[postgis-tickets] [PostGIS] #4078: test_gdal_configured fails with GDAL 2.3.0-rc1
PostGIS trac at osgeo.org
Mon May 7 13:48:02 PDT 2018
  Reporter:  Bas Couwenberg  |      Owner:  pramsey
      Type:  defect          |     Status:  new
  Priority:  high            |  Milestone:  PostGIS 2.4.5
 Component:  postgis         |    Version:  2.4.x
Resolution:                  |   Keywords:
Comment (by Bas Couwenberg):
 `test_gdal_configured` succeeds with the new gdal package, but two other
 tests now fail:
  rt_gdalwarp .. failed (diff expected obtained:
 /tmp/pgis_reg/test_50_diff)
  rt_asraster .. failed (diff expected obtained:
 /tmp/pgis_reg/test_51_diff)
 --- rt_gdalwarp_expected        2018-04-06 05:05:52.000000000 +0000
 +++ /tmp/pgis_reg/test_50_out   2018-05-07 20:41:43.339711352 +0000
 @@ -1,40 +1,9 @@
  NOTICE:  table "raster_gdalwarp_src" does not exist, skipping
  NOTICE:  table "raster_gdalwarp_dst" does not exist, skipping
 +ERROR:  rt_raster_gdal_warp: Could not create GDAL transformation object
 for output dataset creation
  NOTICE:  Values must be provided for both X and Y when specifying the
 scale.  Returning original raster
 -NOTICE:  Raster has default geotransform. Adjusting metadata for use of
 GDAL Warp API
 GDAL Warp API
 GDAL Warp API
 -NOTICE:  Values must be provided for both X and Y when specifying the
 -0.0|||||||||||||
 -0.1|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 -0.10|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
 -0.11|992163|11|10|1|1000.000|-1000.000|0.000|0.000|-500001.000|600000.000|t|t|t
 -0.12|992163|10|11|1|1000.000|-1000.000|0.000|0.000|-500000.000|600009.000|t|t|t
 -0.13|992163|11|11|1|1000.000|-1000.000|0.000|0.000|-500100.000|600950.000|t|t|t
 -0.14|992163|201|201|1|50.000|50.000|0.000|0.000|-500040.000|589957.000|t|t|t
 -0.15|992163|84|84|1|121.000|121.000|0.000|0.000|-500093.000|589875.000|t|t|t
 -0.16|993310|243|243|1|50.000|50.000|0.000|0.000|950710.000|1397157.000|t|t|t
 -0.17|993309|243|243|1|50.000|50.000|0.000|0.000|950760.000|1396957.000|t|t|t
 -0.18|992163|10|10|1|1000.000|-1000.000|3.000|3.000|-500030.000|600000.000|t|t|t
 -0.19|993310|12|12|1|1009.894|-1009.894|3.000|3.000|950691.792|1409281.783|t|t|t
 -0.2|993309|12|12|1|1009.916|-1009.916|0.000|0.000|950762.305|1409088.896|t|t|t
 -0.20|993309|12|12|1|1009.916|-1009.916|1.000|3.000|950742.107|1409088.896|t|t|t
 -0.21|993310|24|24|1|500.000|500.000|3.000|3.000|950657.188|1397356.783|t|t|t
 -0.22|993310|26|26|1|500.000|500.000|0.000|6.000|950452.000|1396632.000|t|t|t
 -0.23|984269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
 -0.24|974269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
 -0.25|0|5|5|1|2.000|-2.000|0.000|0.000|0.000|0.000|t|t|t
 -0.26|0|2|2|1|5.000|-5.000|0.000|0.000|0.000|0.000|t|t|t
 -0.27|0|100|100|1|0.100|-0.100|0.000|0.000|0.000|0.000|t|t|t
 -0.3|994269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
 -0.4|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 -0.5|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
 -0.6|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
 -0.7|992163|20|20|1|500.000|500.000|0.000|0.000|-500000.000|590000.000|t|t|t
 -0.8|992163|40|40|1|250.000|250.000|0.000|0.000|-500000.000|590000.000|t|t|t
 -0.9|992163|40|40|1|250.000|250.000|0.000|0.000|-500000.000|590000.000|t|t|t
  1.0|||||||||||||
 1.1|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
 1.10|992163|10|11|1|1000.000|-1000.000|0.000|0.000|-500000.000|600009.000|t|t|t
 @@ -61,21 +30,6 @@
 1.7|992163|40|40|1|250.000|250.000|0.000|0.000|-500000.000|590000.000|t|t|t
 1.8|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
 1.9|992163|11|10|1|1000.000|-1000.000|0.000|0.000|-500001.000|600000.000|t|t|t
 -2.1|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 -2.10|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 -2.11|993309|121|121|1|100.000|100.000|0.000|0.000|950762.305|1396988.896|t|t|t
 -2.12|993310|6|6|1|2000.000|2000.000|0.000|0.000|950732.188|1397281.783|t|t|t
 -2.13|993310|8|8|1|1500.000|1500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 -2.14|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 -2.15|993310|16|16|1|750.000|750.000|0.000|0.000|950732.188|1397281.783|t|t|t
 -2.2|993309|12|12|1|1009.916|-1009.916|0.000|0.000|950762.305|1409088.896|t|t|t
 -2.3|994269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
 -2.4|||||||||||||
 -2.5|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 -2.6|||||||||||||
 -2.7|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 -2.8|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 -2.9|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 3.1|992163|100|100|1|100.000|100.000|0.000|0.000|-500000.000|590000.000|t|t|t
 3.2|992163|100|100|1|100.000|100.000|0.000|0.000|-500000.000|590000.000|t|t|t
 3.3|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
 @@ -115,8 +69,7 @@
 5.7|992163|10|11|1|1000.000|-1000.000|0.000|0.000|-500000.000|600991.000|t|t|t
 5.8|992163|10|11|1|1000.000|-1000.000|0.000|0.000|-500000.000|600001.000|t|t|t
 5.9|992163|10|11|1|1000.000|-1000.000|0.000|0.000|-500000.000|600009.000|t|t|t
 -NOTICE:  The rasters (pixel corner coordinates) are not aligned
 -t|f|t
 GDAL Warp API
 GDAL Warp API
 GDAL Warp API
  ### /tmp/pgis_reg/test_51_diff ###
 --- rt_asraster_expected        2018-04-06 05:05:52.000000000 +0000
 +++ /tmp/pgis_reg/test_51_out   2018-05-07 20:41:44.119707831 +0000
 @@ -10,55 +10,4 @@
  NOTICE:  The geometry's SRID (993310) is not the same as the raster's
 SRID (992163).  The geometry will be transformed to the raster's
 projection
 projection
 projection
 -NOTICE:  The rasters have different scales on the X axis
 -1.0||||||||||||||||
 -1.1|993310|100|100|1|1406.537|-869.114|0.000|0.000|-175453.086|114987.661|8BUI|0.000|t|1.000|1.000|
 -1.10|993310|141|87|1|1000.000|-1000.000|0.000|0.000|-175453.086|114987.661|32BF|0.000|t|1.000|1.000|
 -1.11|993310|100|100|1|1406.537|-869.114|0.000|0.000|-175453.086|114987.661|8BSI|0.000|t|1.000|1.000|
 -1.12|993310|100|100|1|1406.537|-869.114|0.000|0.000|-175453.086|114987.661|16BUI|0.000|t|1.000|1.000|
 -1.13|993310|100|100|1|1406.537|-869.114|0.000|0.000|-175453.086|114987.661|32BF|0.000|t|255.000|255.000|
 -1.14|993310|100|100|1|1406.537|-869.114|0.000|0.000|-175453.086|114987.661|32BF|1.000|t|255.000|255.000|
 -1.15|993310|100|100|1|1406.537|-869.114|0.000|0.000|-175453.086|114987.661|8BUI|0.000|t|1.000|1.000|
 -1.16|993310|100|100|1|1406.537|-869.114|0.000|0.000|-175453.086|114987.661|32BF||t|0.000|255.000|
 -1.17|993310|141|87|2|1000.000|-1000.000|0.000|0.000|-175453.086|114987.661|32BF||t|0.000|255.000|
 -1.18|993310|10|10|2|14065.366|-8691.142|0.000|0.000|-175453.086|114987.661|8BUI|0.000|t|255.000|255.000|
 -1.19|993310|141|87|3|1000.000|-1000.000|0.000|0.000|-175453.086|114987.661|32BF||t|0.000|255.000|
 -1.2|993310|1407|869|1|100.000|-100.000|0.000|0.000|-175453.086|114987.661|8BUI|0.000|t|1.000|1.000|
 -1.20|993310|141|87|2|1000.000|-1000.000|0.000|0.000|-175453.086|114987.661|1BB|1.000|f|||
 -1.3|993310|500|500|1|281.307|-173.823|0.000|0.000|-175453.086|114987.661|8BUI|0.000|t|1.000|1.000|
 -1.4|993310|141|87|1|1000.000|-1000.000|0.000|0.000|-175453.086|114987.661|8BUI|0.000|t|1.000|1.000|
 -1.5|993310|141|87|1|1000.000|-1000.000|0.000|0.000|-175453.086|114987.661|8BSI|0.000|t|1.000|1.000|
 -1.6|993310|141|87|1|1000.000|-1000.000|0.000|0.000|-175453.086|114987.661|16BUI|0.000|t|1.000|1.000|
 -1.7|993310|1407|869|1|100.000|-100.000|0.000|0.000|-175453.086|114987.661|32BF|0.000|t|1.000|1.000|
 -1.8|993310|141|87|1|1000.000|-1000.000|0.000|0.000|-175453.086|114987.661|8BSI|0.000|t|1.000|1.000|
 -1.9|993310|141|87|1|1000.000|-1000.000|0.000|0.000|-175453.086|114987.661|16BUI|0.000|t|1.000|1.000|
 -2.0||||||||||||||||
 -2.1||||||||||||||||
 -2.2|993310|141|87|1|1000.000|-1000.000|0.000|0.000|-175400.000|115000.000|8BUI|0.000|t|255.000|255.000|
 -2.3|993310|141|87|1|1000.000|-1000.000|0.000|0.000|-170000.000|114988.000|8BUI|0.000|t|255.000|255.000|
 -2.4|993310|141|87|1|1000.000|-1000.000|0.000|0.000|-170000.000|110000.000|8BUI|0.000|t|255.000|255.000|
 -2.5|993310|141|87|1|1000.000|-1000.000|0.000|0.000|-179000.000|119000.000|8BUI|0.000|t|255.000|255.000|
 -2.6|993310|100|100|1|1406.537|-869.114|0.000|0.000|-179000.000|119000.000|8BUI|0.000|t|255.000|255.000|
 -2.7|993310|100|100|1|1406.537|-869.114|0.000|0.000|-179000.000|119000.000|8BUI|0.000|t|255.000|255.000|
 -3.0||||||||||||||||
 -3.1|993310|100|100|1|1406.537|-869.114|0.000|0.000|-175453.086|114987.661|8BUI|0.000|t|255.000|255.000|
 -3.2|993310|100|100|1|1406.537|-869.114|0.000|0.000|-175453.086|114987.661|8BUI|0.000|t|255.000|255.000|
 -3.3|993310|100|100|1|1406.537|-869.114|1.000|0.000|-175565.609|114987.661|8BUI|0.000|t|255.000|255.000|
 -3.4|993310|100|100|1|1406.537|-869.114|0.000|1.000|-175453.086|114987.661|8BUI|0.000|t|255.000|255.000|
 -3.5|993310|101|101|1|1406.537|-869.114|10.000|-5.000|-176465.793|115491.747|8BUI|0.000|t|255.000|255.000|
 -3.6|993310|100|101|1|1406.537|-869.114|-5.000|10.000|-175453.086|114987.661|8BUI|0.000|t|255.000|255.000|
 -4.0||||||||||||||||
 -4.1|992163|150|117|1|1000.000|-1000.000|0.000|0.000|-1898000.000|-412000.000|8BUI|0.000|t|1.000|1.000|t
 -4.10|993310|142|88|1|1000.000|-1000.000|0.000|0.000|-176100.000|115100.000|16BUI|0.000|t|13.000|13.000|f
 -4.11|993310|142|88|1|1000.000|-1000.000|0.000|0.000|-176100.000|115100.000|16BUI|0.000|t|13.000|13.000|f
 -4.2|992163|150|117|1|1000.000|-1000.000|0.000|0.000|-1898000.000|-412000.000|64BF|0.000|t|1.000|1.000|t
 -4.3|992163|150|117|1|1000.000|-1000.000|0.000|0.000|-1898000.000|-412000.000|16BUI|0.000|t|13.000|13.000|t
 -4.4|992163|150|117|1|1000.000|-1000.000|0.000|0.000|-1898000.000|-412000.000|16BUI||t|0.000|13.000|t
 -4.5|992163|150|117|1|1000.000|-1000.000|0.000|0.000|-1898000.000|-412000.000|16BUI|0.000|t|13.000|13.000|t
 -4.6|992163|150|117|1|1000.000|-1000.000|0.000|0.000|-1898000.000|-412000.000|16BUI||t|0.000|13.000|t
 -4.7|992163|150|117|1|1000.000|-1000.000|0.000|0.000|-1898000.000|-412000.000|16BUI|0.000|t|13.000|13.000|t
 -4.8|993310|142|88|1|1000.000|-1000.000|0.000|0.000|-176000.000|115000.000|16BUI|0.000|t|13.000|13.000|f
 -4.9|993310|142|88|1|1000.000|-1000.000|0.000|0.000|-176453.000|115987.000|16BUI|0.000|t|13.000|13.000|f
 I think we can close this issue because `test_gdal_configured` succeeds
 now, and leave the two failures for another time/ticket.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4078#comment:8>
