[postgis-tickets] r16880 - Have postgis_extensions_upgrade() package unpackaged extensions
Sandro Santilli strk at kbt.io
Wed Oct 10 01:36:51 PDT 2018
Author: strk
Date: 2018-10-10 13:36:51 -0700 (Wed, 10 Oct 2018)
New Revision: 16880
   trunk/doc/reference_management.xml
   trunk/postgis/postgis.sql.in
See #4196
NOTE: it doesn't re-package tiger geocoder because I would not
      know how to tell if the support for it is installed and
      it does't re-package topology due to bug #2503
Modified: trunk/doc/reference_management.xml
--- trunk/doc/reference_management.xml	2018-10-08 23:19:50 UTC (rev 16879)
+++ trunk/doc/reference_management.xml	2018-10-10 20:36:51 UTC (rev 16880)
@@ -348,9 +348,10 @@
 	  <refnamediv>
 		<refname>PostGIS_Extensions_Upgrade</refname>
-		<refpurpose>Upgrades installed postgis packaged extensions (e.g. postgis_sfcgal, postgis_topology, postgis_sfcgal)
-		to latest installed version. Reports full postgis version and build configuration
-		infos after.</refpurpose>
+		<refpurpose>
+Packages and upgrades postgis extensions (e.g. postgis_sfcgal,
+postgis_topology, postgis_sfcgal) to latest available version.
+    </refpurpose>
 	  </refnamediv>
 	  <refsynopsisdiv>
@@ -366,17 +367,18 @@
 	  <refsection>
 		<title>Description</title>
-		<para>Upgrades installed postgis packaged extensions
-		to latest installed version. Only extensions you have installed in the database will be upgraded and if they are already at last installed version,
-		they will not be upgraded. Reports full postgis version and build configuration
-		infos after.  This is short-hand for doing multiple ALTER EXTENSION .. UPDATE for each postgis extension.
+		<para>Packages and upgrades postgis extensions
+		to latest version. Only extensions you have installed in the
+    database will be packaged and upgraded if needed.
+		Reports full postgis version and build configuration infos after.
+    This is short-hand for doing multiple CREATE EXTENSION .. FROM
+    unpackaged and ALTER EXTENSION .. UPDATE for each postgis extension.
 		Currently only tries to upgrade extensions postgis,
     postgis_raster, postgis_sfcgal, postgis_topology, and postgis_tiger_geocoder.</para>
 		<para>Availability: 2.5.0</para>
 		<note>
-			<para>Changed: 3.0.0 to support separate postgis_raster extension
-				and repackage loose raster functions into postgis_raster.</para>
+			<para>Changed: 3.0.0 to repackage loose extensions and support postgis_raster.</para>
 		</note>
 	  </refsection>
@@ -385,15 +387,19 @@
 		<programlisting>SELECT PostGIS_Extensions_Upgrade();</programlisting>
 <screen>
-NOTICE:  ALTER EXTENSION postgis_tiger_geocoder UPDATE TO "2.5.0dev";
-NOTICE:  ALTER EXTENSION postgis_topology UPDATE TO "2.5.0dev";
+NOTICE:  Packaging extension postgis
+NOTICE:  Packaging extension postgis_raster
+NOTICE:  Packaging extension postgis_sfcgal
+NOTICE:  Extension postgis_topology is not available or not packagable for some reason
+NOTICE:  Extension postgis_tiger_geocoder is not available or not packagable for some reason
-POSTGIS="2.5.0dev r15966" [EXTENSION] PGSQL="100"
-GEOS="3.7.0dev-CAPI-1.11.0 8fe2ce6" SFCGAL="1.3.1"
-PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.2.2, released 2017/09/15"
-LIBXML="2.7.8" LIBJSON="0.12" LIBPROTOBUF="1.2.1" TOPOLOGY RASTER
+POSTGIS="3.0.0dev r16878" [EXTENSION] PGSQL="96"
+GEOS="3.8.0dev-CAPI-1.11.0 a67b6f86" SFCGAL="1.3.5" PROJ="Rel. 4.9.3,
+15 August 2016" GDAL="GDAL 2.3.0dev, released 2017/99/99"
+LIBXML="2.9.4" LIBJSON="0.12.1" LIBPROTOBUF="1.2.1" TOPOLOGY
+[UNPACKAGED!] RASTER
 (1 row)</screen>
 	  </refsection>
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in	2018-10-08 23:19:50 UTC (rev 16879)
+++ trunk/postgis/postgis.sql.in	2018-10-10 20:36:51 UTC (rev 16880)
@@ -2825,51 +2825,78 @@
 AS $$
 DECLARE rec record; sql text; var_schema text;
 BEGIN
-	-- if at a version different from default version or we are at a dev version,
-	-- then do an upgrade to default version
-	FOR rec in SELECT  name, default_version, installed_version
-		FROM pg_available_extensions
-		WHERE installed_version > '' AND name IN(
+	FOR rec IN
+		SELECT name, default_version, installed_version
+		FROM pg_catalog.pg_available_extensions
+		WHERE name IN (
 			'postgis',
 			'postgis_raster',
 			'postgis_sfcgal',
-			'postgis_tiger_geocoder',
-			'postgis_topology')
-		AND ( default_version <> installed_version  OR
-			( default_version = installed_version AND
-				default_version ILIKE '%dev%' AND
-				installed_version ILIKE '%dev%' ) )
+			'postgis_topology',
+			'postgis_tiger_geocoder'
+		ORDER BY length(name) -- this is to make sure 'postgis' is first !
 	LOOP
+		IF rec.installed_version IS NULL THEN
+			-- If the support installed by available extension
+			-- is found unpackaged, we package it
+			IF
+				 -- PostGIS is always available (this function is part of it)
+				 rec.name = 'postgis'
-		-- we need to upgrade to next so our installed is different from current
-		-- and then we can upgrade to default_version
-		IF rec.installed_version = rec.default_version THEN
-			sql = 'ALTER EXTENSION ' || rec.name || ' UPDATE TO ' || quote_ident(rec.default_version || 'next')   || ';';
-			EXECUTE sql;
-			RAISE NOTICE '%', sql;
-		END IF;
+				 -- PostGIS raster is available if type 'raster' exists
+				 OR ( rec.name = 'postgis_raster' AND EXISTS (
+							SELECT 1 FROM pg_catalog.pg_type
+							WHERE typname = 'raster' ) )
-		sql = 'ALTER EXTENSION ' || rec.name || ' UPDATE TO ' || quote_ident(rec.default_version)   || ';';
-		EXECUTE sql;
+				 -- PostGIS SFCGAL is availble if
+				 -- 'postgis_sfcgal_version' function exists
+				 OR ( rec.name = 'postgis_sfcgal' AND EXISTS (
+							SELECT 1 FROM pg_catalog.pg_proc
+							WHERE proname = 'postgis_sfcgal_version' ) )
-		-- If postgis raster functions still exist, but postgis_raster extension is not installed
-		-- then repackage as postgis_raster
-		IF rec.name = 'postgis'
-			AND NOT EXISTS(SELECT 1 FROM pg_extension WHERE extname='postgis_raster')
-			AND EXISTS(SELECT 1 FROM pg_proc WHERE proname LIKE 'raster%') THEN
-			SELECT n.nspname INTO var_schema
-				FROM pg_catalog.pg_extension AS e
-					INNER JOIN pg_catalog.pg_namespace AS n ON e.extnamespace = n.oid
-			WHERE e.extname = 'postgis';
+				 -- PostGIS Topoology is available if
+				 -- 'topology.topology' table exists
+				 -- NOTE: disabled due to https://trac.osgeo.org/postgis/ticket/2503
+				 OR ( FALSE AND rec.name = 'postgis_topology' AND EXISTS (
+							SELECT 1 FROM pg_catalog.pg_class c
+							JOIN pg_catalog.pg_namespace n ON (c.relnamespace = n.oid )
+							WHERE n.nspname = 'topology' AND c.relname = 'topology') )
-			sql = 'CREATE EXTENSION postgis_raster FROM unpackaged SCHEMA ' || quote_ident(var_schema) || ';';
+				 -- TODO: How do we tell if PostGIS Tiger Geocoder is available  ?
+			THEN
+				sql = 'CREATE EXTENSION ' || rec.name || ' FROM unpackaged';
+				RAISE NOTICE 'Packaging extension %', rec.name;
+				RAISE DEBUG '%', sql;
+				EXECUTE sql;
+			ELSE
+				RAISE NOTICE 'Extension % is not available or not packagable for some reason', rec.name;
+			END IF;
+		ELSIF rec.default_version > rec.installed_version
+		THEN
+			sql = 'ALTER EXTENSION ' || rec.name || ' UPDATE TO ' ||
+						quote_ident(rec.default_version)   || ';';
+			RAISE NOTICE 'Updating extension % from % to %',
+				rec.name, rec.installed_version, rec.default_version;
 			EXECUTE sql;
+		ELSIF rec.default_version = rec.installed_version AND
+					rec.installed_version ILIKE '%dev%'
+		THEN
+			-- we need to upgrade to next and back
+			RAISE NOTICE 'Updating dev extension % %',
+				rec.name, rec.installed_version;
+						quote_ident(rec.default_version || 'next')   || ';';
+			EXECUTE sql;
+			EXECUTE sql;
 		END IF;
 	END LOOP;
 	RETURN @extschema at .postgis_full_version();
