[postgis-tickets] [PostGIS] #4078: test_gdal_configured fails with GDAL 2.3.0-rc1
PostGIS trac at osgeo.org
Fri May 4 12:54:27 PDT 2018
 Reporter:  Bas Couwenberg  |      Owner:  pramsey
     Type:  defect          |     Status:  new
 Priority:  high            |  Milestone:  PostGIS 2.4.5
Component:  postgis         |    Version:  2.4.x
 Keywords:                  |
 The gdal test suite fails with GDAL 2.3.0-rc1:
 Suite: gdal
   Test: test_gdal_configured ...ERROR 4: Unable to open EPSG support file
 gcs.csv.  Try setting the GDAL_DATA environment variable to point to the
 directory containing EPSG csv files.
 FAILED
     1. cu_gdal.c:28  - rt_util_gdal_configured()
   Test: test_gdal_drivers ...passed
   Test: test_gdal_rasterize ...passed
   Test: test_gdal_polygonize ...passed
   Test: test_raster_to_gdal ...Warning 1: Cannot find pcs.csv
 Warning 1: Cannot find datum.csv or gdal_datum.csv
 Warning 1: Cannot find ellipsoid.csv
 Warning 1: Cannot find prime_meridian.csv
 Warning 6: PNG driver doesn't support data type Float64. Only eight bit
 (Byte) and sixteen bit (UInt16) bands supported. Defaulting to Byte
 passed
   Test: test_gdal_to_raster ...passed
   Test: test_gdal_warp ...passed
 The full buildlog is attached.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4078>
