[postgis-tickets] [PostGIS] #4194: proj_api.h does not exist
PostGIS trac at osgeo.org
Tue Oct 2 21:01:17 PDT 2018
 Reporter:  robe     |      Owner:  robe
     Type:  defect   |     Status:  assigned
 Priority:  blocker  |  Milestone:  PostGIS 2.4.6
Component:  postgis  |    Version:  2.4.x
 Keywords:           |
 I've suddenly starting getting this error on winnie.
 make[2]: Entering directory '/projects/postgis/branches/3.0/loader/cunit'
 x86_64-w64-mingw32-gcc -Wall -Wmissing-prototypes -std=gnu99 -Wall -fno-
 omit-frame-pointer -fno-math-errno -fno-signed-zeros  -I/projects/rel-
 libiconv-1.13.1w64gcc48/include
 -I/projects/postgresql/rel/pg10w64gcc48/include -I/projects/rel-
 libiconv-1.13.1w64gcc48/include -I.. -mms-bitfields
 -IE:/jenkins/gtkw64gcc48/include/gtk-2.0
 -IE:/jenkins/gtkw64gcc48/lib/gtk-2.0/include
 -IE:/jenkins/gtkw64gcc48/include/atk-1.0
 -IE:/jenkins/gtkw64gcc48/include/cairo -IE:/jenkins/gtkw64gcc48/include
 /gdk-pixbuf-2.0 -IE:/jenkins/gtkw64gcc48/include/pango-1.0
 -IE:/jenkins/gtkw64gcc48/include/glib-2.0
 -IE:/jenkins/gtkw64gcc48/lib/glib-2.0/include
 -IE:/jenkins/gtkw64gcc48/include/pixman-1 -IE:/jenkins/gtkw64gcc48/include
 -IE:/jenkins/gtkw64gcc48/include/freetype2
 -IE:/jenkins/gtkw64gcc48/include/libpng14
 -IE:/jenkins/postgresql/rel/pg10w64gcc48/include -c -o cu_pgsql2shp.o
 cu_pgsql2shp.c
 -IE:/jenkins/postgresql/rel/pg10w64gcc48/include -c -o cu_shp2pgsql.o
 cu_shp2pgsql.c
 In file included from ../../liblwgeom/liblwgeom_internal.h:48:0,
                  from ../../liblwgeom/stringbuffer.h:30,
                  from ../shp2pgsql-core.h:30,
                  from cu_shp2pgsql.c:14:
 ../../liblwgeom/liblwgeom.h:35:22: fatal error: proj_api.h: No such file
 or directory
  #include "proj_api.h"
 compilation terminated.
 Makefile:87: recipe for target 'cu_shp2pgsql.o' failed
 make[2]: *** [cu_shp2pgsql.o] Error 1
 make[2]: Leaving directory '/projects/postgis/branches/3.0/loader/cunit'
 Makefile:156: recipe for target 'check' failed
 make[1]: *** [check] Error 2
 make[1]: Leaving directory '/projects/postgis/branches/3.0/loader'
 GNUmakefile:16: recipe for target 'check' failed
 make: *** [check] Error 1
  What's weird is everything runs fine until it get to regress of loader so
 I definitely have proj but the loader is not seeing it.
 PostgreSQL 10.4, compiled by Visual C++ build 1800, 64-bit
   Postgis 3.0.0dev - r16871 - 2018-10-02 13:50:23
   scripts 3.0.0dev r16871
   GEOS: 3.7.0-CAPI-1.11.0 3.7.0
   PROJ: Rel. 4.9.3, 15 August 2016
 Running tests
  regress/legacy_validate .. ok
  regress/legacy_predicate .. ok
  regress/legacy_invalid .. ok
  regress/sqlmm .. ok
  regress/legacy_query .. ok
  regress/addnode .. ok
  regress/addedge .. ok
  regress/addface .. ok
  regress/addface2.5d .. ok
  regress/addtopogeometrycolumn .. ok
  regress/polygonize .. ok
  regress/st_addisoedge .. ok
  regress/st_addisonode .. ok
  regress/st_addedgemodface .. ok
  regress/st_addedgenewfaces .. ok
  regress/st_changeedgegeom .. ok
  regress/st_createtopogeo .. ok
  regress/st_getfacegeometry .. ok
  regress/st_getfaceedges .. ok
  regress/st_modedgeheal .. ok
  regress/st_modedgesplit .. ok
  regress/st_newedgeheal .. ok
  regress/st_newedgessplit .. ok
  regress/st_remedgenewface .. ok
  regress/st_remedgemodface .. ok
  regress/st_simplify .. ok
  regress/topoelement .. ok
  regress/topoelementarray_agg .. ok
  regress/topogeo_addlinestring .. ok
  regress/topogeo_addpoint .. ok
  regress/topogeo_addpolygon .. ok
  regress/topogeom_edit .. ok
  regress/topogeometry_type .. ok
  regress/topojson .. ok
  regress/topologysummary .. ok
  regress/topo2.5d .. ok
  regress/totopogeom .. ok
  regress/droptopology .. ok
  regress/droptopogeometrycolumn .. ok
  regress/copytopology .. ok
  regress/createtopogeom .. ok
  regress/createtopology .. ok
  regress/gml .. ok
  regress/getnodebypoint .. ok
  regress/getedgebypoint .. ok
  regress/getfacebypoint .. ok
  regress/getringedges .. ok
  regress/gettopogeomelements .. ok
  regress/layertrigger .. ok
  regress/validatetopology .. ok
  uninstall .  /projects/postgis/branches/3.0/regress/00-regress-
 install/share/contrib/postgis/uninstall_topology.sql
 install/share/contrib/postgis/uninstall_postgis.sql
 . ok (4663)
 Run tests: 51
 Failed: 0
 make[2]: Leaving directory '/projects/postgis/branches/3.0/topology/test'
 make[1]: Leaving directory '/projects/postgis/branches/3.0/topology'
 ---- Making check in loader
 make[1]: Entering directory '/projects/postgis/branches/3.0/loader'
 make -C cunit check
 cu_pgsql2shp.c
 cu_shp2pgsql.c
 or directory
 Looks like recent changes happened to loader at r16863 for #4189 pull
 request - https://github.com/postgis/postgis/pull/310 which I think got
 committed to all stable branches
 Unfortunately I was in middle of making changes myself so winnie has been
 failing for other reasons.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4194>
