[postgis-tickets] r16901 - [topology] properly drop removed internal functions on upgrade
Sandro Santilli strk at kbt.io
Mon Oct 15 03:38:39 PDT 2018
Author: strk
Date: 2018-10-15 03:38:39 -0700 (Mon, 15 Oct 2018)
New Revision: 16901
   branches/2.5/NEWS
   branches/2.5/topology/topology_drop_before.sql.in
References #4202 in 2.5 branch
Modified: branches/2.5/NEWS
--- branches/2.5/NEWS	2018-10-15 10:35:58 UTC (rev 16900)
+++ branches/2.5/NEWS	2018-10-15 10:38:39 UTC (rev 16901)
@@ -6,6 +6,7 @@
   - #4188, Avoid division by zero in kmeans (Raúl Marín)
   - #4189, Fix undefined behaviour in SADFWrite (Raúl Marín)
   - #4191, Fix undefined behaviour in ptarray_clone_deep (Raúl Marín)
+  - #4020, Fix leftovers in topology upgrade from 2.1 (Sandro Santilli)
 PostGIS 2.5.0
Modified: branches/2.5/topology/topology_drop_before.sql.in
--- branches/2.5/topology/topology_drop_before.sql.in	2018-10-15 10:35:58 UTC (rev 16900)
+++ branches/2.5/topology/topology_drop_before.sql.in	2018-10-15 10:38:39 UTC (rev 16901)
@@ -17,3 +17,6 @@
 -- used to be in public, will now be moved to topology
 DROP FUNCTION IF EXISTS postgis_topology_scripts_installed();
+-- Removed in 2.2.0 when topology API moved to liblwgeom
+DROP FUNCTION topology._ST_RemEdgeCheck(varchar, integer, integer, integer, integer);
+DROP FUNCTION topology._ST_AddFaceSplit(varchar, integer, integer, boolean);
