[postgis-tickets] [PostGIS] #4202: Topology extension upgrade from 2.1.9 to 3.0.0dev fails
PostGIS trac at osgeo.org
Sun Oct 14 06:45:45 PDT 2018
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.0.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by strk):
 The problem seems related to #2138 as the uninstall code in `run_test.pl`
 goes:
     if ( $OPT_WITH_TOPO )
         # NOTE: "manually" dropping topology schema as EXTENSION does not
         #       take care of that itself, see
         #       http://trac.osgeo.org/postgis/ticket/2138
         $cmd = "psql $psql_opts -c \"DROP EXTENSION postgis_topology; DROP
 SCHEMA topology;\" $DB >> $REGRESS_LOG 2>&1";
         $rv = system($cmd);
           $ok = 0 if $rv;
 I guess the `DROP SCHEMA topology` is checked _before_ the `DROP
 EXTENSION` takes effect (within same transaction) thus the problem.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4202#comment:1>
