[postgis-tickets] [PostGIS] #4077: st_removerepeatedpoints regression
PostGIS trac at osgeo.org
Tue May 8 05:33:30 PDT 2018
  Reporter:  nicklas  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by pramsey):
 Hm, well I never see the error case in my tests on 2.4 svn tip. I *do* see
 an inconsistency in the handling of polygon in 2.4, which is that your
 test returns NULL for polygon but empty for multipolygon in 2.4. In trunk
 the correct things happen. I will do a little code read and see if maybe
 we're mishandling memory in the 2.4 repeated points empty handling, which
 might cause an intermittent failure?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4077#comment:1>
