result = geography_centroid_from_wpoints(mline->srid, points, size);
+    pfree(points);
+    return result;
@@ -313,7 +316,7 @@
     uint32_t j = 0;
     /* use first point as reference to create triangles */
@@ -379,6 +382,7 @@
-    return geography_centroid_from_wpoints(mpoly->srid, points, size);
+    LWPOINT* result = geography_centroid_from_wpoints(mpoly->srid, points, size);
+    pfree(points);
+    return result;
