[postgis-tickets] [PostGIS] #2503: ERROR: table "topology" is not a member of the extension being created
PostGIS trac at osgeo.org
Wed Oct 10 13:15:29 PDT 2018
  Reporter:  strk                   |      Owner:  robe
      Type:  defect                 |     Status:  reopened
  Priority:  medium                 |  Milestone:  PostGIS 2.1.1
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:  extension
Changes (by strk):
 * status:  closed => reopened
 * version:  2.1.x => trunk
 * resolution:  invalid =>
Comment:
 I'm reopening this because I'm seeing this error again now as part of
 `postgis_extensions_upgrade` call, while I'm adding re-packaging feature
 in it (see #4197).
 The workflow in this case is:
  createdb x
  psql -f postgis/postgis.sql x
  psql -f spatial_ref_sys.sql x
  psql -f topology/topology.sql x
  psql -c 'create extension postgis from unpackaged' x
  psql -c 'create extension postgis_topology from unpackaged' x
 Again, I fail to see why the above should not work...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2503#comment:13>
