[postgis-tickets] r16876 - St_AsMVTGeom: Handle type changes in geometry collections
Raul raul at rmr.ninja
Wed Oct 3 03:52:58 PDT 2018
Author: algunenano
Date: 2018-10-03 03:52:58 -0700 (Wed, 03 Oct 2018)
New Revision: 16876
   trunk/postgis/mvt.c
   trunk/regress/mvt.sql
   trunk/regress/mvt_expected
References #4181
Modified: trunk/postgis/mvt.c
--- trunk/postgis/mvt.c	2018-10-03 10:17:43 UTC (rev 16875)
+++ trunk/postgis/mvt.c	2018-10-03 10:52:58 UTC (rev 16876)
@@ -788,6 +788,39 @@
 	POSTGIS_DEBUGF(3, "parse_values n_tags %zd", ctx->feature->n_tags);
+/* For a given geometry, look for the highest dimensional basic type, that is,
+ * point, line or polygon */
+static uint8
+lwgeom_get_basic_type(LWGEOM *geom)
+	switch(geom->type)
+	case POINTTYPE:
+	case LINETYPE:
+	case POLYGONTYPE:
+		return geom->type;
+	case MULTIPOINTTYPE:
+	case MULTILINETYPE:
+	case MULTIPOLYGONTYPE:
+		return geom->type - 3; /* Based on LWTYPE positions */
+	case COLLECTIONTYPE:
+		uint32_t i;
+		uint8 type = 0;
+		LWCOLLECTION *g = (LWCOLLECTION*)geom;
+		for (i = 0; i < g->ngeoms; i++)
+			LWGEOM *sg = g->geoms[i];
+			type = Max(type, lwgeom_get_basic_type(sg));
+		return type;
+	default:
+		elog(ERROR, "%s: Invalid type (%d)", __func__, geom->type);
  * In place process a collection to find a concrete geometry
  * object and expose that as the actual object. Will some
@@ -795,27 +828,12 @@
  * draw it anyways.
 static void
-lwgeom_to_basic_type(LWGEOM *geom)
+lwgeom_to_basic_type(LWGEOM *geom, uint8 original_type)
 	if (lwgeom_get_type(geom) == COLLECTIONTYPE)
-		/* MVT doesn't handle generic collections, so we */
-		/* need to strip them down to a typed collection */
-		/* by finding the largest basic type available and */
-		/* using that as the basis of a typed collection. */
-		LWCOLLECTION *gc;
-		uint32_t i, maxtype = 0;
-		for (i = 0; i < g->ngeoms; i++)
-			LWGEOM *sg = g->geoms[i];
-			if (sg->type > maxtype && sg->type < COLLECTIONTYPE)
-				maxtype = sg->type;
-		if (maxtype > 3) maxtype -= 3;
-		/* Force the working geometry to be a simpler version */
-		/* of itself */
-		gc = lwcollection_extract(g, maxtype);
+		LWCOLLECTION *gc = lwcollection_extract(g, original_type);
 		*g = *gc;
@@ -837,6 +855,7 @@
 	double height = gbox->ymax - gbox->ymin;
 	double resx, resy, res, fx, fy;
 	int preserve_collapsed = LW_TRUE;
+	const uint8_t basic_type = lwgeom_get_basic_type(lwgeom);
 	POSTGIS_DEBUG(2, "mvt_geom called");
 	/* Short circuit out on EMPTY */
@@ -855,13 +874,12 @@
 	fx = extent / width;
 	fy = -(extent / height);
-	if (FLAGS_GET_BBOX(lwgeom->flags) && lwgeom->bbox &&
-		(lwgeom->type == LINETYPE || lwgeom->type == MULTILINETYPE ||
-		lwgeom->type == POLYGONTYPE || lwgeom->type == MULTIPOLYGONTYPE))
+	if (basic_type == LINETYPE || basic_type == POLYGONTYPE)
 		// Shortcut to drop geometries smaller than the resolution
-		double bbox_width = lwgeom->bbox->xmax - lwgeom->bbox->xmin;
-		double bbox_height = lwgeom->bbox->ymax - lwgeom->bbox->ymin;
+		const GBOX *lwgeom_gbox = lwgeom_get_bbox(lwgeom);
+		double bbox_width = lwgeom_gbox->xmax - lwgeom_gbox->xmin;
+		double bbox_height = lwgeom_gbox->ymax - lwgeom_gbox->ymin;
 		if (bbox_height * bbox_height + bbox_width * bbox_width < res * res)
 			return NULL;
@@ -904,9 +922,7 @@
 			/* For some polygons, the simplify step might have left them
 			 * as invalid, which can cause clipping to return the complementary
 			 * geometry of what it should */
-			if ((lwgeom->type == POLYGONTYPE ||
-				lwgeom->type == MULTIPOLYGONTYPE ||
-				lwgeom->type == COLLECTIONTYPE) &&
+			if ((basic_type == POLYGONTYPE) &&
 			    !gbox_contains_2d(&pre_clip_box, lwgeom_get_bbox(clipped_geom)))
 				/* TODO: Adapt this when and if Exception Policies are introduced.
@@ -942,22 +958,11 @@
 		return NULL;
-	if (lwgeom->type == POLYGONTYPE ||
+	if (basic_type == POLYGONTYPE)
 		/* Force validation as per MVT spec */
 		lwgeom = lwgeom_make_valid(lwgeom);
-		/* Drop type changes tp play nice with MVT renderers */
-		if (!(lwgeom->type == POLYGONTYPE ||
-			lwgeom->type == COLLECTIONTYPE))
-			lwgeom_free(lwgeom);
-			return NULL;
 		/* In image coordinates CW actually comes out a CCW, so we reverse */
 		lwgeom_force_clockwise(lwgeom);
 		lwgeom_reverse_in_place(lwgeom);
@@ -965,8 +970,15 @@
 	/* if geometry collection extract highest dimensional geometry type */
 	if (lwgeom->type == COLLECTIONTYPE)
-		lwgeom_to_basic_type(lwgeom);
+		lwgeom_to_basic_type(lwgeom, basic_type);
+	if (basic_type != lwgeom_get_basic_type(lwgeom))
+		/* Drop type changes to play nice with MVT renderers */
+		POSTGIS_DEBUG(3, "mvt_geom: Dropping geometry after type change");
+		return NULL;
 	if (lwgeom == NULL || lwgeom_is_empty(lwgeom))
 		return NULL;
Modified: trunk/regress/mvt.sql
--- trunk/regress/mvt.sql	2018-10-03 10:17:43 UTC (rev 16875)
+++ trunk/regress/mvt.sql	2018-10-03 10:52:58 UTC (rev 16876)
@@ -273,6 +273,14 @@
 	16,
 	true));
+-- Geometry type change of one geometry of the multipolygon used to fallback to multilinestring
+SELECT 'PG46', St_AsEWKT(ST_AsMVTGeom(
+	'SRID=3857;MULTIPOLYGON(((-8230324.85567616 4984496.35685962,-8230307.1114228 4984654.46474466,-8230285.21085987 4984959.60349704,-8230324.85567616 4984496.35685962)),((-8230327.54013683 4984444.33052449,-8230327.23971431 4984450.39401942,-8230327.26833036 4984449.87731981,-8230327.54013683 4984444.33052449)))'::geometry,
+	'SRID=3857;POLYGON((-8238077.16046316 4989809.20645631,-8238077.16046316 4980025.2668358,-8228293.22084265 4980025.2668358,-8228293.22084265 4989809.20645631,-8238077.16046316 4989809.20645631))'::geometry,
+	4096,
+	16,
+	true));
 -- geometry encoding tests
 SELECT 'TG1', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1,
 	ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
@@ -433,13 +441,13 @@
 	FROM (SELECT NULL::integer AS c1, NULL AS geom) AS q;
 -- Ticket #3922
-SELECT '#3922', length(bytea(ST_AsMVTGeom(
+SELECT '#3922', St_AsEWKT(ST_AsMVTGeom(
 		st_geomfromtwkb('\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'),
 		'SRID=3347;POLYGON((3658201 658873,3658201 5958872.97428571,8958201.49428571 5958872.97428571,8958201.49428571 658873,3658201 658873))'::geometry,
 		4096,
 		0,
 		true
 -- Feature id encoding tests
Modified: trunk/regress/mvt_expected
--- trunk/regress/mvt_expected	2018-10-03 10:17:43 UTC (rev 16875)
+++ trunk/regress/mvt_expected	2018-10-03 10:52:58 UTC (rev 16876)
@@ -48,6 +48,7 @@
 PG43 - OFF|MULTIPOLYGON(((5 5,-1 -1,11 -1,5 5)),((5 5,11 11,-1 11,5 5)))
 PG44|
 PG45|
+PG46|SRID=3857;MULTIPOLYGON(((3245 2224,3262 2030,3253 2158,3245 2224)))
 TG1|GiEKBHRlc3QSDBICAAAYASIECTLePxoCYzEiAigBKIAgeAI=
 TG2|GiMKBHRlc3QSDhICAAAYASIGETLePwIBGgJjMSICKAEogCB4Ag==
 TG3|GiYKBHRlc3QSERICAAAYAiIJCQCAQArQD88PGgJjMSICKAEogCB4Ag==
@@ -97,7 +98,7 @@
 TU2
 ERROR:  pgis_asmvt_transfn: parameter row cannot be other than a rowtype
 TU3|
-#3922|91
+#3922|MULTIPOLYGON(((2613 3664,2615 3662,2616 3662,2617 3665,2615 3665,2615 3664,2613 3664)))
 FI1|GicKBHRlc3QSDggBEgIAABgBIgQJMt4/GgJjMiIGCgRhYmNkKIAgeAI=
 FI2|GicKBHRlc3QSDggBEgIAABgBIgQJMt4/GgJjMiIGCgRhYmNkKIAgeAI=
 FI3|GicKBHRlc3QSDggBEgIAABgBIgQJMt4/GgJjMiIGCgRhYmNkKIAgeAI=
