[postgis-tickets] [PostGIS] #4099: upgrade script failing on winnie
PostGIS trac at osgeo.org
Thu May 31 12:38:43 PDT 2018
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  PostGIS 2.5.0
Component:  buildbots  |    Version:  trunk
 Keywords:             |
 TMPDIR is /projects/postgis/tmp/2.5.0dev_pg10_geos3.7.0dev_gdal2.2.4w64
 Creating database 'postgis_reg'
 Preparing db 'postgis_reg' using: CREATE EXTENSION postgis
 Died at run_test.pl line 1300.
  failed (Error encountered creating EXTENSION POSTGIS:
 /projects/postgis/tmp/2.5.0dev_pg10_geos3.7.0dev_gdal2.2.4w64/regress_log)
 sh: createlang: command not found
 ERROR:  extension "postgis" has no installation script nor update path for
 version "2.5.0beta1dev"
 Makefile:307: recipe for target 'check' failed
 make[1]: *** [check] Error 1
 make[1]: Leaving directory '/projects/postgis/branches/2.5/regress'
 GNUmakefile:16: recipe for target 'check' failed
 make: *** [check] Error 1
 e:\jenkins\postgis>exit 2
 Build step 'Execute Windows batch command' marked build as failure
 An attempt to send an e-mail to empty list of recipients, ignored.
 Triggering a new build of PG_ED_STOP
 Finished: FAILURE
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4099>
