[postgis-tickets] r16905 - [topology] properly drop removed internal functions on upgrade
Sandro Santilli strk at kbt.io
Mon Oct 15 03:49:02 PDT 2018
Author: strk
Date: 2018-10-15 03:49:02 -0700 (Mon, 15 Oct 2018)
New Revision: 16905
   branches/2.2/NEWS
   branches/2.2/topology/topology_drop_before.sql.in
Closes #4202 in 2.2 branch
Modified: branches/2.2/NEWS
--- branches/2.2/NEWS	2018-10-15 10:48:56 UTC (rev 16904)
+++ branches/2.2/NEWS	2018-10-15 10:49:02 UTC (rev 16905)
@@ -6,6 +6,7 @@
    - #4160, Use qualified names in topology extension install (Raúl Marín)
    - #4189, Fix undefined behaviour in SADFWrite (Raúl Marín)
    - #4191, Fix undefined behaviour in ptarray_clone_deep (Raúl Marín)
+   - #4020, Fix leftovers in topology upgrade from 2.1 (Sandro Santilli)
 PostGIS 2.2.7
 2018/04/06
Modified: branches/2.2/topology/topology_drop_before.sql.in
--- branches/2.2/topology/topology_drop_before.sql.in	2018-10-15 10:48:56 UTC (rev 16904)
+++ branches/2.2/topology/topology_drop_before.sql.in	2018-10-15 10:49:02 UTC (rev 16905)
@@ -17,3 +17,6 @@
 -- used to be in public, will now be moved to topology
 DROP FUNCTION IF EXISTS postgis_topology_scripts_installed();
+-- Removed in 2.2.0 when topology API moved to liblwgeom
+DROP FUNCTION topology._ST_RemEdgeCheck(varchar, integer, integer, integer, integer);
+DROP FUNCTION topology._ST_AddFaceSplit(varchar, integer, integer, boolean);
