[postgis-tickets] r16892 - Remove unused file
Sandro Santilli strk at kbt.io
Sun Oct 14 12:31:41 PDT 2018
Author: strk
Date: 2018-10-14 00:31:40 -0700 (Sun, 14 Oct 2018)
New Revision: 16892
Removed:
   trunk/regress/isvalid_test
Remove unused file
Deleted: trunk/regress/isvalid_test
--- trunk/regress/isvalid_test	2018-10-12 21:24:45 UTC (rev 16891)
+++ trunk/regress/isvalid_test	2018-10-14 07:31:40 UTC (rev 16892)
@@ -1,822 +0,0 @@
-BEGIN;
-CREATE TABLE "validtest" (
-	"g" geometry,
-	"result" boolean,
-	"comment" text
--- Data for TOC Entry ID 3 (OID 100237962)
--- Name: validtest Type: TABLE DATA Owner: dblasby
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(10 10)','t','P - point');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(10 10,20 20,30 30)','t','mP - no repeated points');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(10 10,20 20,30 30,10 10)','t','P - repeated points');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 180,120 120,140 200,200 140,240 200)','t','L - no repeated points');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 180,120 120,140 200,140 200,200 140,240 200)','t','L - repeated points');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(0 0,0 0)','f','L - linestring with two identical points ');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 0,0 0,0 0,0 0,0 0))','f','A - zero-area polygon ');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 0,10 0,20 0,0 0,0 0))','f','A - polygon with too few points ');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((107 246,107 246,250 285,294 137,151 90,15 125,157 174,107 246))','t','A - polygon with repeatd point ');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((100 20,180 20,180 100,100 100,100 20)),((20 100,100 100,100 180,20 180,20 100)),((100 180,180 180,180 260,100 260,100 180)),((180 100,180 180,180 180,180 100)))','f','mA - multipolygon with component with too few points ');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 40,0 0,40 40,40 0,0 40))','f','A - polygon self-intersects at non-vertex');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((0 40,20 20,40 0,40 40,20 20,0 0,0 40)))','f','A - polygon self-intersects at vertex');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 40,20 20,40 0,40 40,0 0,0 40))','f','A - polygon self-intersects at vertex/non-vertex');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((-10 50,50 50,50 -10,-10 -10,-10 50),(0 40,0 0,40 40,40 0,0 40))','f','A - hole self-intersects at non-vertex');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((-10 50,50 50,50 -10,-10 -10,-10 50),(0 40,20 20,40 0,40 40,20 20,0 0,0 40))','f','A - polygon self-intersects at vertex');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((-10 50,50 50,50 -10,-10 -10,-10 50),(0 40,20 20,40 0,40 40,0 0,0 40))','f','A - polygon self-intersects at vertex/non-vertex');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 60,0 0,60 0,60 60,0 60),(20 40,20 20,40 20,40 40,20 40))','t','A - Valid doughnut');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 60,0 0,0 0,60 0,60 60,0 60),(20 40,20 20,40 20,40 40,20 40))','t','A - shell has repeated points');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 60,0 0,60 0,60 60,0 60),(20 40,20 20,60 20,20 40))','t','A - shell touches hole without crossing it (valid)');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 60,0 0,60 0,60 60,0 60),(0 40,20 20,60 20,0 40))','f','A - shell touches hole without crossing it, but does so twice (invalid)');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 120,0 0,140 0,140 120,0 120),(100 100,100 20,120 20,120 100,100 100),(20 100,20 40,100 40,20 100))','t','A - hole touches hole without crossing it (valid)');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 120,0 0,140 0,140 120,0 120),(100 100,100 20,120 20,120 100,100 100),(20 100,20 40,100 40,80 60,100 80,20 100))','f','A - holel touches hole without crossing it, but does so twice (invalid)');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 120,0 0,140 0,140 120,0 120),(100 100,100 20,120 20,120 100,100 100),(20 100,20 40,100 40,100 80,20 100))','f','A - hole touches hole without crossing it, but does so at an infinite number of points (invalid)');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 60,0 0,60 0,60 20,100 20,60 20,60 60,0 60))','f','A - spike (invalid)');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 60,0 0,60 0,60 20,20 20,60 20,60 60,0 60))','f','A - puncture (invalid)');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 140,0 0,180 0,180 140,0 140),(20 20,160 20,160 120,20 120,20 20),(40 100,40 40,140 40,140 100,40 100))','f','A - hole within a hole (invalid)');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((60 280,260 180,60 80,60 280),(140 80,120 180,200 180,140 80))','f','A - hole overlapping shell at non-vertex');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((60 340,60 100,340 100,340 280,340 200,340 340,60 340))','f','A - shell self-overlaps ');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((40 260,40 60,120 60,180 160,240 60,300 60,300 260,40 260),(70 230,80 230,80 220,80 220,70 230))','t','A - hole with repeated points');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((40 260,40 60,120 60,180 160,240 60,300 60,300 260,40 260),(180 160,240 60,120 60,180 160))','f','A - hole outside but adjacent to shell');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((240 260,40 260,40 80,240 80,240 260),(140 180,40 180,140 260,140 180))','f','A - hole touches shell at two points');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((240 260,40 260,40 80,240 80,240 260),(140 180,40 180,140 240,140 180))','t','A - hole touches shell at one non-vertex point');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((240 260,40 260,40 80,240 80,240 260),(140 180,40 260,140 240,140 180))','t','A - hole touches shell at one vertex point');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 180,20 20,140 20,140 180,20 180),(160 120,180 100,160 80,160 120))','f','A - hole outside shell');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 180,20 20,140 20,140 180,20 180),(20 180,20 20,140 20,140 180,20 180))','f','A - hole identical to shell');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((380 340,40 340,40 20,380 20,380 340),(120 300,300 280,320 200,160 140,200 80,320 120,320 200,360 60,120 40,120 300))','f','A - hole self-intersects ');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 320,260 320,260 20,20 20,20 320),(140 280,80 100,200 100,140 280),(140 280,40 80,240 80,140 280))','f','A - holes overlap, first point is identical ');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 320,240 320,240 40,20 40,20 320),(140 180,60 120,60 240,140 180),(140 180,200 120,200 240,140 180))','t','A - holes do not overlap, first point is identical ');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((340 320,340 200,200 280,200 80,340 200,340 20,60 20,60 340,340 320))','f','A - shell self-touches at vertex ');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((300 320,300 220,260 260,180 220,360 220,360 140,120 140,120 320,300 320))','f','A - shell self-touches at non-vertex ');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((40 300,40 20,280 20,280 300,40 300),(120 240,80 180,160 220,120 240),(220 240,160 220,220 160,220 240),(160 100,80 180,100 80,160 100),(160 100,220 160,240 100,160 100))','f','A - chain of holes surrounds an island inside the polygon ');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((40 320,340 320,340 20,40 20,40 320),(100 120,40 20,180 100,100 120),(200 200,180 100,240 160,200 200),(260 260,240 160,300 200,260 260),(300 300,300 200,340 320,300 300))','f','A - chain of holes splits polygon in two (touching at vertices) ');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((40 320,340 320,340 20,40 20,40 320),(100 120,40 20,180 100,100 120),(200 200,180 100,240 160,200 200),(260 260,240 160,300 200,260 260),(300 300,300 200,340 260,300 300))','f','A - chain of holes splits polygon in two (touching at non-vertex) ');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((190 190,360 20,20 20,190 190),(90 50,150 110,190 50,90 50),(190 50,230 110,290 50,190 50))','t','A - holes touch in one point ');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((40 340,300 340,300 40,40 40,40 340),(180 260,100 120,240 100,180 260),(100 120,240 100,180 260,100 120))','f','A - duplicate holes ');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((40 120,140 120,140 40,40 40,40 120)),((140 120,40 120,40 200,140 200,140 120)))','f','mA - adjacent shells (shared vertices) ');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((40 120,140 120,140 40,40 40,40 120)),((160 120,60 120,40 200,140 200,160 120)))','f','mA - adjacent shells (different vertices) ');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((80 260,240 260,240 100,80 100,80 260)),((120 240,220 240,220 140,120 140,120 240)))','f','mA - nested overlapping shells ');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((60 320,60 80,300 80,60 320),(80 280,80 100,260 100,80 280)),((120 160,140 160,140 140,120 160)))','t','mA - nested non-overlapping shells ');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((20 380,420 380,420 20,20 20,20 380),(220 340,180 240,60 200,180 160,340 60,240 220,220 340)),((180 240,180 160,240 220,180 240)))','t','mA - nested non-overlapping shells, all vertices touch ');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((20 380,420 380,420 20,20 20,20 380),(220 340,180 240,60 200,140 100,340 60,300 240,220 340)),((60 200,340 60,220 340,60 200)))','f','mA - nested overlapping shells, all vertices touch ');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((20 380,420 380,420 20,20 20,20 380),(220 340,80 320,60 200,140 100,340 60,300 240,220 340)),((60 200,340 60,220 340,60 200)))','t','mA - nested non-overlapping shells, all vertices touch ');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((20 380,420 380,420 20,20 20,20 380),(220 340,180 240,60 200,200 180,340 60,240 220,220 340)),((60 200,340 60,220 340,60 200)))','f','mA - nested overlapping shells, all vertices touch ');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((100 20,180 20,180 100,100 100,100 20)),((20 100,100 100,100 180,20 180,20 100)),((100 180,180 180,180 260,100 260,100 180)),((180 100,260 100,260 180,180 180,180 100)))','t','mA - disconnected exterior ');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((110 110,70 200,150 200,110 110)),((110 110,150 20,70 20,110 110)))','t','mA - shells touch in single point ');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((60 300,320 220,260 60,60 100,60 300)),((60 300,320 220,260 60,60 100,60 300)))','f','mA - duplicate shells ');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((180 60,240 160,300 60,180 60)),((80 80,180 60,160 140,240 160,360 140,300 60,420 100,320 280,120 260,80 80)))','t','mA - shells are not nested but share all vertices ');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(-123456789 -40,381039468754763 123456789)','t','Test 1');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(0 0)','t','Test 2');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 20,20 100,120 100,140 20,20 20))','t','Test 3');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 20,140 20,120 100,20 100,20 20))','t','Test 4');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((120 100,140 20,20 20,20 100,120 100))','t','Test 5');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 100,60 100,120 100,140 20,80 20,20 20,20 100))','t','Test 6');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 0,80 0,80 80,0 80,0 0))','t','Test 7');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((100 200,100 140,180 140,180 200,100 200))','t','Test 8');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((140 120,160 20,20 20,20 120,140 120))','t','Test 9');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((140 120,140 200,240 200,240 120,140 120))','t','Test 10');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((80 180,140 260,260 200,200 60,80 180))','t','Test 11');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((240 80,140 120,180 240,280 200,240 80))','t','Test 12');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((140 160,20 20,270 20,150 160,230 40,60 40,140 160))','t','Test 13');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((140 40,180 80,120 100,140 40))','t','Test 14');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((120 100,180 80,130 40,120 100))','t','Test 15');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 20,180 20,140 140,20 140,20 20))','t','Test 16');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((180 100,80 200,180 280,260 200,180 100))','t','Test 17');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((140 140,20 120,0 220,120 240,140 140))','t','Test 18');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((160 200,210 70,120 70,160 200))','t','Test 19');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((160 200,260 40,70 40,160 200,20 20,310 20,160 200))','f','Test 20');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((110 140,200 70,200 160,110 140))','t','Test 21');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((110 140,110 50,60 50,60 90,160 190,20 110,20 20,200 20,110 140))','f','Test 22');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 120,20 20,260 20,260 120,200 40,140 120,80 40,20 120))','t','Test 23');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 120,20 240,260 240,260 120,200 200,140 120,80 200,20 120))','t','Test 24');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 120,20 20,260 20,260 120,180 40,140 120,100 40,20 120))','t','Test 25');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 120,300 120,140 240,20 120))','t','Test 26');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 20,20 300,280 300,280 260,220 260,60 100,60 60,280 60,280 20,20 20))','t','Test 27');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((100 140,160 80,280 180,200 240,220 160,160 200,180 120,100 140))','t','Test 28');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((260 200,180 80,120 160,200 160,180 220,260 200))','t','Test 29');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 20,280 20,280 140,220 60,140 140,80 60,20 140,20 20))','t','Test 30');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 140,300 140,140 240,0 140))','t','Test 31');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 240,20 140,320 140,180 240,20 240))','t','Test 32');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 240,20 140,80 180,140 140,220 180,280 140,280 240,20 240))','t','Test 33');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((120 120,180 60,20 20,20 120,120 120))','t','Test 34');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((120 120,220 20,280 20,240 160,120 120))','t','Test 35');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((140 120,160 20,260 120,220 200,140 120))','t','Test 36');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 140,120 40,20 40,20 140))','t','Test 37');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((190 140,190 20,140 20,20 140,190 140))','t','Test 38');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((300 20,220 20,120 120,260 160,300 20))','t','Test 39');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((140 120,240 160,280 60,160 20,140 120))','t','Test 40');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((280 60,180 60,120 120,260 180,280 60))','t','Test 41');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((120 200,120 120,40 120,40 200,120 200))','t','Test 42');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((160 220,140 120,60 120,40 220,160 220))','t','Test 43');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((140 120,20 120,20 220,140 220,140 120))','t','Test 44');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((320 20,220 20,80 160,240 140,320 20))','t','Test 45');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 20,20 180,220 180,220 20,20 20))','t','Test 46');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((60 40,60 140,180 140,180 40,60 40))','t','Test 47');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 20,80 140,160 60,20 20))','t','Test 48');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((160 60,20 20,100 140,160 60))','t','Test 49');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 100,140 160,160 40,20 100))','t','Test 50');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((160 40,20 100,160 160,160 40))','t','Test 51');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 180,180 120,80 40,20 180))','t','Test 52');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((180 120,100 40,20 180,180 120))','t','Test 53');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 20,140 40,140 120,20 160,80 80,20 20))','t','Test 54');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 20,140 40,140 140,20 180,80 100,20 20))','t','Test 55');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((40 180,60 100,180 100,200 180,120 120,40 180))','t','Test 56');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 180,60 80,180 80,220 180,120 120,20 180))','t','Test 57');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((40 60,20 180,100 100,140 180,160 120,220 100,140 40,40 60))','t','Test 58');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((60 100,180 100,220 180,120 140,20 180,60 100))','t','Test 59');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 20,20 140,120 120,120 40,20 20))','t','Test 60');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 20,20 180,140 140,140 60,20 20))','t','Test 61');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 20,120 40,120 120,20 140,20 20))','t','Test 62');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((120 40,20 20,20 140,120 120,120 40))','t','Test 63');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 20,140 60,140 140,20 180,20 20))','t','Test 64');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((140 60,20 20,20 180,140 140,140 60))','t','Test 65');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 20,60 120,140 120,180 20,20 20))','t','Test 66');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 40,120 40,120 120,20 140,20 40))','t','Test 67');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 20,20 180,60 120,100 180,140 120,220 180,200 120,140 60,20 20))','t','Test 68');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((150 150,330 150,250 70,70 70,150 150))','t','Test 69');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((150 150,270 150,140 20,20 20,150 150))','t','Test 70');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((150 150,270 150,330 150,250 70,190 70,70 70,150 150))','t','Test 71');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((150 150,270 150,190 70,140 20,20 20,70 70,150 150))','t','Test 72');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 20,60 50,20 40,60 70,20 60,60 90,20 90,70 110,20 130,80 130,20 150,80 160,20 170,80 180,20 200,80 200,30 240,80 220,50 260,100 220,100 260,120 220,130 260,140 220,150 280,150 190,160 280,170 190,180 280,190 190,200 280,210 190,220 280,230 190,240 260,250 230,260 260,260 220,290 270,290 220,330 260,300 210,340 240,290 180,340 210,290 170,350 170,240 150,350 150,240 140,350 130,240 120,350 120,240 110,350 110,240 100,350 100,240 90,350 90,240 80,350 80,300 70,340 60,290 60,340 40,300 50,340 20,270 60,310 20,250 60,270 20,230 60,240 20,210 60,210 20,190 70,190 20,180 90,170 20,160 90,150 20,140 90,130 20,120 90,110 20,100 90,100 20,90 60,80 20,70 40,20 20))','t','Test 73');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((190 140,140 130,200 160,130 150,210 170,130 170,210 180,120 190,220 200,120 200,250 210,120 210,250 220,120 220,250 230,120 240,230 240,120 250,240 260,120 260,240 270,120 270,270 290,120 290,230 300,150 310,250 310,180 320,250 320,200 360,260 330,240 360,280 320,290 370,290 320,320 360,310 320,360 360,310 310,380 340,310 290,390 330,310 280,410 310,310 270,420 280,310 260,430 250,300 250,440 240,300 240,450 230,280 220,440 220,280 210,440 210,300 200,430 190,300 190,440 180,330 180,430 150,320 180,420 130,300 180,410 120,280 180,400 110,280 170,390 90,280 160,400 70,270 160,450 30,260 160,420 30,250 160,390 30,240 160,370 30,230 160,360 30,230 150,330 50,240 130,330 30,230 130,310 30,220 130,280 30,230 100,270 40,220 110,250 30,210 130,240 30,210 100,220 40,200 90,200 20,190 100,180 30,20 20,180 40,20 30,180 50,20 50,180 60,30 60,180 70,20 70,170 80,80 80,170 90,20 80,180 100,40 100,200 110,60 110,200 120,120 120,190 140))','t','Tes
 t 74');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((70 150,20 160,110 160,20 180,100 200,20 200,190 210,20 210,160 220,20 220,150 230,60 240,180 250,20 260,170 260,60 270,160 270,100 310,170 280,200 260,180 230,210 260,130 330,230 250,210 290,240 250,230 210,260 300,250 230,270 300,270 240,300 340,280 250,320 330,290 250,340 350,290 240,350 360,270 190,350 340,290 200,350 330,300 190,360 320,310 190,360 300,320 200,360 280,330 200,360 260,340 200,370 260,340 180,390 290,340 170,400 260,350 170,400 250,350 160,410 240,350 150,400 170,350 140,310 170,340 140,270 180,330 140,260 170,310 140,240 170,290 140,200 190,270 140,180 190,260 140,170 190,260 130,170 180,250 130,170 170,240 120,170 160,210 120,170 150,210 110,340 130,230 110,420 140,220 100,410 130,220 90,400 120,220 80,390 110,220 70,420 110,240 70,420 100,260 70,420 90,280 70,430 80,230 60,430 60,270 50,450 40,210 50,370 40,260 40,460 30,160 40,210 60,200 110,190 60,190 120,170 50,180 130,150 30,170 130,140 20,160 120,130 20,160
  150,120 20,160 170,110 20,160 190,100 20,150 190,90 20,140 180,80 20,120 140,70 20,120 150,60 20,110 150,50 20,100 140,50 30,90 130,40 30,80 120,30 30,80 130,30 40,80 140,20 40,70 140,40 90,60 130,20 90,60 140,20 130,70 150))','t','Test 75');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((60 160,220 160,220 20,60 20,60 160))','t','Test 76');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((60 160,20 200,260 200,220 160,140 80,60 160))','t','Test 77');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((60 160,20 200,260 200,140 80,60 160))','t','Test 78');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 200,140 80,260 200,20 200))','t','Test 79');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 200,60 160,140 80,220 160,260 200,20 200))','t','Test 80');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 200,60 160,140 80,260 200,20 200))','t','Test 81');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 0,0 200,200 200,200 0,0 0))','t','Test 82');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((100 100,1000000 110,10000000 100,100 100))','t','Test 83');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((100 0,100 200,200 200,200 0,100 0))','t','Test 84');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((120 0,120 200,200 200,200 0,120 0))','t','Test 85');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 0,0 200,110 200,110 0,0 0))','t','Test 86');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((100 100,100 200,200 200,200 100,100 100))','t','Test 87');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((100 100,2100 110,2100 100,100 100))','t','Test 88');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((100 100,2101 110,2101 100,100 100))','t','Test 89');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((100 100,200 200,200 100,100 100))','t','Test 90');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((100 100,1000000 110,1000000 100,100 100))','t','Test 91');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((120 100,120 200,200 200,200 100,120 100))','t','Test 93');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((100 100,500 110,500 100,100 100))','t','Test 94');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((100 100,501 110,501 100,100 100))','t','Test 95');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((120 100,130 200,200 200,200 100,120 100))','t','Test 96');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((120 100,17 200,200 200,200 100,120 100))','t','Test 97');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((101 99,101 1000000,102 1000000,101 99))','t','Test 98');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((100 100,200 101,200 100,100 100))','t','Test 99');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((16 319,150 39,25 302,160 20,265 20,127 317,16 319))','t','Test 100');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((10 307,22 307,153 34,22 34,10 307))','t','Test 101');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((160 200,310 20,20 20,160 200),(160 200,260 40,70 40,160 200))','t','Test 102');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((170 120,240 100,260 50,190 70,170 120))','t','Test 103');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((150 150,410 150,280 20,20 20,150 150),(170 120,330 120,260 50,100 50,170 120))','t','Test 104');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((270 90,200 50,150 80,210 120,270 90))','t','Test 105');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((170 120,260 100,240 60,150 80,170 120))','t','Test 106');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((220 120,270 80,200 60,160 100,220 120))','t','Test 107');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((260 50,180 70,180 110,260 90,260 50))','t','Test 108');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((230 110,290 80,190 60,140 90,230 110))','t','Test 109');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((170 120,330 120,260 50,100 50,170 120))','t','Test 110');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((170 120,330 120,280 70,120 70,170 120))','t','Test 111');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((170 120,300 120,250 70,120 70,170 120))','t','Test 112');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((190 100,310 100,260 50,140 50,190 100))','t','Test 113');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((280 130,360 130,270 40,190 40,280 130))','t','Test 114');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((150 150,410 150,280 20,20 20,150 150),(170 120,250 120,180 50,100 50,170 120))','t','Test 115');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((220 80,180 40,80 40,170 130,270 130,230 90,300 90,250 30,280 30,390 140,150 140,40 30,230 30,280 80,220 80))','t','Test 116');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((260 130,360 130,280 40,170 40,260 130))','t','Test 117');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((240 110,340 110,290 60,190 60,240 110))','t','Test 118');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((250 120,350 120,280 50,180 50,250 120))','t','Test 119');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((230 210,230 20,20 20,20 210,230 210),(120 180,50 50,200 50,120 180))','t','Test 120');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((230 210,230 20,20 20,20 210,230 210),(140 40,40 40,40 170,140 40),(110 190,210 190,210 50,110 190))','t','Test 121');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((280 190,330 150,200 110,150 150,280 190))','t','Test 122');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((140 110,260 110,170 20,50 20,140 110)),((300 270,420 270,340 190,220 190,300 270)))','t','Test 123');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((80 190,220 190,140 110,0 110,80 190))','t','Test 124');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((330 150,200 110,150 150,280 190,330 150))','t','Test 125');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((290 190,340 150,220 120,170 170,290 190))','t','Test 126');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((220 190,340 190,260 110,140 110,220 190))','t','Test 127');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((140 190,220 190,100 70,20 70,140 190))','t','Test 128');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((140 220,60 140,140 60,220 140,140 220))','t','Test 129');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((100 20,180 20,180 100,100 100,100 20)),((20 100,100 100,100 180,20 180,20 100)),((100 180,180 180,180 260,100 260,100 180)),((180 100,260 100,260 180,180 180,180 100)))','t','Test 130');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((110 110,70 200,150 200,110 110)),((110 110,150 20,70 20,110 110)))','t','Test 131');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((110 110,160 160,210 110,160 60,110 110)),((110 110,60 60,10 110,60 160,110 110)))','t','Test 132');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((110 110,70 200,150 200,110 110),(110 110,100 180,120 180,110 110)),((110 110,150 20,70 20,110 110),(110 110,120 40,100 40,110 110)))','t','Test 133');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((110 110,160 160,210 110,160 60,110 110),(110 110,160 130,160 90,110 110)),((110 110,60 60,10 110,60 160,110 110),(110 110,60 90,60 130,110 110)))','t','Test 134');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((110 110,70 200,200 200,110 110),(110 110,100 180,120 180,110 110)),((110 110,200 20,70 20,110 110),(110 110,120 40,100 40,110 110)))','t','Test 135');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((110 110,20 200,200 200,110 110),(110 110,100 180,120 180,110 110)),((110 110,200 20,20 20,110 110),(110 110,120 40,100 40,110 110)))','t','Test 136');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((110 110,70 200,210 110,70 20,110 110),(110 110,110 140,150 110,110 80,110 110)),((110 110,60 60,10 110,60 160,110 110),(110 110,60 90,60 130,110 110)))','t','Test 137');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((100 60,140 100,100 140,60 100,100 60))','t','Test 138');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((80 40,120 40,120 80,80 80,80 40)),((120 80,160 80,160 120,120 120,120 80)),((80 120,120 120,120 160,80 160,80 120)),((40 80,80 80,80 120,40 120,40 80)))','t','Test 139');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(150 150,40 230)','t','Test 140');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((150 150,410 150,280 20,20 20,150 150))','t','Test 141');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 40,50 130,130 130)','t','Test 142');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 230,150 150)','t','Test 143');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(210 150,330 150)','t','Test 144');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(200 150,310 150,360 220)','t','Test 145');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(180 150,250 150,230 250,370 250,410 150)','t','Test 146');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(210 210,220 150,320 150,370 210)','t','Test 147');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 60,150 60)','t','Test 148');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 90,310 180)','t','Test 149');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(90 210,210 90)','t','Test 150');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(290 10,130 170)','t','Test 151');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(30 100,100 100,180 100)','t','Test 152');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 100,100 100,360 100,410 100)','t','Test 153');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(90 210,150 150,210 90)','t','Test 154');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(180 90,280 120)','t','Test 155');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(70 70,80 20)','t','Test 156');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(130 20,150 60)','t','Test 157');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(70 70,80 20,140 20,150 60)','t','Test 158');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(170 50,170 20,240 20,260 60)','t','Test 159');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(50 100,140 190,280 190)','t','Test 160');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(140 60,180 100,290 100)','t','Test 161');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(170 120,210 80,270 80)','t','Test 162');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(170 120,260 50)','t','Test 163');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(190 90,190 270)','t','Test 164');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((190 190,360 20,20 20,190 190),(190 190,280 50,100 50,190 190))','t','Test 165');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 160,150 70)','t','Test 166');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((190 190,360 20,20 20,190 190),(110 110,250 100,140 30,110 110))','t','Test 167');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((190 190,20 20,360 20,190 190),(250 100,110 110,140 30,250 100))','t','Test 168');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(190 90,190 190,190 270)','t','Test 169');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 160,110 110,150 70)','t','Test 170');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((190 190,110 110,20 20,360 20,190 190),(250 100,110 110,140 30,250 100))','t','Test 171');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(130 110,180 110,190 60)','t','Test 172');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 200,240 200,240 20,20 20,20 200),(130 110,60 180,60 40,130 110),(130 110,200 40,200 180,130 110))','t','Test 173');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 110,180 110)','t','Test 174');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 200,20 20,240 20,240 200,20 200),(60 180,130 110,60 40,60 180),(130 110,200 40,200 180,130 110))','t','Test 175');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 110,170 110)','t','Test 176');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 200,20 20,240 20,240 200,20 200),(130 110,60 40,60 180,130 110),(130 180,130 40,200 110,130 180))','t','Test 177');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 110,130 110,170 110)','t','Test 178');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 110,130 110,180 110)','t','Test 179');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(160 70,320 230)','t','Test 180');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(160 70,200 110,280 190,320 230)','t','Test 181');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(70 50,70 150)','t','Test 182');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((0 0,0 100,140 100,140 0,0 0)),((20 170,70 100,130 170,20 170)))','t','Test 183');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,20 200,200 200,110 110)','t','Test 184');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 20,200 20,110 110,20 20))','t','Test 185');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(150 70,160 110,200 60,150 70)','t','Test 186');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 60,120 40,120 70,80 60)','t','Test 187');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((110 110,200 20,20 20,110 110),(110 90,50 30,170 30,110 90))','t','Test 188');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 20,200 20,110 110,20 20)','t','Test 189');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 90,170 30,50 30,110 90)','t','Test 190');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,170 50,170 110,110 110)','t','Test 191');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 90,70 50,130 50,110 90)','t','Test 192');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 60,20 150,200 150,110 60)','t','Test 193');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 130,110 70,200 100,110 130)','t','Test 194');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 90,160 40,60 40,110 90)','t','Test 195');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 100,40 30,180 30,110 100)','t','Test 196');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((110 110,200 20,20 20,110 110),(110 90,60 40,160 40,110 90))','t','Test 197');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,180 30,40 30,110 110)','t','Test 198');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 90,180 30,40 30,110 90)','t','Test 199');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 90,50 30,180 30,110 90)','t','Test 200');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,200 200,200 110,110 200)','t','Test 201');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((110 110,200 20,20 20,110 110))','t','Test 202');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,200 200,110 110,20 200,20 110,200 110)','t','Test 203');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,20 110,200 110,50 110,110 170)','t','Test 204');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,20 200,110 200,110 110,200 200)','t','Test 205');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,170 50,20 200,20 110,200 110)','t','Test 206');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,180 40,110 40,110 180)','t','Test 207');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 60,50 30,170 30,90 70)','t','Test 208');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,180 40,110 40,110 110,70 40)','t','Test 209');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(230 70,170 120,190 60,140 60,170 120,270 90)','t','Test 210');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((20 110,200 110),(200 200,110 110,20 210,110 110))','t','Test 211');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((20 110,200 110),(60 180,60 110,160 110,110 110))','t','Test 212');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((20 110,200 110),(200 200,110 110,20 200,110 200,110 110))','t','Test 213');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((20 110,200 110),(110 50,110 170,110 70,110 150,200 150))','t','Test 214');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((20 110,200 110),(50 110,170 110,110 170,110 50,110 170,110 50))','t','Test 215');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((20 110,200 110),(110 60,110 160,200 160))','t','Test 216');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((110 100,40 30,180 30),(170 30,110 90,50 30))','t','Test 217');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((110 110,60 40,70 20,150 20,170 40),(180 30,40 30,110 80))','t','Test 218');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((20 110,200 110,200 160),(110 110,200 110,200 70,20 150))','t','Test 219');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((110 110,20 20,200 20,110 110)),((110 110,20 200,200 200,110 110)))','t','Test 220');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((20 160,70 110,150 110,200 160),(110 110,20 110,50 80,70 110,200 110))','t','Test 221');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((20 110,200 110),(110 110,20 170,20 130,200 90))','t','Test 222');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(0 0,0 50,50 50,50 0,0 0)','t','Test 223');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((0 0,0 50),(0 50,50 50),(50 50,50 0),(50 0,0 0))','t','Test 224');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 180,140 180)','t','Test 225');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((20 320,180 320,180 180,20 180,20 320)),((20 180,20 80,180 80,180 180,20 180)))','f','Test 226');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((20 320,180 320,180 180,20 180,20 320)),((60 180,60 80,180 80,180 180,60 180)))','f','Test 227');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(0 0,60 0,60 60,60 0,120 0)','t','Test 228');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((0 0,60 0),(60 0,120 0),(60 0,60 60))','t','Test 229');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 40,120 120)','t','Test 230');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 40,60 120)','t','Test 231');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 240,40 40)','t','Test 232');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 40,180 180)','t','Test 233');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(120 120,20 200)','t','Test 234');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 240,120 120)','t','Test 235');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 180,140 140)','t','Test 236');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 120,120 40)','t','Test 237');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 40,100 100)','t','Test 238');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(100 100,40 40)','t','Test 239');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 120,120 160)','t','Test 240');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 20,180 180)','t','Test 241');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 20,110 110)','t','Test 242');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(50 50,140 140)','t','Test 243');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(180 180,40 40)','t','Test 244');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(120 120,260 260)','t','Test 245');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(260 260,120 120)','t','Test 246');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 40,100 100,200 120,80 240)','t','Test 247');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 40,20 100,40 160,20 200)','t','Test 248');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 200,40 160,20 100,40 40)','t','Test 249');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 240,200 120,100 100,40 40)','t','Test 250');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 60,60 230,140 230,250 160)','t','Test 251');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 20,60 60,250 160,310 230)','t','Test 252');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 20,110 110,200 110,320 230)','t','Test 253');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 110,60 250,360 210)','t','Test 254');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 110,110 160,250 160,310 160,360 210)','t','Test 255');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(360 210,310 160,110 160,60 110)','t','Test 256');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(160 160,240 240)','t','Test 257');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(240 240,160 160)','t','Test 258');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 150,110 100,170 100,110 230)','t','Test 259');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(200 120,200 190,150 240,200 240)','t','Test 260');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(200 240,150 240,200 200,200 120)','t','Test 261');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 230,80 140,120 140,140 230)','t','Test 262');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 110,200 110,250 160,300 210)','t','Test 263');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 110,200 110,250 160,300 210,360 210)','t','Test 264');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 110,220 110,250 160,280 110)','t','Test 265');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 110,150 110,200 160,250 110,360 110,360 210)','t','Test 266');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(130 160,160 110,220 110,250 160,250 210)','t','Test 267');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(130 160,160 110,190 110,230 210)','t','Test 268');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(130 160,160 110,200 110,230 160,260 210,360 210)','t','Test 269');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(130 160,160 110,200 110,230 160,260 210,360 210,380 210)','t','Test 270');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(130 160,160 110,200 110,230 160,260 210,380 210)','t','Test 271');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 160,160 110,200 110,250 160,250 210)','t','Test 272');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 160,180 110,250 160,320 110)','t','Test 273');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(140 160,180 80,220 160,250 80)','t','Test 274');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 40,100 100,200 120,130 190)','t','Test 275');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 130,70 130,160 40)','t','Test 276');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 160,40 100,110 40,170 40)','t','Test 277');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(130 110,180 160,230 110,280 160,330 110)','t','Test 278');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(30 140,80 140,100 100,200 30)','t','Test 279');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,110 160,180 110,250 160,250 110)','t','Test 280');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 20,80 80,160 80,240 80,300 140)','t','Test 281');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 60,60 60,60 140,80 80,100 20,140 140,180 20,200 80,220 20,240 80,300 80,270 110,200 110)','t','Test 282');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 20,230 20,20 30,170 30,20 40,230 40,20 50,230 60,60 60,230 70,20 70,180 80,60 80,230 90,20 90,230 100,30 100,210 110,20 110,80 120,20 130,170 130,90 120,230 130,170 140,230 140,80 150,160 140,20 140,70 150,20 150,230 160,80 160,230 170,20 160,180 170,20 170,230 180,20 180,40 190,230 190,20 200,230 200)','t','Test 283');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(30 210,30 60,40 210,40 30,50 190,50 20,60 160,60 50,70 220,70 50,80 20,80 210,90 50,90 150,100 30,100 210,110 20,110 190,120 50,120 180,130 210,120 20,140 210,130 50,150 210,130 20,160 210,140 30,170 210,150 20,180 210,160 20,190 210,180 80,170 50,170 20,180 70,180 20,190 190,190 30,200 210,200 30,210 210,210 20,220 150,220 20)','t','Test 284');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 240,120 200,200 120,100 100,80 80,40 40)','t','Test 285');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(260 210,240 130,280 120,260 40)','t','Test 286');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(100 20,20 20,20 160,210 160,210 20,110 20,50 120,120 150,200 150)','t','Test 287');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(140 130,100 110,120 60,170 60)','t','Test 288');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 110,110 160,310 160,360 210)','t','Test 289');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 110,110 160,250 160)','t','Test 290');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 160,310 160,340 190)','t','Test 291');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(140 160,250 160,310 160,340 190)','t','Test 292');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 160,250 160,310 160)','t','Test 293');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(200 120,100 100,40 40,140 80,200 40)','t','Test 294');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(280 240,240 140,200 120,100 100,40 40)','t','Test 295');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 190,140 140,40 40)','t','Test 296');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(240 200,200 260,80 240,140 180)','t','Test 297');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(140 180,80 240,200 260,240 200)','t','Test 298');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(280 240,240 140,200 120,80 240)','t','Test 299');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 80,120 80,200 80,260 20)','t','Test 300');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(100 100,200 120,240 140,280 240)','t','Test 301');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(280 240,240 140,200 120,100 100)','t','Test 302');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 20,80 80,240 80,300 20)','t','Test 303');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 80,80 80,120 80,140 140,160 80,200 80,220 20,240 80,270 110,300 80)','t','Test 304');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(100 100,20 180,180 180)','t','Test 305');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(100 100,180 20,20 20,100 100)','t','Test 306');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 100,180 100,100 180)','t','Test 307');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(100 40,100 160,180 160)','t','Test 308');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 100,100 100,180 100,100 180)','t','Test 309');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(100 100,160 40)','t','Test 310');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(100 100,180 20)','t','Test 311');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 60,100 100,140 60)','t','Test 312');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(100 100,190 10,190 100)','t','Test 313');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(100 100,160 40,160 100)','t','Test 314');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 140,160 40,160 140)','t','Test 315');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 20,140 140)','t','Test 316');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 80,20 80,140 80,80 20,80 140)','t','Test 317');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 80,20 80,140 80)','t','Test 318');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 80,140 80,80 20,80 140)','t','Test 319');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 80,20 80,140 80,80 20,80 80)','t','Test 320');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 80,20 80,140 80,80 80)','t','Test 321');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 80,20 80,20 140,140 20,80 20,80 80)','t','Test 322');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 140,140 20,100 20,100 80)','t','Test 323');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(140 80,20 80,120 80,80 20,80 140)','t','Test 324');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(140 80,20 80,140 80)','t','Test 325');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(140 80,20 80,80 140,80 20)','t','Test 326');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(140 80,80 80,20 80,50 140,50 60)','t','Test 327');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(140 80,20 80,120 80,80 20,80 80,80 140)','t','Test 328');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(140 80,20 80,80 80,140 80)','t','Test 329');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(140 80,20 80,80 140,80 80,80 20)','t','Test 330');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(130 150,220 150,220 240)','t','Test 331');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(130 240,130 150,220 20,50 20,130 150)','t','Test 332');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(30 150,130 150,250 150)','t','Test 333');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(30 150,250 150)','t','Test 334');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(130 240,130 20,30 20,130 150)','t','Test 335');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(120 240,120 20,20 20,120 170)','t','Test 336');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(200 200,20 20,200 20,110 110,20 200,110 200,110 110)','t','Test 337');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,200 110)','t','Test 338');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 110,200 110)','t','Test 339');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(90 200,90 130,110 110,150 200)','t','Test 340');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(200 200,20 20,200 20,20 200,20 130,90 130)','t','Test 341');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(200 110,110 110,90 130,90 200)','t','Test 342');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 80,150 80,210 80)','t','Test 343');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((20 20,140 140),(20 140,140 20))','t','Test 344');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 80,160 200,260 20,40 80)','t','Test 345');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 80,260 20,160 200,40 80)','t','Test 346');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(260 20,40 80,160 200,260 20)','t','Test 347');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(100 140,160 200,260 20,40 80,100 140)','t','Test 348');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(100 100,180 180,20 180,100 100)','t','Test 349');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 150,40 40,150 40,150 150,40 150)','t','Test 350');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 150,150 40,170 20,170 190,40 150)','t','Test 351');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(180 100,20 100,100 180,180 100)','t','Test 352');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(180 180,100 100,20 180,180 180)','t','Test 353');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 180,100 100,20 20,20 180)','t','Test 354');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(100 20,100 180,180 100,100 20)','t','Test 355');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(170 20,20 170,170 170,170 20)','t','Test 356');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 150,150 150,90 210,40 150)','t','Test 357');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 150,170 150,90 230,20 150)','t','Test 358');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 150,150 150,150 40,20 40,20 150,40 150)','t','Test 359');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,200 20,20 20,110 110)','t','Test 360');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(200 20,20 200,200 200,110 110,110 40)','t','Test 361');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(200 20,20 200,200 200,20 20)','t','Test 362');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,20 110,110 20,20 20,110 110)','t','Test 363');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,200 200,110 200,200 110,110 110)','t','Test 364');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 120,120 120,20 20,120 20,20 120)','t','Test 365');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(170 100,70 100,170 170,70 170,170 100)','t','Test 366');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 110,110 110,20 20,110 20,20 110)','t','Test 367');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 160,70 110,60 160,20 130,110 160)','t','Test 368');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 200,200 200,20 20,200 20,20 200)','t','Test 369');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 110,200 110,200 160,20 60,20 110)','t','Test 370');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(200 200,110 110,200 110,110 200,200 200)','t','Test 371');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(220 120,120 20,220 20,120 120,220 120)','t','Test 372');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((70 20,20 90,70 170),(70 170,120 90,70 20))','t','Test 373');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((20 20,90 20,170 20),(90 20,90 80,90 140))','t','Test 374');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((90 140,90 60,90 20),(170 20,130 20,20 20))','t','Test 375');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((90 20,170 100,170 140),(170 60,90 20,20 60),(130 100,130 60,90 20,50 90))','t','Test 376');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((90 20,170 100,170 140),(130 140,130 60,90 20,20 90,90 20,130 60,170 60))','t','Test 377');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((90 20,170 100,170 140),(170 60,90 20,20 60))','t','Test 378');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((90 20,170 100,170 140),(170 60,90 20,20 60),(130 100,90 20))','t','Test 379');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((90 20,170 100,170 140),(170 60,90 20,20 60),(120 100,170 100,90 20))','t','Test 380');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((90 20,170 100,170 140),(130 140,130 60,90 20,20 90,90 20))','t','Test 381');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((90 20,170 100,170 140),(170 60,90 20,20 60,20 140,90 20))','t','Test 382');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((20 20,90 90,20 160),(90 160,90 20))','t','Test 383');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((160 160,90 90,160 20),(160 120,120 120,90 90,160 60))','t','Test 384');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((160 160,90 90,160 20),(160 120,120 120,90 90,120 60,160 60))','t','Test 385');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((160 160,90 90,160 20),(160 120,90 90,160 60))','t','Test 386');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(20 20)','t','Test 387');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((60 120,60 40,160 40,160 120,60 120))','t','Test 388');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(70 170)','t','Test 389');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((110 230,80 160,20 160,20 20,200 20,200 160,140 160,110 230))','t','Test 390');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(110 130)','t','Test 391');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 160,80 160,110 100,140 160,200 160,200 20,20 20,20 160))','t','Test 392');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(100 70)','t','Test 393');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 150,100 150,40 50,170 50,110 150,190 150,190 20,20 20,20 150))','t','Test 394');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 150,100 150,40 50,160 50,100 150,180 150,180 20,20 20,20 150))','f','Test 395');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(60 120)','t','Test 396');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(110 120)','t','Test 397');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(160 120)','t','Test 398');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(100 150)','t','Test 399');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(100 80)','t','Test 400');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(60 160)','t','Test 401');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((190 190,360 20,20 20,190 190),(280 50,100 50,190 140,280 50))','t','Test 402');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(190 90)','t','Test 403');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(190 190)','t','Test 404');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(360 20)','t','Test 405');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(130 130)','t','Test 406');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(280 50)','t','Test 407');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(150 100)','t','Test 408');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(100 50)','t','Test 409');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(140 120)','t','Test 410');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(190 50)','t','Test 411');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((190 190,360 20,20 20,190 190),(90 50,150 110,190 50,90 50),(190 50,230 110,290 50,190 50))','t','Test 412');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(180 90)','t','Test 413');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((190 190,360 20,20 20,190 190),(180 140,180 40,80 40,180 140),(180 90,210 140,310 40,230 40,180 90))','t','Test 414');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(20 80,110 160,20 160)','t','Test 415');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(20 80,60 120,20 160)','t','Test 416');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(10 80,110 170,110 120)','t','Test 417');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(10 80,110 170,160 120)','t','Test 418');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(20 120,60 120,110 120,160 120,200 120)','t','Test 419');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(60 120,110 120,160 120)','t','Test 420');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(60 120,160 120,160 40,60 40)','t','Test 421');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(20 150,60 120,110 80)','t','Test 422');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(110 80,160 120,200 160)','t','Test 423');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(110 80,110 120,110 160)','t','Test 424');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(110 170,110 80)','t','Test 425');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(60 120,160 120,110 80,110 170)','t','Test 426');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(90 80,130 80)','t','Test 427');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(60 120,160 120,110 80)','t','Test 428');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(40 170,40 90,130 170)','t','Test 429');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(90 170,280 170,190 90)','t','Test 430');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(190 110,150 70,230 70)','t','Test 431');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(100 100)','t','Test 432');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((20 100,20 20,100 20,100 100,20 100)),((100 180,100 100,180 100,180 180,100 180)))','t','Test 433');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(20 100)','t','Test 434');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(60 100)','t','Test 435');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(110 110)','t','Test 436');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((110 110,20 200,200 200,110 110),(110 110,80 180,140 180,110 110)),((110 110,20 20,200 20,110 110),(110 110,80 40,140 40,110 110)))','t','Test 437');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(110 200)','t','Test 438');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(90 80,160 150,300 150,340 150,340 240)','t','Test 439');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(90 80)','t','Test 440');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(340 240)','t','Test 441');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(230 150)','t','Test 442');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(160 150)','t','Test 443');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(90 150)','t','Test 444');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(150 150,20 20,280 20,150 150)','t','Test 445');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(150 80)','t','Test 446');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(150 150)','t','Test 447');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(100 20)','t','Test 448');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(220 220)','t','Test 449');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,220 20,20 20,110 110,220 220)','t','Test 450');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,220 20,20 20,220 220)','t','Test 451');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(110 20)','t','Test 452');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(220 20)','t','Test 453');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(220 220,20 20,220 20,110 110)','t','Test 454');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(20 110)','t','Test 455');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 200,20 20,110 20,20 110,110 200)','t','Test 456');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(20 200)','t','Test 457');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 200,200 20,20 20,200 200)','t','Test 458');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 200,200 20,140 20,140 80,80 140,20 140)','t','Test 459');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(80 140)','t','Test 460');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 200,110 110,200 20,140 20,140 80,110 110,80 140,20 140)','t','Test 461');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 200,200 20,140 20,140 80,110 110,80 140,20 140)','t','Test 462');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 200,110 110,200 20,20 20,110 110,200 200)','t','Test 463');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 200,200 20,20 20,110 110,200 200)','t','Test 464');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 200,110 110,20 20,200 20,110 110,200 200)','t','Test 465');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,110 200,20 200,110 110,200 20,140 20,140 80,110 110,80 140,20 140)','t','Test 466');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,110 200,20 200,200 20,140 20,140 80,110 110,80 140,20 140)','t','Test 467');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,110 200,20 200,200 20,140 20,140 80,80 140,20 140)','t','Test 468');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,110 200,20 200,110 110,200 20,20 20,110 110,200 200)','t','Test 469');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,110 200,20 200,200 20,20 20,110 110,200 200)','t','Test 470');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,110 200,20 200,200 20,20 20,200 200)','t','Test 471');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,110 200,20 200,110 110,20 20,200 20,110 110,200 200)','t','Test 472');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,110 200,20 200,200 20,200 110,110 110,200 200)','t','Test 473');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(200 200,110 110,20 20,200 20,110 110,20 200,110 200,110 110)','t','Test 474');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(200 200,20 20,200 20,20 200,110 200,110 110)','t','Test 475');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(200 200,110 110,200 20,20 20,110 110,20 200,110 200,110 110)','t','Test 476');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(200 200,20 20,20 110,110 110,20 200,110 200,110 110)','t','Test 477');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(110 160)','t','Test 478');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 160,200 250,110 250,110 160,110 110,110 20,20 20,110 110)','t','Test 479');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 160,200 250,110 250,110 110,110 20,20 20,110 110)','t','Test 480');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 160,200 250,110 250,110 160,110 20,20 20,110 110)','t','Test 481');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,200 200,110 200,110 110,110 20,20 20,110 110)','t','Test 482');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,200 200,110 200,110 20,20 20,110 110)','t','Test 483');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(140 200)','t','Test 484');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,200 200,110 200,110 110,110 20,200 20,110 110)','t','Test 485');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(90 130)','t','Test 486');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(90 130,20 130,20 200,90 130,200 20,20 20,200 200)','t','Test 487');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(90 130,20 130,20 200,200 20,20 20,200 200)','t','Test 488');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(200 200,20 20,200 20,90 130,20 200,20 130,90 130)','t','Test 489');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,20 130,20 200,110 110,200 20,20 20,110 110,200 200,200 130,110 110)','t','Test 490');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,20 130,20 200,200 20,20 20,200 200,200 130,110 110)','t','Test 491');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,80 200,20 200,110 110,200 20,20 20,110 110,200 200,140 200,110 110)','t','Test 492');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 110,80 200,20 200,200 20,20 20,200 200,140 200,110 110)','t','Test 493');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(200 200,20 20,200 20,20 200,200 200)','t','Test 494');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(200 200,110 110,20 20,200 20,110 110,20 200,200 200)','t','Test 495');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(200 200,110 110,200 20,20 20,110 110,20 200,200 200)','t','Test 496');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(90 130,20 130,20 200,90 130,110 110,200 20,20 20,110 110,200 200,90 130)','t','Test 497');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(90 130,20 130,20 200,110 110,200 20,20 20,110 110,200 200,90 130)','t','Test 498');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(90 130,90 200,20 200,90 130,110 110,200 20,20 20,110 110,200 200,90 130)','t','Test 499');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(90 130,90 200,20 200,200 20,20 20,200 200,90 130)','t','Test 500');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(90 130,90 200,20 200,110 110,200 20,20 20,110 110,200 200,90 130)','t','Test 501');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 200,110 110,20 20,200 20,110 110,110 200,200 200)','t','Test 502');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(110 150)','t','Test 503');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 200,110 110,20 20,200 20,110 110,110 200)','t','Test 504');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 200,110 200,110 110,20 20,200 20,110 110,110 200,200 200)','t','Test 505');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(50 250,90 220,130 190)','t','Test 506');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(180 180,230 130,280 80)','t','Test 507');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(50 120,90 80,130 40)','t','Test 508');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(300 280,340 240,380 200)','t','Test 509');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(230 150,260 120,290 90)','t','Test 510');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(200 190,240 150,270 110)','t','Test 511');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(160 150,190 120,220 90)','t','Test 512');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(120 190,160 150,200 110)','t','Test 513');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(90 80,160 150,340 240)','t','Test 514');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(90 80,160 150,300 150)','t','Test 515');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(90 80,160 150,240 150)','t','Test 516');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(90 80,130 120,210 150)','t','Test 517');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(130 120,210 150,340 200)','t','Test 518');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(160 150,240 150,340 210)','t','Test 519');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(160 150,300 150,340 150)','t','Test 520');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(160 150,240 150,340 240)','t','Test 521');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(40 60)','t','Test 522');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(40 40)','t','Test 523');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(20 20,80 80,20 120)','t','Test 524');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(40 40,80 60,120 100)','t','Test 525');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(40 40,120 100,80 60)','t','Test 526');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(40 40,60 100,100 60,120 120)','t','Test 527');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(20 120,60 60,100 100,140 40)','t','Test 528');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(20 20,80 70,140 120,200 170)','t','Test 529');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(20 20,140 120,80 70,200 170)','t','Test 530');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(80 70,20 20,200 170,140 120)','t','Test 531');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(80 70,140 120)','t','Test 532');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(140 120,80 70)','t','Test 533');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(80 170,140 120,200 80)','t','Test 534');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(80 170,140 120,200 80,80 70)','t','Test 535');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(10 10)','t','Test 536');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(10 10,20 20)','t','Test 537');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(10 10,20 20)','t','Test 538');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(10 10,20 20,20 10,10 10)','t','Test 539');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 40,100 100,180 100,180 180,100 180,100 100)','t','Test 540');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((10 10,20 20),(20 20,30 30))','t','Test 541');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((10 10,20 20),(20 20,30 20),(20 20,30 30))','t','Test 542');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((10 10,20 20),(20 20,30 20),(20 20,30 30),(20 20,30 40))','t','Test 543');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((10 10,20 20),(20 20,20 30,30 30,30 20,20 20))','t','Test 544');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((10 10,20 20,20 30,30 30,30 20,20 20))','t','Test 545');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((40 60,420 60,420 320,40 320,40 60))','t','Test 546');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((40 60,420 60,420 320,40 320,40 60),(200 140,160 220,260 200,200 140))','t','Test 547');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(130 240,130 240,130 240,570 240,570 240,570 240,650 240)','t','Test 548');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((10 10,100 10,100 100,10 100,10 10))','t','Test 549');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(30 220,240 220,240 220)','t','Test 550');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(110 290,110 100,110 100)','t','Test 551');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(120 230,120 200,150 180,180 220,160 260,90 250,80 190,140 110,230 150,240 230,180 320,60 310,40 160,140 50,280 140)','t','Test 552');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((200 360,230 210,100 190,270 150,360 10,320 200,490 230,280 240,200 360),(220 300,250 200,150 190,290 150,330 70,310 210,390 230,280 230,220 300))','t','Test 553');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(70 340,70 50,430 50,420 340,340 120,390 110,390 70,350 100,350 50,370 90,320 80,360 120,350 80,390 90,420 80,410 60,410 100,370 100,380 60,370 80,380 100,360 80,370 80,380 70,390 80,390 70,410 70,400 60,410 60,410 60,410 60,370 70,410 50,410 50,410 50,410 50,410 50,410 50,410 50)','t','Test 554');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(140 350,510 140,110 140,250 290,250 50,300 370,450 310,440 160,290 280,220 160,100 260,320 230,200 280,360 130,330 210,380 80,220 210,380 310,260 150,260 110,170 130)','t','Test 555');
-INSERT INTO "validtest" VALUES ('SRID=-1;GEOMETRYCOLLECTION(POINT(110 300),POINT(100 110),POINT(130 210),POINT(150 210),POINT(150 180),POINT(130 170),POINT(140 190),POINT(130 200),LINESTRING(240 50,210 120,270 80,250 140,330 70,300 160,340 130,340 130),POLYGON((210 340,220 260,150 270,230 220,230 140,270 210,360 240,260 250,260 280,240 270,210 340),(230 270,230 250,200 250,240 220,240 190,260 220,290 230,250 230,230 270)))','t','Test 556');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(50 320,50 280,50 230,50 160,50 120,100 120,160 120,210 120,210 180,210 150,180 180,140 180,140 210,140 260,160 180,140 300,140 320,110 320,80 320)','t','Test 557');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((50 50,200 50,200 200,50 200,50 50))','t','Test 559');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 20,20 160,160 160,160 20,20 20),(140 140,40 140,40 40,140 40,140 140))','t','Test 560');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((80 100,220 100,220 240,80 240,80 100))','t','Test 561');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 340,330 380,50 40,20 340))','t','Test 562');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((210 320,140 270,0 270,140 220,210 320))','t','Test 563');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 0,110 0,110 60,40 60,180 140,40 220,110 260,0 260,0 0))','t','Test 564');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((220 0,110 0,110 60,180 60,40 140,180 220,110 260,220 260,220 0))','t','Test 565');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 0,120 0,120 50,50 50,120 100,50 150,120 150,120 190,0 190,0 0))','t','Test 566');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((230 0,120 0,120 50,190 50,120 100,190 150,120 150,120 190,230 190,230 0))','t','Test 567');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 0,210 0,210 230,0 230,0 0))','t','Test 568');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((40 20,0 0,20 40,60 60,40 20)),((60 90,60 60,90 60,90 90,60 90)),((70 120,90 90,100 120,70 120)),((120 70,90 90,120 100,120 70)))','t','Test 569');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 0,340 0,340 300,0 300,0 0))','t','Test 570');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((40 20,0 0,20 40,60 60,40 20)),((60 100,60 60,100 60,100 100,60 100)))','t','Test 571');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 0,120 0,120 120,0 120,0 0))','t','Test 572');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((60 20,0 20,60 60,60 20)),((60 100,60 60,100 60,100 100,60 100)))','t','Test 573');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((160 330,60 260,20 150,60 40,190 20,270 130,260 250,160 330),(140 240,80 190,90 100,160 70,210 130,210 210,140 240))','t','Test 574');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((300 330,190 270,150 170,150 110,250 30,380 50,380 250,300 330),(290 240,240 200,240 110,290 80,330 170,290 240))','t','Test 575');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((120 340,120 200,140 200,140 280,160 280,160 200,180 200,180 280,200 280,200 200,220 200,220 340,120 340)),((360 200,220 200,220 180,300 180,300 160,220 160,220 140,300 140,300 120,220 120,220 100,360 100,360 200)))','t','Test 576');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((100 220,100 200,300 200,300 220,100 220)),((280 180,280 160,300 160,300 180,280 180)),((220 140,220 120,240 120,240 140,220 140)),((180 220,160 240,200 240,180 220)))','t','Test 577');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((100 200,100 180,120 180,120 200,100 200)),((60 240,60 140,220 140,220 160,160 160,160 180,200 180,200 200,160 200,160 220,220 220,220 240,60 240),(80 220,80 160,140 160,140 220,80 220)),((280 220,240 180,260 160,300 200,280 220)))','t','Test 578');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((80 220,80 160,140 160,140 220,80 220),(100 200,100 180,120 180,120 200,100 200)),((220 240,220 220,160 220,160 200,220 200,220 180,160 180,160 160,220 160,220 140,320 140,320 240,220 240),(240 220,240 160,300 160,300 220,240 220)))','t','Test 579');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((60 160,140 160,140 60,60 60,60 160))','t','Test 580');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((160 160,100 160,100 100,160 100,160 160),(140 140,120 140,120 120,140 120,140 140))','t','Test 581');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((10 10,100 10,10 11,10 10))','t','Test 582');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((90 0,200 0,200 200,90 200,90 0))','t','Test 583');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((100 10,10 10,90 11,90 20,100 20,100 10))','t','Test 584');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 20,0 20,0 0,20 0,20 20))','t','Test 585');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((10 10,50 10,50 50,10 50,10 31,49 30,10 30,10 10))','t','Test 586');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((60 40,40 40,40 20,60 20,60 40))','t','Test 587');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((10 100,10 10,100 10,100 100,10 100),(90 90,11 90,10 10,90 11,90 90))','t','Test 588');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 30,0 0,30 0,30 30,0 30))','t','Test 589');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((0 0,100 0,100 20,0 20,0 0)),((0 40,0 21,100 20,100 40,0 40)))','t','Test 590');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((110 30,90 30,90 10,110 10,110 30))','t','Test 591');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((100 10,0 10,100 11,100 10))','t','Test 592');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((100 10,0 10,90 11,90 20,100 20,100 10))','t','Test 593');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((10 30,10 0,30 10,30 30,10 30))','t','Test 594');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((10 30,10 10,30 10,30 30,10 30))','t','Test 595');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 0,200 0,0 198,0 0))','t','Test 596');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((280 60,139 60,280 70,280 60))','t','Test 597');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 0,140 10,0 20,0 0))','t','Test 598');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((280 0,139 10,280 1,280 0))','t','Test 599');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((1 4,1 1,2 1,2 4,1 4)),((3 4,3 1,4 1,4 4,3 4)),((5 4,5 1,6 1,6 4,5 4)),((7 4,7 1,8 1,8 4,7 4)),((9 4,9 1,10 1,10 4,9 4)))','t','Test 600');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 2,11 3,11 2,0 2))','t','Test 601');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 40,20 200,180 200,180 40,20 40),(180 120,120 120,120 160,60 120,120 80,120 119,180 120))','t','Test 602');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((200 160,160 160,160 80,200 80,200 160))','t','Test 603');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(160 140,160 100)','t','Test 604');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 40,20 200,180 200,180 120,140 120,180 119,180 40,20 40),(140 160,80 120,140 80,140 160))','t','Test 605');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((200 160,150 160,150 80,200 80,200 160))','t','Test 606');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((83 33,62 402,68 402,83 33))','t','Test 607');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((78 39,574 76,576 60,78 39))','t','Test 608');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(240 190,120 120)','t','Test 609');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((110 240,50 80,240 70,110 240))','t','Test 610');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(0 100,100 100,200 200)','t','Test 611');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((30 240,260 30,30 30,30 240),(80 140,80 80,140 80,80 140))','t','Test 612');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 340,200 250,120 180,160 110,270 40)','t','Test 613');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((60 320,60 80,300 80,60 320),(80 280,80 100,260 100,80 280)),((120 160,140 160,140 140,120 160)))','t','Test 614');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((100 240,100 180,160 180,160 120,220 120),(40 360,40 60,340 60,40 360,40 20),(120 120,120 140,100 140,100 120,140 120))','t','Test 615');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((60 260,60 120,220 120,220 260,60 260),(80 240,80 140,200 140,200 240,80 240)),((100 220,100 160,180 160,180 220,100 220),(120 200,120 180,160 180,160 200,120 200)))','t','Test 616');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((40 260,240 260,240 240,40 240,40 220,240 220),(120 300,120 80,140 80,140 300,140 80,120 80,120 320))','t','Test 617');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((60 320,60 120,280 120,280 320,60 320),(120 260,120 180,240 180,240 260,120 260)),((280 400,320 400,320 360,280 360,280 400)),((300 240,300 220,320 220,320 240,300 240)))','t','Test 618');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((80 300,80 160,260 160,260 300,80 300,80 140),(220 360,220 240,300 240,300 360))','t','Test 619');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((120 180,60 80,180 80,120 180)),((100 240,140 240,120 220,100 240)))','t','Test 620');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((180 260,120 180,60 260,180 260),(60 300,60 40),(100 100,140 100))','t','Test 621');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((95 9,81 414,87 414,95 9))','t','Test 622');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(93 13,96 13)','t','Test 623');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(0 0,100 100)','t','Test 624');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(0 100,100 0)','t','Test 625');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(0 0,100 100,200 0)','t','Test 626');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(0 0,100 100,200 200)','t','Test 627');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 360,40 220,120 360)','t','Test 628');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(120 340,60 220,140 220,140 360)','t','Test 629');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(220 240,200 220,60 320,40 300,180 200,160 180,20 280)','t','Test 630');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(220 240,140 160,120 180,220 280,200 300,100 200)','t','Test 631');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 320,220 320,220 160,80 300)','t','Test 632');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 200,60 260,140 200)','t','Test 633');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 200,60 140,140 200)','t','Test 634');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(180 200,100 280,20 200,100 120,180 200)','t','Test 635');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(100 200,220 200,220 80,100 80,100 200)','t','Test 636');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(0 10,620 10,0 11)','t','Test 637');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(400 60,400 10)','t','Test 638');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((120 320,180 200,240 320,120 320)),((180 200,240 80,300 200,180 200)))','t','Test 639');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(120 320,180 260,180 320,180 200,300 200,200 220)','t','Test 640');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((120 80,420 80,420 340,120 340,120 80),(160 300,160 120,380 120,380 300,160 300)),((200 260,200 160,340 160,340 260,200 260),(240 220,240 200,300 200,300 220,240 220)))','t','Test 641');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(200 360,420 340,400 100,340 120,200 140,200 160,220 180,260 200,200 360,420 340,400 100,340 120,200 140,200 160,220 180,260 200)','t','Test 642');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(40 90,20 20,70 70)','t','Test 643');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 20,100 100)','t','Test 644');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 20,110 110,170 50,130 10,70 70)','t','Test 645');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((100 320,100 220),(100 180,200 180),(220 180,220 320),(220 320,160 320),(100 320,100 220),(100 180,200 180),(220 180,220 320),(220 320,160 320),(100 220,100 320))','t','Test 646');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(100 320,100 260,100 220,100 200,100 180,120 180,200 180,220 180,220 260,220 320,200 320,160 320,140 320,120 320,100 320,100 260,100 220,100 200,100 180,120 180,200 180,220 180,220 260,220 320,200 320,160 320,140 320,120 320)','t','Test 647');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((-500 -140,-500 -280,-320 -280,-320 -140,-500 -140,-500 -340),(-500 -140,-320 -140,-500 -140,-320 -140,-500 -140))','t','Test 648');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(-560 -180,-420 -180,-500 -220,-500 -340,-500 -280,-500 -140,-320 -140,-420 -140,-320 -180,-280 -140,-320 -120,-560 -180,-420 -180,-500 -220,-500 -340,-500 -280,-500 -140,-320 -140,-420 -140,-320 -180,-280 -140,-320 -120)','t','Test 649');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((180 100,140 280,240 140,220 120,140 280),(140 280,100 400,80 380,140 280,40 380,20 360,140 280))','t','Test 650');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(200 200)','t','Test 651');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(100 100,200 200)','t','Test 652');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(100 100,200 200,300 300,500 500)','t','Test 653');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(100 100,200 200,400 400,600 600)','t','Test 654');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(80 200)','t','Test 655');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(260 80)','t','Test 656');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(60 260)','t','Test 657');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(120 260)','t','Test 658');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(80 80)','t','Test 659');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(80 280)','t','Test 660');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 0,140 0,140 140,0 140,0 0))','t','Test 661');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((140 0,0 0,0 140,140 140,140 0))','t','Test 662');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((40 60,360 60,360 300,40 300,40 60))','t','Test 663');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((120 100,280 100,280 240,120 240,120 100))','t','Test 664');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((80 100,360 100,360 280,80 280,80 100))','t','Test 665');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 280,0 0,260 0,260 280,0 280),(220 240,40 240,40 40,220 40,220 240))','t','Test 666');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 260,240 260,240 20,20 20,20 260),(160 180,80 180,120 120,160 180))','t','Test 667');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((60 80,200 80,200 220,60 220,60 80))','t','Test 668');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((120 140,260 140,260 260,120 260,120 140))','t','Test 669');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((60 220,220 220,140 140,60 220))','t','Test 670');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((100 180,180 180,180 100,100 100,100 180))','t','Test 671');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((40 40,180 40,180 180,40 180,40 40))','t','Test 672');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((180 40,40 180,160 280,300 140,180 40))','t','Test 673');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((40 280,200 280,200 100,40 100,40 280),(100 220,120 220,120 200,100 180,100 220))','t','Test 674');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((40 280,180 260,180 120,60 120,40 280))','t','Test 675');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((0 200,0 0,200 0,200 200,0 200),(20 180,130 180,130 30,20 30,20 180))','t','Test 676');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((60 90,130 90,130 30,60 30,60 90))','t','Test 677');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(100 120,100 240)','t','Test 678');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((40 60,160 60,160 180,40 180,40 60))','t','Test 679');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 80,140 140,200 200)','t','Test 680');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((40 40,140 40,140 140,40 140,40 40))','t','Test 681');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((190 190,360 20,20 20,190 190),(111 110,250 100,140 30,111 110))','t','Test 682');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 200,20 20,240 20,240 200,20 200),(130 110,60 40,60 180,130 110),(130 180,131 40,200 110,130 180))','t','Test 683');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(100 140,100 40)','t','Test 684');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((20 80,180 79,100 0,20 80)),((20 160,180 160,100 80,20 160)))','t','Test 685');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((20 80,180 80,100 0,20 80)),((20 160,180 160,100 80,20 160)))','t','Test 686');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 0,20 80,100 80,80 120,40 140)','t','Test 687');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(140 300,220 160,260 200,240 260)','t','Test 688');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 40,140 40,140 160,0 160)','t','Test 689');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(140 280,240 280,240 180,140 180,140 280)','t','Test 690');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(140 0,0 0,40 60,0 120,60 200,220 160,220 40)','t','Test 691');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 140,180 100,160 40,100 40,60 100,80 140)','t','Test 692');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 20,80 80)','t','Test 693');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 40,160 160,200 60,60 140)','t','Test 694');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 40,200 40)','t','Test 695');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(200 40,140 40,40 40)','t','Test 696');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(0 0,110 0,60 0)','t','Test 697');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(0 0,110 0)','t','Test 698');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(0 0,80 0,80 60,80 0,170 0)','t','Test 699');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((0 0,170 0),(80 0,80 60))','t','Test 700');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 100,180 200)','t','Test 701');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 180,180 120)','t','Test 702');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 40,100 100,160 160)','t','Test 703');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(160 60,100 100,60 140)','t','Test 704');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(140 60,60 140)','t','Test 705');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 40,180 180,100 180,100 100)','t','Test 706');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 90,50 50,0 0)','t','Test 707');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 140,240 140)','t','Test 708');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 140,100 140,80 80,120 60,100 140,160 140,160 100,200 100,160 140,240 140)','t','Test 709');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 20,100 20,20 20)','t','Test 710');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(60 20,200 20)','t','Test 711');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 60,180 60,180 140,100 140,100 60,220 60,220 180,80 180,80 60,280 60)','t','Test 712');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(140 60,180 60,220 60,260 60)','t','Test 713');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(0 20,40 20)','t','Test 714');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((20 40,20 0,60 0,60 40,20 40))','t','Test 715');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(0 20,20 20)','t','Test 716');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(20 20,40 20)','t','Test 717');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(80 260,140 260,180 260)','t','Test 718');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((40 320,140 320,140 200,40 200,40 320))','t','Test 719');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((0 40,0 0,40 0,40 40,0 40)),((40 80,40 40,80 40,80 80,40 80)))','t','Test 720');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 40,120 120,200 120)','t','Test 721');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 40,100 100,160 100)','t','Test 722');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(60 60)','t','Test 723');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(40 40,100 40)','t','Test 724');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 40,80 80)','t','Test 725');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(40 40,60 60)','t','Test 726');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(60 60,100 100)','t','Test 727');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(40 40,60 60,80 80)','t','Test 728');
-INSERT INTO "validtest" VALUES ('SRID=-1;POINT(20 30)','t','Test 729');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(40 40,80 60,40 100)','t','Test 730');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(80 280,80 220,160 220,80 220)','t','Test 731');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(80 280,80 220,160 220)','t','Test 732');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 60,160 60,80 160,80 20)','t','Test 734');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 80,80 20,80 80,140 60,80 20,160 20)','t','Test 735');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 60,100 60,60 100,60 60)','t','Test 736');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 60,60 60,100 60,60 100,60 60)','t','Test 737');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(20 20,80 20,80 80,20 20)','t','Test 738');
-INSERT INTO "validtest" VALUES ('SRID=-1;LINESTRING(80 80,20 20,20 80,140 80,140 140,80 80)','t','Test 739');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((40 140,160 40),(160 140,40 40))','t','Test 741');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((20 160,20 20),(100 160,100 20))','t','Test 742');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((60 140,20 80,60 40),(60 40,100 80,60 140))','t','Test 743');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((60 40,140 40,100 120,100 0),(100 200,200 120))','t','Test 744');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((40 120,100 60),(160 120,100 60),(40 60,160 60))','t','Test 745');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((80 160,40 220,40 100,80 160),(80 160,120 220,120 100,80 160))','t','Test 746');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTILINESTRING((80 160,40 220),(80 160,120 220,120 100,80 160),(40 100,80 160))','t','Test 747');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((180 260,80 300,40 180,160 120,180 260))','t','Test 748');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((240 160,140 220,80 60,220 40,240 160)),((160 380,100 240,20 380,160 380),(120 340,60 360,80 320,120 340)))','t','Test 750');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOLYGON(((240 160,100 240,80 60,220 40,240 160)),((160 380,100 240,20 380,160 380),(120 340,60 360,80 320,120 340)))','t','Test 751');
-INSERT INTO "validtest" VALUES ('SRID=-1;POLYGON((100 100,1e+15 110,1e+15 100,100 100))','t','Test 92');
-INSERT INTO "validtest" VALUES ('SRID=-1;MULTIPOINT(-1e+24 -1e+24,1e+24 -1e+24,1e+24 1e+24,-1e+24 1e+24,0 0)','t','Test 558');
-COMMIT;
