[postgis-tickets] [PostGIS] #4200: move core regress tests under regress/core
PostGIS trac at osgeo.org
Sat Oct 13 13:52:15 PDT 2018
 Reporter:  strk                   |      Owner:  strk
     Type:  enhancement            |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.0.0
Component:  build/upgrade/install  |    Version:  trunk
 Keywords:                         |
 This is to allow running core-only tests w/out necessarely _also_ running
 sfcgal tests, which is currently impossible with a "make check" call
 (there's no isolated directory for them).
 My proposal is to have:
  regress/core
  regress/sfcgal
 Then the Makefile in regress/ would descend in both if sfcgal is enabled
 and only in core otherwise. Users willing to only run core tests can do:
  make -C regress/core check
 This is particularly useful for running upgrade tests (see
 utils/check_all_upgrades) when sfcgal was not available in source release.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4200>
