[postgis-tickets] r16907 - Use portable code to write extension-protection line
Sandro Santilli strk at kbt.io
Mon Oct 15 04:31:38 PDT 2018
Author: strk
Date: 2018-10-15 04:31:38 -0700 (Mon, 15 Oct 2018)
New Revision: 16907
   branches/2.3/NEWS
   branches/2.3/extensions/postgis/Makefile.in
References #4203 in 2.3 branch
Modified: branches/2.3/NEWS
--- branches/2.3/NEWS	2018-10-15 11:31:11 UTC (rev 16906)
+++ branches/2.3/NEWS	2018-10-15 11:31:38 UTC (rev 16907)
@@ -11,8 +11,8 @@
   - #4189, Fix undefined behaviour in SADFWrite (Raúl Marín)
   - #4191, Fix undefined behaviour in ptarray_clone_deep (Raúl Marín)
   - #4020, Fix leftovers in topology upgrade from 2.1 (Sandro Santilli)
+  - #4203, Fix build with GNU Make 4.1 (Sandro Santilli)
 PostGIS 2.3.7
 2018/04/06
Modified: branches/2.3/extensions/postgis/Makefile.in
--- branches/2.3/extensions/postgis/Makefile.in	2018-10-15 11:31:11 UTC (rev 16906)
+++ branches/2.3/extensions/postgis/Makefile.in	2018-10-15 11:31:38 UTC (rev 16907)
@@ -34,12 +34,12 @@
 CURV_big=@POSTGIS_MAJOR_VERSION@@POSTGIS_MINOR_VERSION@
 ifeq ($(PG91),yes)
 all: sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql sql_minor_upgrade
 sql/$(EXTENSION).sql: sql_bits/postgis.sql sql_bits/postgis_comments.sql sql_bits/rtpostgis.sql sql_bits/spatial_ref_sys_config_dump.sql sql_bits/raster_comments.sql sql_bits/spatial_ref_sys.sql
 	mkdir -p sql
-	echo '\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \quit' > $@
+	printf '\\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \\quit\n' > $@
 	cat $^ >> $@
 sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql
@@ -49,7 +49,7 @@
 sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: sql_bits/postgis.sql sql_bits/rtpostgis.sql ../../utils/create_unpackaged.pl
 	mkdir -p sql
 	cat ../../postgis/postgis.sql ../../raster/rt_pg/rtpostgis.sql | $(PERL) ../../utils/create_unpackaged.pl postgis > $@
 #this is a cludge to allow upgrading from same SVN to same SVN
 sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql: sql_bits/postgis_extension_upgrade_minor.sql
 	cp $< $@
@@ -57,7 +57,7 @@
 	cp $< $@
 #strip BEGIN/COMMIT since these are not allowed in extensions
-sql_bits/spatial_ref_sys.sql: ../../spatial_ref_sys.sql
+sql_bits/spatial_ref_sys.sql: ../../spatial_ref_sys.sql
 	$(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' $< > $@
@@ -70,7 +70,7 @@
 sql_bits/postgis_comments.sql: ../../doc/postgis_comments.sql
 	cp $< $@
 sql_bits/rtpostgis.sql: ../../raster/rt_pg/rtpostgis_for_extension.sql
 	mkdir -p sql_bits
@@ -79,7 +79,7 @@
 sql_bits/spatial_ref_sys_config_dump.sql: ../../spatial_ref_sys.sql ../../utils/create_spatial_ref_sys_config_dump.pl
 	$(PERL) ../../utils/create_spatial_ref_sys_config_dump.pl $< > $@
-sql_bits/rtpostgis_upgrade.sql: ../../raster/rt_pg/rtpostgis_upgrade_for_extension.sql
+sql_bits/rtpostgis_upgrade.sql: ../../raster/rt_pg/rtpostgis_upgrade_for_extension.sql
 	$(PERL) -pe "s/BEGIN\;//g ; s/COMMIT\;//g; s/^(DROP .*)\;/SELECT postgis_extension_drop_if_exists('$(EXTENSION)', '\1');\n\1\;/" $< > $@
 sql_bits/postgis_upgrade.sql: ../../postgis/postgis_upgrade_for_extension.sql
@@ -94,7 +94,7 @@
 #postgis_extension_upgrade_minor.sql is the one that contains both postgis AND raster
 sql_bits/postgis_extension_upgrade_minor.sql: ../postgis_extension_helper.sql sql_bits/postgis_upgrade.sql sql_bits/rtpostgis_upgrade.sql ../../doc/raster_comments.sql ../../doc/postgis_comments.sql ../postgis_extension_helper_uninstall.sql
 	cat $^ >> $@
 sql_minor_upgrade: sql_bits/postgis_extension_upgrade_minor.sql
